Question about Amana Refrigerators
Amana model BR18D. Freezer building up ice. Bad timer or heating element? This is a bottom freezer, pull out drawer 2001 model.
  • 1073 Answers
SOURCE: Icing up in bottom of the freezer
machine has a defrost issue, defrost mi metal or defrost timer
Posted on Apr 12, 2008
rpbuice
  • 161 Answers
SOURCE: Ice build up in freezer
Defrost system failure.
Defrost timer, heater, therma disk, any one could be bad.
You could manually defrost and this would get the Ref back to working for a couple of days before it iced up again. Remember there is a lot of ice build up on the cooling coils in the freezer that you can't see so, a little extra time with a hair dryer is needed to do a complete manual defrost.
Posted on Jan 21, 2009
david04928
  • 102 Answers
SOURCE: Build up of ice on bottom of LG fridge freezer
Is it supposed to be self defrost? If so then either underneath the freezer needs to be cleaned. coils if dirty will cause freezer not to work well. I that doesn't help you might have a freon leak which would make it under charged and would ice up like that.
Posted on Mar 15, 2009
Maanita
  • 1142 Answers
SOURCE: fan runs constantly, freezer ice melting, bottom drawer in refrig
  • If your refrigerator temperature is closer to 35 degrees, try turning the temperature up slightly.
  • If you find that the temperature varies a lot from the top shelf to the bottom (where it is coldest), try putting produce and other sensitive products on a higher shelf.
  • If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. Other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models) or a defective air damper. These problems can be quite difficult to locate and correct, we recommend you contact a qualified appliance repair technician.
  • Posted on Mar 24, 2009
    • 19 Answers
    SOURCE: bosch fridge freezer - ice build up and water leak from freezer
    could be an air leak around the door seals. put a piece of paper between the door and the freezer if it slides around easly then the seal is leaking air and moisture into the freezer. Also -20 is extream. you could turn the temp up by 10 or 15 degrees and it may solve the problem and so money!
    Posted on Jul 26, 2009
    Why does my freezer build up with ice in the bottom
    is it a frost free model? if it is the defrost timer may be out or the defrost element may be bad. but if this is not a frost free model the door seals may be bad and need replaced
    Aug 24, 2014 | Amana ABB1922FEB (185 cu ft) Bottom...
    My fridg and freezer is cold but not could enough the freezer wont keep food frozen. there is no ice build up, I replaced the defrost timer, and I cleaned the fan in the back what else could it be please...
    Hello Nicole,
    Their are a few things that couldbe causing your refrig.troubles.
    1) their is ice build up in the return air vents that is not allowing air to flow correctly
    you can see the air vents under the crispers in the ref.floor and can see if they
    blocked with ice.
    2) the freezer fan is bad and not circulating cold air into and out of the ref.
    3) In addation to the defrost timer,perhaps the deforst heater and defrost thermostat are bad and frost is building up in the freezer,Do ya see frost
    build up in the freezer??
    GENE
    Sep 21, 2011 | Amana BCI21V1C Bottom Freezer Refrigerator
    I have a Amana Bottom Freezer Refrigerator Model BC20ML that is about 20 yr.s old, works fine except the drain tube from refrig. compartment to evaporator drain pan sames to be plugged. Water and ice...
    You have to remove the bottom drawer, remove one of the drawer slider mounts on the freezer wall, and remove the rear panel. If yours has an ice maker you will have to disconnect it and remove it also. Unplug it so the water valve does not dump water on you while you are working inside.
    Aug 13, 2011 | Amana Refrigerators
    Westinghouse silhouette frost free 522 fridge is not cooling properly top and bottom.freezer fan is still working,and the motor at the bottom in the back of fridge stay's constantly running and has done...
    The heating element, located behind the back plate of the freezer, is probably not working. A failed heating element leads to a build up of ice around the evaporator coils in the rear of the freezer. If the back plate of the freezer is removed (ONLY DO THIS WITH THE APPLIANCE UNPLUGGED FROM THE POWER SUPPLY) and there is a large build up of ice around the evaporator coils then it's a fairly good indication that the heating element is not working. The heating element comes on periodically to defrost/de-ice the evaporator coils. Heating element is often activated by a small timer switch which turns the heater on for a set time every 24 hrs or so. Heating element may be open circuit or timer switch may not be operating. Most likely to be open circuit heating element.
    Jan 01, 2010 | Westinghouse Refrigerators
    Freezer building up with frost
    Sounds like the defrosting system has a faulty timer/board, faulty heating element or bad electrical connections to these components.
    More info, let me know...
    Charlie
    Aug 23, 2009 | Amana 22.6 cu. ft. Side-By-Side...
    Leaking kenmore side byside Refridgerator . It seems to leakout the freezer door side. Ice builds up at the bottom or floor of the freezer.
    If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
    You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model when ice is gone take back cover off find drain hole and clean
    Aug 14, 2009 | Refrigerators
    Thick layer of ice has formed at bottom of freezer. Cannot even pull out the bottom basket
    If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, ie defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
    Aug 13, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
    My in-laws Amana ATB1832AR Top Freezer has stopped cooling. It was purchased 7/1/2005. Is there an inline fuse for the compressor that may have gone out?
    Aug 13, 2009 | Amana ATB1832AR Top Freezer Refrigerator
    Jan 21, 2009 | Amana Refrigerators
    Refrigerators Logo
    96 people viewed this question
    Top Amana Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
    Dan Webster
    Dan Webster
    Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
