Question about HP Photosmart M517 Digital Camera
Why does my camera say batteries depleted and shuts down when i put new batteries in it
    President:
  • 2,185 Answers
As a workaround, you need to take out the memory card and take our the batteries as well. let it stay out for like 15 minutes and then put everything back. Or you can try using new and fresh batteries.
This commonly happens if you are using alkaline batteries. You need to use a high capacity NiMH rechargeables for better solution.
Posted on Sep 29, 2009
SOURCE: my camera won't work at all it just says batteries depleted even with new batteries
well wat u need to do is take the memery card out and take the batteries out 4 a little bit
Posted on Jul 09, 2007
SOURCE: Batteries are Depleted
A camera rep told me that use about 2500mi (?) batteries instead of the 900 I was using otherwise the batteries will be depleted with just one picture. Digital cameras or any other digital piece of equipment needs the extra power. Make sure that your charger will charge the 2500 power ones fully.
Posted on Apr 12, 2008
SOURCE: Batteries "depleted"
I also have 2 Canon cameras with the same problem. The A710 is particularly bad and is worst when using rechargeable batteries.
The reason I believe is the lower voltage of NiCd or NiMh which is 1.2 volts as opposed to 1.5 for normal ones.
These cameras are designed for a 3v battery. When you use rechargeables the camera only gets 2.4 volts which indicates to the camera that the batteries are almost dead! If you've just charged them , then the voltage will be a little higher initially and so the camera will work for a while.
It's a big design flaw. What they should have done was have a switch inside the camera that would allow you to choose normal or rechargeable cells.
Other manufacturers overcome this problem by having a built-in rechargeable battery and the camera is designed to work with the correct voiltage.
The solution? I can think of two possible solutions.
One is to use rechargeable ALKALINE cells which used to be available 10 years ago. The voltage is 1.5v but the capacity was unfortunately low.
The other possibility is to build a rechargeable lithium cell such as used in cell phones to fit the battery compartment. This would give 3.6v which would be great. Someone could make a mint manufacturing such a unit with a charger.
Posted on Feb 02, 2009
pontelemon
  • 538 Answers
SOURCE: camera keeps shutting down
Yes, that's sounds like a main board.
Posted on Mar 18, 2009
SOURCE: battery life
I bought a few SL400R.. yes I think this is the best camera ever. The battery that came with the cameras always would last very short time, especially in cold weather. But when I ordered new ones online, these would last very long. The specs of the new batteries are the same as the original ones. Go figure. After that I ordered external charger too, so I dont need to use the camera's built-in charger. Works very well.
Posted on Mar 20, 2009
Camera will not come on. I bought new battery for it and still nothing
As long as the battery is fully charged, if it doesn't work, the only solution is to return it to the maker for repair.
With items like this, the battery depletes over time itself even if it isn't used. I have some very good rechargeable batteries that will deplete in my camera if left for 3 months.
Sep 23, 2016 | Video Cameras
I have the Nikon Coolpix L100 camera and have had it for several months without encountering a single problem. I got a message saying that the batteries were exhausted and it shut down. I replaced the...
I have the same problem with my Coolpix L100. On 27 December 2010 after taking a few shots with flash, using rechargable batteries for one year, it displayed in Hungarian that the batteries are depleted, but after I have recharged them, the camera did not start again anymore, displaying in continue that the batteries are depleted, and it turn off itself after a few seconds. I think that the problem is with the sensor of the camera that should measure the battery status, because even if I had new batteries it desplayed an icon with half battery but I never let it depleted totally so far. Now I am wondering if NIKON will offer free service for it as I have bought it just about 16 months ago in the Romanian DOMO market chain.
Dec 25, 2010 | Nikon COOLPIX L100 Digital Camera
Batteries flat after taking 1 photo
Try cleaning the battery contacts inside the camera with a cotton swab lightly dampened with rubbing alcohol.
Dec 18, 2009 | HP Photosmart M417 Digital Camera
Camera says batteries are low but batteries are new
Try cleaning the battery contacts in the camera with a pencil eraser. If there is any sign of corrosion on the contacts, take a q-tip, dip it in white vinegar and clean the contacts....
Mar 21, 2009 | Pentax Optio 30 Digital Camera
Camera keeps shutting down
Mar 18, 2009 | HP Photosmart M417 Digital Camera
I have a HP Photosmart M415 digital camera 3 years old. It will not hold the charge in the rechargable batteries and also when I replace them with Duracel I can only take about 10 photos and then the...
You have to go for a rechargeable battery as duracell doesnt have enough current as the camera consumes more energy then a rechargeable battery has. go for uniross 2200 mha battery that is pretty cheap and best.
May 22, 2008 | HP Cameras
Battery depleted
Sounds like the battery might be defective/worn out. If it's AA batteries (a.k.a. R6) try with a pair of good-quality alkaline batteries to see if it works then. Cheap batteries often doesn't have enogh "umph" to power cameras.
Dec 20, 2007 | HP Photosmart 735 Digital Camera
S2 pro electronic malfunction?!?!
If your lithium batteries are depleted, having them in the camera will shut it down. A common cause of depleting the lithium batteries is leaving them in the camera while using the AC power adapter. For some odd reason, the Fuji engineers did not build in a disconnect circuit when on AC power. You should always remove the lithium batteries when using the AC adapter.
The Fuji S2 will run fine without the lithium batteries, except that you will not be able to use the built-in flash. Fuji recommends that as an "emergency" procedure, but I ran my S2 off NiMH AAs only for my heavy use over four years with no adverse effects.
If you buy the MB-16 battery pack or one of the modified versions for the S2, you would be able to use 8 AA batteries to power the camera, including the built-in flash, and never touch another lithium battery. The MB-16 itself does require some modification in filing off edges around the base and building up material around the post to firmly engage the switch you found.
Sep 29, 2007 | Fuji FinePix S2 Pro Digital Camera
My camera won't work at all it just says batteries depleted even with new batteries
try taking the camera to ur local hp dealer and smash it to the ground jump up and down shouting i feel better now ha ha ha ur all nuts michael
Jul 05, 2007 | HP Photosmart M425 Digital Camera
HP Photosmart M517 Digital Camera Logo
284 people viewed this question
Top HP Cameras Experts
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
