Question about Samsung SCX-4100 All-In-One Laser Printer
SAMSUNG SCX 4100 PRINTER POWERD ON THEN DISPLYED BY THIS LSU OR PSU ERROR ?
Samsung Printer SCX-4100 LSU Error
Laser Scanner Unit or LSU is what writes to the surface of the drum. The glass above the cartridge in the machine may be dirty. The mirror motor in the LSU could be bad or needs to be cleaned to spin better. The Laser diode may be faulty.
This is not a user-serviceable issue. You will need to contact Samsung for service. You can do it online via Samsung website or contact the vendor to see who will they appoint to service the printer to, especially if it is still under warranty.
Jan 27, 2011 | Samsung SCX-4100 All-In-One Laser Printer
Lsu error
This is not a user-serviceable error. You will need to contact Samsung for service. You can do it online via Samsung website or contact the vendor to see who will they appoint to service the printer to, especially if it is still under warranty.
Jan 12, 2011 | Samsung SCX-4100 All-In-One Laser Printer
Lsu problem samsung printer 4100 series plese solve mathod
What is problem ? your printer.Send me any error code or cause.I should help you because i am a expert in Samsung.
Jun 24, 2010 | Samsung SCX-4100 All-In-One Laser Printer
LSU ERROR
i have a Samsung all in one Laser printer, its shows me LSU Error when i am going to print any document or if i want to make copy.so can u tell me how can i solve this problem
Dec 23, 2009 | Samsung SCX-4100 All-In-One Laser Printer
Printer scren displyed by LSU OR PSU ERROR PRINTER POWERD ON THEN SEE THIS ERROR ?
Dear Sir, Welcome to fixya, The most likely cause for this error is the (LSU). Shut off your copier and let it rest for 10 minutes.. and turn back on,It may solve your problem if it is not solves your problem may be Laser Scanner Unit dead & it cannot be repaired, parts are impossible to find. Unfortunately there is no real alternative to replacing the LSU. I think it helps.If you have any confusion regarding this issue leave a feedback we will glad to assist you. Have a Nice Day!
Sep 29, 2009 | Samsung SCX-4100 All-In-One Laser Printer
Have lsu error also.
Hi ...
LSU stands for Laser Scanner Unit ... you normally get 2 different kind of errors with LSU ...
LSU Hsync or LSU Motor Error ...
If you get this error, it means that the Laser Scanner Unit has gone bad and the only way to get it fixed is to get the printer repaired ...
Cheers ....
Jul 28, 2009 | Samsung SCX-4100 All-In-One Laser Printer
LSU Error
Bad Laser Scanning Unit. Uneconomical to repair. Sorry.
Jan 22, 2009 | Samsung SCX-4100 All-In-One Laser Printer
Error LSU
The LSU error stands for Laser Scanner Unit error. The probable cause/s:
The Polygon motor in the LSU does not rotate.
The LSU’s laser beam is functioning properly.
What you can do:
Try to unplug the machine for a couple of minutes or maybe a little longer and then plug everything back in. Power on and then test.
Jul 03, 2008 | Samsung SCX-4100 All-In-One Laser Printer
Lsu error pour samsung scx-4100
Please kindly help me to sole the problem Lsu of my printer samsung scx-4100
thanks
Jan 25, 2008 | Samsung ML 1610 Laser Printer
Samsung SCX-4100 All-In-One Laser Printer Logo
101 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
