Question about Tascam DP01FX All-In-One Recording Package Microphone
DP02- turning on an effect but not recording effect on track
Weird issue. When I enable an effect (for example, distortion), the sound I hear is the effected sound, I hit record, record the part (still hearing the effect). After the take I playback and it recorded the part WITHOUT the effect. Why? I turn on and off the effects, assign/unassign, etc. takes several tries and eventually it works. But I have no idea why it does this, nor do I have a solution. I have to test the track before I record a part or it'd be a waste of time. Anyone else have this issue? or a fix? Aside from that I love this machine. Had a 424 back in the day and this is almost as easy to use. And damn clean recordings.
thanx
Bill
to hear my DP02 in action: myspace.com/alascar11
  • qq121q Sep 29, 2009
    I'll try it. It isn't consistent. It usually just works. Once in a while it doesn't....strange. thanx for the speedy reply though. Other than that I'm tascam all the way and love the results w this machine. I used to make some pretty good recordings from my old 424 too.
    www.myspace.com/alascar11
  • Tascam Master
  • 5,603 Answers
You MIGHT try turning on the effect right after hitting record. It is possible that the record cancels the effects... I don't know if this is possible, but if it is, try it.
I can kind of see a technical reason they might do this.
Posted on Sep 29, 2009
My DP-02CF comes up with no free disk space even though i've bounced everything together and ive still got 6 tracks left. how can i stop this from happening
This is just a suggestion - back up the track to a PC using the USB port and reload and reburn on a new disc. Sounds like you may have a bad file and or disc. And by the way you worded this, has this happened before? Make sure the activity light is out and your tracks have been recorded fully before turning the unit off or you will get "end of file" errors.
Len
Nov 01, 2009 | Tascam 2488 Portastudio Multitrack...
I have a Tascam DP-02 8-track all-in-one digital recorder. I've successfully armed and recorded Ch's 1 and 2 to input A and saved the session. When I loaded the session the next day to resume the project,...
i had a look for u on the net only the small yellow ones light up but ill get back to you about the other question as soon as i find a ansew wont be long thanks from chris
Sep 14, 2008 | Tascam DP01 All-In-One Recording Package...
Effects won't record or play back
Turn on the effect for the appropriate input or turn on the reverb. For the reverb you must turn up at least one tracks (the track you are using) effects send together with the Master effects return. The volume of the multi effect may need adjusting or the parameter of the effect is so low that the effect is too subtle to be noticed. Multi effect page 60 of the manual. Manual can be found at http://www.tascam.com/products/dp-01;9,16,33,19.html under resources.
May 28, 2009 | Tascam DP01 All-In-One Recording Package...
Poor Recording Level on the Tascam DP-02CF
When I record on DP-02/CF Tascam I can't get the music to play back. Do I have to do something other than rewind to be able to hear it? Albert S.
Feb 08, 2009 | Tascam 2488 Portastudio Multitrack...
Dp02 recording music(from stero)
Sounds like you are using the DP-02's 'stereo mix' inputs here. If so, the signal input from those is only routed to the line out and headphone jacks and cannot be recorded using the DP-02.
To record from a stereo you need to take the left and right aux outs (or some other line out - like the tape outs) from the stereo and put them into the main A and B mic/line inputs on far right of the DP-02's back panel. Then assign them to two respective tracks and you can record the stereo output to the DP-02. Just make sure you use a line level output from the stereo as the amplified speaker output can overpower and damage the inputs on the DP-02. You might need a couple of rca to 1/4 inch adapters to accomplish this.
Hope this helps.
bd.
Jan 14, 2009 | Tascam DP01 All-In-One Recording Package...
Tascam DP-02cf
You've got two inputs on the DP-02 so you can record two sources at once.
Depending on how you want the electric guitar recorded (mic the amp, or direct line in) you can in the first case plug your guitar mic into one of the mic inputs on DP02 and plug your vocal mic into the other mic input. You also have the option of plugging the guitar directly into the DP02 (using the hi-z input - I believe it is labelled 'guitar' or something on the DP02. I any event I believe it's the one on the left). This way you only need one mic for use recording the vocal part.
To avoid any 'bleed' between channels you can use the headphones while recording this way and you'll avoid having the unamplified guitar sound coming through over the vocal mic.
Once you have the mics or guitar and mic plugged into two inputs, you need to assign the inputs to a channel (track) to record on. You do this by pressing the select button for the input and then pressing the select button for the track where you want to record the input. Do this for both inputs so that they are recording on different tracks. Then arm the tracks for recording by pressing the record button for each track and the lighted buttons will flash above each armed track. Then just press play and record and you'll be recording. You can go back and redo it as many times as you like and record over what is there, or preserve a take and assign a new track (or tracks) for another take. You've got 8 to play with.
Hope this helps.
bd.
Sep 01, 2008 | Tascam 2488 Portastudio Multitrack...
Mic effects
The short answer is that you'd use the multi effect (or one of the 4 mic effect) to one channel for effecting your mic input. Reverb should be added later using the single effect. You'd send the already recorded track to the send effect and then return it to another track and 'print' it using a bounce. 'Send' sends the signal to the effect and returnsit to the mix bus. So to add reverb to a track you'd send that track to the single effect after configuring the reverb effect the way you'd like it, and then make sure all of the other are turned down and record it to an open track during a bounce.
The single effect is what would be referred to as a 'send effect' and is designed to be used at mixdown or during a bounce. In the 2488 the single, aux and send effects are all 'send effects'. These take an existing sound and change it. Examples are reverb, chorus, delay, phaser and flanger. The internal effects on the 2488 can be used or external sound processors can be fed with the sends and returned to inputs on the 2488.
The 2488's multi-effect, as well as the mic x4 effects are 'insert effects' to be used on the input signal when recording. Examples of insert effects are compression, expansion, gating, limiting and distortion.
You can send all channels (or multiple channels) to the same effect send, but they all must be sent to the same effect (or chain of effects) at once. You cannot for instance send channels 1,2 and 5 to one send effect and 3 and 4 to another at once. You'd have to do something like that in two seperate operations.
Insert effects cannot be shared among channel strips. Each sound source needs its own insert effect. The 2488 has one multi-effect box which acts like an effect chain on one channel or 4 mic effects which can be assigned to 4 mic inputs at once. Each input assigned uses one of the mic effects up (a stereo pair will use 2) of the available 4.
The main thing to remember is that there are the 2 different effect types. Sends are for adding something to the signal like reverb, chorus, delay, phase shift, flange (on the 2488 these are the single effect and the aux send effects) while insert effects act on the signal modify or subtract from it (compression, gate, limiter, distortion).
Hopefully this helps. I know it can be quite confusing starting out.
bd.
Jun 26, 2008 | Tascam 2488 Portastudio Multitrack...
Tacsam DP02
this generally means there is a short.
Apr 25, 2008 | Tascam DP01 All-In-One Recording Package...
Tascam 2488 Recorder
if the multitrack doesnt have built in effects you need to but an extrenal vocal effects processor that you can wire up to it. try lexicon products, they offer really good realistic vocal effects rack units.
Dec 26, 2007 | Tascam 2488 Portastudio Multitrack...
118 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
John
John
Michial Gueffroy
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
