Question about Dell Inspiron E1505 Notebook
My inspiron had hard disk problem...
Hi!
my inspiron had hard disk problem. i replaced the hard disk and when i start it, doesnt even have the LCD display. I see the lights blinking for few seconds and it turns off. Can you please help me?
thanks in advance..
Raj...
  • 383 Answers
Windows setup: Compressed volume or disk-cache utility error. fdisk <press enter>; In fdisk choose the option to display partition information (option 4). Determine the type of system currently setup on the hard disk .
Good Luck, Please dont for get to Vote. Thank You.
Posted on Dec 19, 2007
Hi i recently started having problems with my dell inspiron 1545 screen. At first it started to freeze and fade to bright white, eventually after a few days it became stuck white even after booting the...
Hi lewis haywar,
Try to replace the LCD inverter in your laptop. Most common issues on LCD are due to failing LCD inverter. It fails more often than LCD cable or LCD backlight does.
Please let me know if this solution helped to resolve your issue.
May 11, 2011 | Dell Inspiron 1545 Notebook
I have INSPIRON 640m. From many months it gives an error saying "Windows deteted hard disk problem". Please back up your files and contact computer manufacturer. In details it syas WDC...
Hi govindcg,
This is an early Warning system for computers of a pending Hard Drive failure. I greatly suggest that you back up your files and replace the Hard Drive as this is the only way to fix it. Hope this helps.
Thanks
Feb 22, 2011 | Western Digital (WD1200BEVS) 120 GB SATA...
My dell inspiron laptop will not start up tingxuan - Nov 18, 2008 11:19am GMT - Last answer on Jul 19, 2010 3:58pm BST tech Hello, recently I have just switched the hard disk of one of my inspiron laptop...
Hi, I have not spoken to you before, I take it the PC was working fine before you switched hard drives?? If so, check to see if you can boot into BIOS, by pressing the F1 key during doot up. If you can and the previous question is Yes, then I believe you will need to reinstall XP.
Hope this helps
Jul 21, 2010 | Dell Inspiron 1525 Laptop Jet Black
Hi, i am facing some issues in my Dell inspiron 1525 laptop. I am not able to download anything into my laptop. Even if the download bar shows a complete status i cant find the the document anywhere in my...
By the way are you using an IE or Firefox? If you are using different type of a browser make sure to check the settings of which is the location or folder that store all the downloaded files.
If you are using an IE: the default for that would be under either My Documents or My Received Files folder.
But if you are using Firefox the default would be on the Desktop. Hope this help you out. Thank you.
Apr 09, 2010 | Dell Inspiron 1525 Laptop
It doesnt detect my harddrive and it causes windows to crash...how do i fix it?
If the BIOS cannot detect the hard disk then probably the hard disk is faulty.
To check if the hard disk is faulty, remove the hard disk and connect it to an USB hard drive adapter and connect it to a working computer's USB port. If this computer cannot detect the hard drive or open the folders and files, then the hard disk is faulty.
To get your computer operating again, replace the hard drive with a new one and install Windows on the new hard drive plus the computer's device drivers and your programs.
Mar 15, 2010 | Dell Inspiron 1525 (dndppa1_3) Intel Core...
Dell inspiron does not boot up
Do you see anything on screen? Dell logo? I will assume you see nothing. Not even a Dell logo.
First test your power supply with a meter to be sure it is putting out 18-19 volts. If good, remove the laptop battery and try again. The next tests should be done with the battery not connected to the laptop.
Remove the hard drive and see if it boots. If not, next remove the dvd drive from the laptop and try to boot. If no good, remove the ram, clean the contacts on the ram and the slot with a pink pencil eraser....gently, just make them shiny. Try to boot with no ram/hdd/dvd. Put the ram back in and try again. Try connecting the laptop to an external monitor.
If after all this you still cannot get a Dell logo at boot time, the mainboard is likely dead. A refurbished one (with only 90 day warranty) will probably cost you at least $250 from Dell. Please let this one go and look at a new laptop.....sorry.
Hope this helps :)
Aug 23, 2009 | Dell Inspiron 6400 Notebook
Dell Inspiron 8500 started boot error message ?primary hard disk drive 0 failure, no boot device available?strike F1 to retry reboot, F2 for setup. Ran express diagnostics and it shows two errors: Error...
Call Dell if under warranty. Start shopping for a replacement hdd if outside of warranty. You'll need
your OS disks that came with computer (hopefully). If you don't have OS/recovery disks, you can get
them from Dell or even using somebody elses (match version with sticker on your laptop).
Check the hdd connection underneath laptop - make sure cable is not loose, etc.
Probably safe to say your data is gone unless you're willing to spend $$.
Jul 12, 2009 | Dell Inspiron 8500, Latitude D800...
Doesnt boot from DVD rom
Hi
I know it sounds a bit odd but were u using a bootable disk to boot?
If yes, then try epgrading ur BIOS version it may help.
Jun 01, 2008 | Dell Inspiron E1405 Notebook
Dell Inspiron E1505 Notebook Logo
52 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
