Question about Mitsubishi WS-55819 55" Rear Projection Television
Mitsubishi 55" rear projection TV, wouldn't turn off
Wouldn't turn off with remote or at set. Also couldn't change volume. Unplugged set, now it won't turn on. Reset button produces flashing green light on panel, but still won't power on.
  • 115 Answers
Um . that model doesn't have a reset button . but if no lights on front of the set even blink when you press the power button on the front or on the remote .then suspect front panel buttons ,with that model.
Posted on Sep 29, 2009
MITSUBISHI WS55907 Diamond 1080 TV bought in 2000 was powered off, unplugged, for a year. Turned the set on with remote last night and worked fine, had very crisp picture.
Your TV was waiting between 2000 and now to suffer power supply failure. It is very frustrating to go from everything working perfectly to nothing.
Oct 31, 2016 | Mitsubishi WS-55907 55" Rear Projection...
MITSUBISHI WS-55315 WON'T TURN ON WITH REMOTE OR START BUTTON
do the self check and find the error code if set shows power and then goes total dead shortly after.
May 02, 2012 | Mitsubishi WS-55513 55" Rear Projection...
My Mitsubishi Medallion tv stays on for about 10 minutes and then shuts down and won't turn back on until a period of time has passed. It is a rear projection tv about 9 years old. Can anyone help ex
When it shuts off and the green power light goes off, press both the menu and input buttons on the front of the set (not the remote) and hold both for about five seconds and release.
Power light will blink a two digit error code like 2 blinks and then 3 blinks and repeat it several times.
What is the error code?
Nov 14, 2011 | Mitsubishi WS-55819 55" Rear Projection...
Volume increases to 30 can't turn down
I don't have a solution but if you take off the speaker grille on the front of the set and see two ribbonish cables, unplug the smaller one. The volume will not increase anymore but you cannot use the controls on the front of the tv and the power light will not show green anymore. You can however use the remote to do everything on the set that you would normally do. Hope this helps until I find a real solution.
Sep 05, 2009 | Mitsubishi WS-55511 55" Rear Projection...
WS-55511 55in volume turns up by itself & can't switch devices
The remote is not the problem. The switch for volume up on the control panel has become leaky. Very common problem for this generation Mitsubishi. If you don't mind not having the control panel working you can disconnect it and the set will work just fine with the remote. To disconnect the control panel pull the speaker grill, it just snaps off, and remove the front access panel. Once that is done you'll see a cable going to the switches just disconnect it.
Nov 23, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Have sound but no picture at all... not even the channel indicator or only visual using the TV remote. Don't projection tv's have 3 bulbs (blue/green/red)? if one burns out, wouldn;t the other two still...
Its definitely not the CRTs. More likely a problem in your deflection circuit Horizontal or vertical. Could be the vertical output as well. your not getting deflection if you don't have any menu or channel indicator.How are your trouble shooting and soldering skills?Let me know if I can help you further.
Jan 22, 2008 | Mitsubishi WS-55711 55" Rear Projection...
Mitsubishi remote and control panel issue
Did you ever resolve this problem and if you did, what was the fix? My same tv just got out of warranty and I have the same problem. Thanks.
Nov 22, 2007 | Mitsubishi WS-55813 55" Rear Projection...
WS-55908 remote control
Take out the batteries or simply reprogram the remote by using the manual search function on the remote. There is probably a couple of different settings in the remote for this type of TV set, Good Luck
Jul 02, 2007 | Mitsubishi WS-55908 55" Rear Projection...
Mitsubishi WS-55819 55" Rear Projection Television Logo
122 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
