Question about Acer Aspire 5630 Notebook
Poor speaker volume
I have a DELL desktop with Windows XP OS and DELL speakers that came with the PC.
The speaker volume is very poor, and all the audio settings are on full.
How can I improve the volume, I don't wish to blast the room with volume, I just want to be able to listen to tutorials without having to place the speaker on my ear.
  • 5,603 Answers
If the speakers do not have internal amplifiers they won't be very strong.
SOME have the capability of being used either way. Those have a place to plug in a power adapter wall wart to power them.
The internal amp in the laptop just don't have much power to drive passive speakers.
Posted on Sep 29, 2009
Sound not working
Choose your OS download and install drivers.
Nov 30, 2012 | Dell Dimension XPS 400 PC Desktop
Model no# for issue no sound using Windows Xp (home edition) is 1213 V2 Premiere.The recovery disc. used was a Dell pc notIebook,my os originally had sp1 but I installed
If your computer came with a motherboard disc the sound drivers could be on it
Click start control panel administrative tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers.
Click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have selected the correct speaker settings.
Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
If his does not fix the problem
Click start control panel sounds and audio devices you can adjust the volume there also select speaker.
volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the speaker volume icon system select adjust volume.
Click start control panel sounds and audio volume advanced speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand system speaker right click properties then select use this device (enable).
The speaker plug/outlets is usually at the back of the computer or if its a laptop on the side.
You will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity.
Clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line specifically around the sound card and the CPU central processing unit.
Dust causes static to build up in a computer
http://download.cnet.com/2000-20_4.html
On the home page you should see a search tab just type in what you are looking for.
Tick in either the all software or windows software box
IE: motherboard name audio driver you might have to try a few times to get it right
Nov 19, 2012 | Computers & Internet
I have not lost all the sound it is just when I turn up the volume on the speakers all the way it is like it is only playing half, every control is set to max.
Try updating or reinstalling the sound driver. I noticed the Dell website only has support for Windows upto XP, you havent stated which operating system you have. Try getting an update through the windows update service or download a free software called Drivermax from www.drivermax.com which will scan, find and install the best driver available. If all this fails i would install a PCI soundcard which will sound a hell of a lot better anyway. cheers from Scott
Feb 22, 2010 | Dell OptiPlex GX520 PC Desktop
I have just installed speakers on my computer, but I can't get any sound.
Check to make sure the speakers power up.
Check to make sure you have installed the speakers into the correct jack on the back of the PC.
Go into Control Panel and check the settings by double-clicking the "Sounds and Audio Devices" icon. Make sure the Mute box isn't checked and that the volume is turned up.
Dec 09, 2009 | Dell Dimension 4600 PC Desktop
I have static in my speakers
Static in the speakers is normally caused by a poor connection. Take all the connections apart and spray them with an electronic cleaner you can purchase at Walmart or any electronics store. Look at the connections and if you see corrosion use a pencil eraser to clean them off.
Sep 20, 2009 | Dell DimensionTM E520 PC Desktop
Dell vostro sound low,using windows xp
Dell Vostro does not have an entertainment integrated speakers. These are just small speakers designed for basic usage. You may connect an external speakers. For adjusting the volume, on the bottom right of your screen, beside the clock, click on the speaker icon and adjust the volume slide
Jun 14, 2009 | Dell Vostro A860 Notebook
Speakers work for just a second when windows starts up
Try to uninstall the sound card, shut your pc off, take the sound card off, attach it again and turn on the pc. Then reinstall the drivers and see whether the same problem occurs or not.
Thanks,
Mary
Mar 31, 2008 | Dell A215 Computer Speakers
Acer Aspire 5630 - Low speaker volume, poor quality, OS=Vista
It's likely that the speakers are blown out if it's quiet and making a crackling sound. To fix that, the speakers can be replaced or you can use external speakers.
Mar 23, 2008 | Acer Aspire 5630 Notebook
Dell Dimension 2200
Some basic questions first: -Are you using the built-in sound card and are your speakers plugged into the green socket? -Did you plug your speakers into another computer to see if they work, if you didn?t how did you test them? -Have you checked the Sounds and audio devices in the control panel? Go to Start, Control Panel, and open Sounds and Audio Devices. Make sure the volume is up and the mute box IS NOT checked. If you?re using Windows XP Click on the Speaker Volume button and make sure the left and right speaker volumes are up. -What program are you trying to use to test the sound volume? Let us know if this solves your problem or if you need some more assistance.
Feb 08, 2007 | Dell Dimension 2200 (A-D0601) PC Desktop
Acer Aspire 5630 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
