Question about Texas Instruments TI-83 Plus Calculator
Find the 5-number summary of the data set. Note that these are the last 5 numbers given to you in 1-var stats. Find the max and min data entries that lie within the fences (if there are outiers) If there are no outliers, use the original min and max data entries. ------------ Question? If I have 10 different number like: 28, 56, 27, 0, 82, 34, 14, 09, 24, 35 Can I put this into my calculator and pess a button that would put in ascending order? This is an easy set of numbers. most of the time we are given 15 to 30 sets.
  • debrah_clark Sep 29, 2009
    Yes, it does. So, I have to do it the long old fashioned way. I have been.
  • 8,197 Answers
I do not know of a button on your calculator that will do this but spreadsheet software (such as Excel) allows this to be done by placing all numbers in a single column and using the
sort ascending' function.
I hope this answers your question.
Good Luck
Posted on Sep 29, 2009
Multiple operations in single command on new TI84
Run SetUpEditor to restore the list names L1, to L6
100->dim(L1) to set the dimension of L1 to 100
100->dim(L2) to set the dimension of L2 to 100.
Since you are going to store the random numbers in L1, you should use L2 as the FreqList. All elements of L2 should be 1. When you create it all its elements are 0. One way to fill it with 1's is 10 run the command
L2+1>L2; Add 1 to each number and store the results in L2 (overwrite the 0 values)
Perform a blank run of 1-var Stats to get the chance to set the default lists.
1-var Stats L1, L2 ENTER
Type in your command
randNorm(64.5,2.5,100) STO> L1:1-var Stats L1, L2 ENTER.
Use the Catalog to type in the 1-var Stats commnad so that you can type in the Lists L1 and L2 without opening the 1-var Stats configuration screen.
Do what you have to do with the statistics you generated.
To rerun the two commands again, press [2nd][ MODE] to (QUIT)
or press the sequence [2nd][ENTER] to have the last (ENTRY) echo on the main screen. Press ENTER to run again
Hoe it helps.
Jan 13, 2012 | Texas Instruments TI-84 Plus Calculator
How do i calculate the standard deviation
for 1-Var statistics
Press [MODE][3:STAT] [1:1-VAR]. You are ready to enter values in the X column.
Enter a number and press [=]. Cursor jumps to second number to enter.
Keep entering numbers and pressing [=] till all numbers are in. Press the [=] key after the last one.
Press [AC] key to clear the screen.
Press [SHIFT] [STAT] (above digit 1.) then [5:Var]. Screen displays the statistical variables 1:n ;2: x bar; 3: x sigma n; 4:x sigma n-1.
Press the number corresponding to Referable you want, ex 1:n . The variable appears on screen. Press [=] and it will be displayed.
To display another variable press [SHIFT][STAT][5:Var][ 1,2, 3, or 4] .
To access the sum of squares sigma x^2 and the sum of data sigma x press[SHIFT][STAT][4:SUM] then [1: for sigma x^2] or [2: for sigma x]. Press [SHIFT][STAT][6:MinMax] to access minX and maxX.
For 2-var statistics
To perform 2 variable statistics you press [MODE][3:STAT] and any of the other regression options (except 1:1-Var). A two column template opens where you enter the X and Y values. When finished entering data, press [SHIFT][STAT][5:Var]. to access the different statistics. you should be able to recognize what each variable means.
Oct 26, 2011 | Casio fx-300ES Calculator
I need to be able to do standard deviation
TO COMPUTE STANDARD DEVIATION AND 2-VAR STATISTICS.
I assume you know the theory. I will show you the key strokes
For 1-Var statistics
Press the number corresponding to the statistical value you want, ex 1:n . The variable appears on screen. Press [=] and it will be displayed.
To perform 2 variable statistics you press [MODE][3:STAT] and any of the other regression options (except 1:1-Var). A two column template opens where you enter the X and Y values. When finished entering data, press [SHIFT][STAT][5:Var]. to access the different statistics. As I assumed above, you should be able to recognize what each variable means.
Apr 18, 2011 | Casio FX-115ES Scientific Calculator
How do you find the standard deviation?
Feb 16, 2011 | Casio FX-115ES Scientific Calculator
HOW TO SOLVE STANDARD DEVIATION PROBLEMS
Here it is.
Feb 02, 2011 | Casio fx-300ES Calculator
Cant figure out how to do standard deviation on this calculator
Jan 12, 2011 | Casio FX-115ES Scientific Calculator
How to calculate standard deviation in casio fx 115es
Nov 12, 2010 | Casio FX-115ES Scientific Calculator
How do u find standard deviation using this calculator?
Oct 25, 2010 | Casio FX-115ES Scientific Calculator
Standard deviation
Here it is.
Oct 07, 2010 | Casio fx-300ES Calculator
Aug 27, 2010 | Casio FX-115ES Scientific Calculator
Texas Instruments TI-83 Plus Calculator Logo
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
