Question about Zenith R56W36 56" Rear Projection Television
Zenith r56w36 56 in
I accidently pressed the auto convergence button and now I have a 3d look with more than 2-3 colors. please help. mikeamad@hotmail.com
  • 3 more comments
  • apple crisp Feb 21, 2008
    My Zenith, r56w36, experiencing same problem. red,blue,and green colors on screen. Do I need a part to fix it? Where do I get an auto converge module/panel? Thank you. djcjedi@yahoo.com
    My Zenith, r56w36 is messed up with red,blue, and green colors. It did not help by pressing the auto convergebutton. Do I need a part? Where do I get an auto Converge module/panel? Thank You for helping. Djcjedi@yahoo.com
  • rudy79 Jul 18, 2008
    I did the same thing and hit the wrong botton on the remote. Now the screen has 3 different colors and a 3D effect. What can I do to fix it.
  • vinniedred Jul 29, 2008
    Ialso hit the auto convergence button and my TV has the 3D look. CAN this problem be fixed?
  • Little apper Nov 07, 2008
    I have the same problem
My picture was fine but I had just got cable and wanted to make sure the picture was right. So I hit the auto convergence and now I have a 3 D look. I have never had any problems prior to this. What can I do? and what was is the problem? Thanks
Posted on Sep 20, 2008
I accidently pressed the auto convergence button and now I have 3d look with more 2-3 colors. please help. aced 57 @comcast.net
Posted on Sep 02, 2008
  • jack299 Dec 27, 2010
    I have the same problem and looking for an answer.
Auto convergence will not adjust the colors
This is a common problem. Its called a convergence failure. You can get all the parts from www.TvRepairKits.com
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 20, 2011 | Zenith R57W46 57" Rear Projection...
We have a Zenith 56 inch rear projection tv. Model num# R56W36. The picture did the 3-D thing on us when I hit auto-convergence button. We ordered new parts from TVRepairKits.com. Replaced parts and now TV...
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
•Screen looks 3D
•Colors don't line up
•One or more colors can't be adjusted when using the convergence menu.
•Screen is bowed or warped.
•TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems
9e1b49a.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
Aug 22, 2010 | Zenith R57W46 57" Rear Projection...
Iqc60h95w zenith=hitachi i can set up convergence but when i press swits on the main board to retorne the picture the convergence wont stay on memory.witch butons on the remote i have to press before press...
Projection TV2_bing.gif sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung2_bing.gif, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith2_bing.gif, and others. You can get a convergenece repair kit from the link below.
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash2_bing.gif focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Jan 01, 2010 | Zenith IQC60H95W 60" Rear Projection...
I pressed the auto convergence button now it looks like its in 3d
  • Screen looks 3D
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 16, 2009 | Zenith R57W46 57" Rear Projection...
I have a wavy 3d looking screen with weird colors
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 16, 2009 | Zenith R56W36 56" Rear Projection...
Zenith r56w36
Unless you can do TV repair your out of luck on this one! Replace your convergence board or ship it for repair cheapest way.You must remeber to connect board exactly the way it hooks up , convergence board has 2 ics on it STK392-120 these ics go bad all the time and when you press auto they quit working.If you need any more help let me know. ThankYou for using FixYa. Have a Nice Day.
Feb 07, 2008 | Zenith R56W36 56" Rear Projection...
Convergence 3D
You have to try auto convergance from the menu.
There ust be convergance adjustment on menu.You will find cross at center of the screen.green cross is the refrance ,you have to overlap red and blue to form white cross.
once you have formed white cross than the picture will be perfect.
Jan 09, 2008 | Zenith R56W36 56" Rear Projection...
3d effect
Sounds to me like your convergance amps are on their way out...
Nov 21, 2007 | Zenith R56W36 56" Rear Projection...
Zenith R56W36 covergence problem
you will need to replace conv ic's then auto converge..
Oct 19, 2007 | Zenith R56W36 56" Rear Projection...
Zenith R56W36 56" Rear Projection Television Logo
333 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
