Question about Western Digital My Book Essential 320GB External USB 2.0 - WDH1U3200N Hard Drive
I DON{T KNOW THE SPECIFICATIONS FOR THE POWER SUPPLY CORD,I LOST IT, I NEED TO KNOW THE VOLTAGE IN
  • 63 Answers
12V, www.ebay.com, item # 280362473044
Posted on Sep 29, 2009
  • 90 Answers
It is 12 volt
I misplaced the power supply and need to find another but don
look at the specifications of the old power supply in the manual or on a sticker on the back of the unit. It should give a DC voltage and an amp value. Get any power supply that has the same DC voltage and same or slightly higher amp rating.
Oct 23, 2012 | PANDIGITAL (DPF802) Digital Picture Frame
My red standby light is off, checked the cord, had a power surge recently?
Good day.
This is the D.I.Y steps for troubleshooting.
  1. Open the back cover of your TV by removing all screws.
  2. Power ON the TV to perform a voltage data.
  3. Check the input voltage of power supply.It should have a 120 or 240 volts ac depends on the voltage supply from your power source.If none replace the power cord or check the main source.
  4. If you have input voltage in the power supply,check the output voltage on the power supply.It should have 5vdc,for the system board,12vdc,for the sound and 24vdc,for the back-light inverter.
  5. If you don't have output voltage from power supply board.Unplug the power cord first to check the fuse if busted,check some transistors and diodes if shorted,check some open/change value resistor and also look for leak/bulge on top capacitor.
  6. If you found any of the defective parts that mention on the step # 5 replace it with the same type and ratings.
  7. After that,try plug-in again the power cord then test the output voltage that mention on step #4.
Thank you for using FixYa and good luck.I hope this solution helps you.
Apr 18, 2011 | iLO V27DMBX Television
No power even if I plug my DVD to power source
Good day.
Follow this procedure for trouble shooting.
  1. Remove the cover of your DVD player.Loosening all screw.
  2. Check the input voltage of the power supply 220v/120v AC.If don't have input supply that comes from the ac cord,replace it.
  3. If you have a input voltage supply comes from the power cord.Check the output voltage of the power supply such as 5vdc and 12vdc.
  4. If the you don't have output voltage from the power supply.Check the fuse if busted,check open/change value of capacitor,check power transistor (regulator)if shorted and leak/bulging top capacitor of the power supply board.If you found any defective parts replace it.
  5. If you have output voltage comes from the power supply.The problem could be the main board,replace it.
  6. If you already done this procedure,test it by power ON the DVD player.
I hope this information will be helpful.Thank you and good luck.
Apr 17, 2011 | LG Televison & Video
My printer will not come on at all. i have the adapter in to the wall jack but nothing happens. i have checked to ensure the wall jack works.
Solution one: Make sure the electrical outlet works
Unplug the power cord from the electrical outlet.
Plug another appliance into the electrical outlet to make sure the outlet works.
If the electrical outlet does not work , plug the product into another outlet that does work.
If the electrical outlet works, but the product still does not turn on , continue to the next step.
Solution two: Make sure the power supply is compatible with the HP product
The term power supply refers to both the power module and the power cord.
NOTE: To make sure that your product and power supply are compatible, HP suggests you use the original power supply shipped with your product.
Example of a power module Example of a power cord
NOTE: The power module might have a permanently attached power cord, or the power cord might detach from the power module.
Make sure the voltage and amperage specifications printed on the power supply match the voltage and amperage specifications printed on the HP product.
Voltage and amperage specifications printed on the power supply Voltage and amperage requirements printed on the HP product
If the voltage and amperage specifications between the product and the power supply are compatible, make sure the connector on the power cord is the same shape and color as the connector on the HP product.
WARNING: Do not force a power cord into an HP product that is incompatible with the HP product (different shape or size).
If the power cord is not compatible with the product, replace the power cord with a compatible cord. To buy a compatible cord, right-click the following link, How to Buy HP , and then click Open in New Window .
If the power cord is compatible with the product, but the products still does not turn on, continue to the next step.
Solution three: Reset the power module and test the power
Step one: Reset the power module
The power module has a safety feature inside that protects the product during a power surge. If you experienced a recent power surge, the power module might need to be reset. Use the following steps to reset the power module.
Unplug the power supply from the rear of the product.
Unplug the power cord from the electrical outlet, power strip, or surge protector.
If the product uses a power module with a detachable power cord, disconnect the cord from the power module.
Wait 15 seconds.
Reconnect the power cord to the power module.
Plug the power cord back into the electrical outlet. Do not use a power strip or surge protector.
Check to see if the power module has an LED.
If the power module does not have an LED, continue to the next step.
If the power module has an LED, check to see if the LED lights up.
If the LED does not light up, contact HP to replace the power module. To buy a compatible power module, right-click the following link, How to Buy HP , and then click Open in New Window .
If the LED lights up, continue to the next step.
Step two: Test the power on the All-in-One
Follow these steps to test the power on the product.
Reconnect the power supply to the rear of the product.
Press and quickly release the Power button to start a Power On/Off cycle. Do not hold the button down.
Figure 1: Press and quickly release the Power button
If you press and hold the Power button too long, the product might turn on and then off without restarting. If this happens, press and quickly release the Power button again.
If these steps resolved the issue , there is no need to continue troubleshooting.
If the issue persists , see the next step.
Solution four: Test the power with a compatible power cord from a different product
If you have another available power cord that is compatible with your product, use the alternate cord to repeat the steps in Solution three: Reset the power module and test the power .
If the product turns on with the alternate power cord, the original power cord caused the issue. Contact HP to replace the power cord. Right-click the following link, How to Buy HP , to buy a compatible power cord.
If the product does not turn on with the alternate power cord, continue to the next step.
Solution five: Service the HP product
If you have completed all the preceding steps and are still experiencing a problem, service the product.
Mar 26, 2011 | HP PSC 750 All-In-One InkJet Printer
Can not get hp 1210 to start -power is getting to machine but it will not start..
  1. Unplug the power cord from the electrical outlet.
  2. Plug another appliance into the electrical outlet to make sure the outlet works.
    • If the electrical outlet does not work , plug the product into another outlet that does work.
    • If the electrical outlet works, but the product still does not turn on , continue to the next step.
  1. Make sure the voltage and amperage specifications printed on the power supply match the voltage and amperage specifications printed on the HP product. Voltage and amperage specifications printed on the power supply Voltage and amperage requirements printed on the HP product c01962881.gif c01962212.gif In this example, the voltage (+32 V) and the amperage (2000 mA) from the power supply is compatible with the voltage and amperage specified on the HP product.
  2. If the voltage and amperage specifications between the product and the power supply are compatible, make sure the connector on the power cord is the same shape and color as the connector on the HP product. WARNING: Do not force a power cord into an HP product that is incompatible with the HP product (different shape or size).
    • If the power cord is not compatible with the product, replace the power cord with a compatible cord. To buy a compatible cord, right-click the following link, How to Buy HP , and then click Open in New Window .
    • If the power cord is compatible with the product, but the products still does not turn on, continue to the next step.
Solution three: Reset the power module and test the power Step one: Reset the power module The power module has a safety feature inside that protects the product during a power surge. If you experienced a recent power surge, the power module might need to be reset. Use the following steps to reset the power module.
  1. Unplug the power supply from the rear of the product.
  2. Unplug the power cord from the electrical outlet, power strip, or surge protector.
  3. If the product uses a power module with a detachable power cord, disconnect the cord from the power module.
  4. Wait 15 seconds.
  5. Reconnect the power cord to the power module.
  6. Plug the power cord back into the electrical outlet. Do not use a power strip or surge protector.
  7. Check to see if the power module has an LED.
    • If the power module does not have an LED, continue to the next step.
    • If the power module has an LED, check to see if the LED lights up.
      • If the LED does not light up, contact HP to replace the power module. To buy a compatible power module, right-click the following link, How to Buy HP , and then click Open in New Window .
      • If the LED lights up, continue to the next step.
Step two: Test the power on the All-in-One Follow these steps to test the power on the product.
  1. Reconnect the power supply to the rear of the product.
  2. Press and quickly release the Power button (c01602202.gif ) to start a Power On/Off cycle. Do not hold the button down. Figure 1: Press and quickly release the Power buttonc01896071.gif c01733891.gif If you press and hold the Power button too long, the product might turn on and then off without restarting. If this happens, press and quickly release the Power button (c01602202.gif ) again.
  • If these steps resolved the issue , there is no need to continue troubleshooting.
  • If the issue persists , see the next step.
Solution four: Test the power with a compatible power cord from a different product If you have another available power cord that is compatible with your product, use the alternate cord to repeat the steps in Solution three: Reset the power module and test the power .
  • If the product turns on with the alternate power cord, the original power cord caused the issue. Contact HP to replace the power cord. Right-click the following link, How to Buy HP , to buy a compatible power cord.
  • If the product does not turn on with the alternate power cord, continue to the next step.
Solution five: Service the HP productIf you have completed all the steps listed above and are still experiencing a problem, service t
Dec 01, 2010 | HP PSC 1210 All-In-One InkJet Printer
Printer will not power on
Check that the corded power supply is plugged into a live receptacle. Verify by using a lamp with a light bulb to see that it lights before plugging power cord into the wall.
Check that the connection at the printer is ok.
Push the power button, and if nothing happens, you might have a bad transformer either on the cord or in the printer itself, depending on the design.
One can double check by getting a spare power supply transformer or cord and trying it.
Or else, a multimeter should show the voltage printed on the power supply or printer. Check that the voltage is within specifications when plugged into the wall whether it is AC or DC voltage.
Jul 04, 2010 | HP Office Equipment & Supplies
There is no power to my router. how do i know if i need a new power cord or if it is defective unit. 2wire 1800HG older model
You can measure the power cord voltage with a voltmeter. The specifications, and voltage output are on the transformer, or modem body. If you don't have a voltmeter, you can take the power supply into Best Buy, Radio Shack, or any computer shop, and they'll measure it for you. If the voltage is ok on the power supply, chances are you have a bad modem, in which case you'd be better off getting a new one. Hope this helps.
May 14, 2010 | 2wire HomePortal 1800HG Router...
Lost power supply
If the desktop charger is the version that can accommodate two radios simultaneously similar to the T5000, then the AC wall adapter or the power supply is 9 volts AC.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 26, 2008 | Cobra Radio Communications
Western Digital My Book Essential 320GB External USB 2.0 - WDH1U3200N Hard Drive Logo
634 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
