Question about Pioneer GM-5000T Car Audio Amplifier
Car amp i am having a problem with my amp it started out popping 2o amp fuses and then i noticed on the amp it said to use 25's so i did and then they worked for a while and then now it won't get any sound out of the amp now so i thought i burned the traces out on the deck . So i sent it out and they resoldier them i got it back and i still cant get any sound out of it. i even tried another amp i have no clue please help i am in a little village in alaska where there is no installers and it cost 2000$ to get my truck out of here and back
  • 631 Answers
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Posted on Dec 19, 2007
Where is the fuses for the wind shield washer pump located? I don t have a diagram
WHAT IS UR PROBLEM EXACTLY?THE WASHER PUMP DONT WORK? CHECK FUSE 24 .IT IS A 2O AMPS FUSE AT THE FUSE HOLDER LOOKING LIKE THIS..
Mar 14, 2015 | 2012 Volkswagen New Beetle
Keep popping 25 amp fuse trying to start honda motor on 3100 wolf pac roller
Your wolf pack is probably drawing too many amps. There are running amps and there are start up amps. The start may be too high for the generator.
Oct 05, 2014 | Honda 23* HP with Key Ignition GX630-QZB2
Fuse (10 amps) that provides juice to temp gage, rpm, speedometer and fuel gage keeps blowing up.
Try to use a 20 fuze one if it burns out that quick use a bigger recemend using a 20 or 25 fuze
Jul 27, 2014 | 2001 Chevrolet Chevrolet Blazer
I have a 2004 Chevy Cavalier. A couple of months ago, just after starting the car one day, the 'check engine' and 'trac off' lights both came on. I immediately shut off the car, waited approximately 5...
Many cars have the cooling fan on a thermostat or time delay, to allow it to run for a short period of time after the engine turns off, to cool the engine off. You may have just never noticed it before. So I wouldn't worry about that.
Your real problem is the blowing fuses, apparently you have a short somewhere in your wiring. Putting in bigger and bigger fuses is a great way to set fire to your wiring harness. It's possible that the wire is pinched or chafed somewhere, and perhaps when you hit a bump just right, it touches and shorts.
You may have to take this to the Chevy dealer or a GOOD independent shop to have them chase it down. Unless someone out there knows exactly what this is, it could be a tough one to find.
Apr 26, 2011 | Chevrolet Cavalier Cars & Trucks
6.5 diesel i put a new charging wire fron 10mm bolt on back of new altinator to the battery,i put a 25amp fuse link on the wire and when i start truck fuse pops,please help
Hi, 25 Amps is too small for that alternator. Your alternator is rated at 105 amps. Correct link is probably 125 amps. OK?
Jan 16, 2011 | 1995 Chevrolet K2500
My Fuel Fuse Keeps poping
I'd try a 20 amp maybee even a 25
Sep 17, 2009 | 1999 Pontiac Sunfire
Popped radio fuse need to kno which one it is 2004 dodge durango
T he fuse should be in your junction box under the hood. Its a 25 amp fuse so just look for the 25 amp fuse thats blown
Aug 11, 2009 | 2004 Dodge Durango
2o amp starter fuse blows
This is a iindication of Hi resistance in your starter, thus starter May be on its way out
Jan 09, 2009 | 2001 Dodge Stratus
PPI2360 Car Amp. blowing fuses...
the bridge rectifier is most likley shorted in the amp.you could repair yourself if you can solder but amps are cheap today and you might just look into replacing it.please rate my solution.
Jan 06, 2008 | PPI2360 Car Audio Amplifier
Pioneer GM-5000T Car Audio Amplifier Logo
52 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
