Home | Sharp | AL 800 Grayscale Copier | The indicator is fla...
Sharp AL 800 Grayscale Copier
Problem for Sharp AL 800 Grayscale Copier
The indicator is flashing H and then 3, the
By goolagil on Sep 29, 2009
The indicator is flashing H and then 3, the machine seems to be lock up.
Solution #1
posted on Oct 03, 2009
Not Rated)
copydoki
Rank: Wiz  Sharp Office Equipment  Expert
Rating: 80%, 113 votes
The Triac in the fuser unit is in shortcircuit,and the heat roller abnormally high temperature.Change the damage part and clean the others.
Was this helpful?
Yes
No
Popular Solutions for Sharp AL 800 Grayscale Copier
Questions and Unsolved Problems for Sharp AL 800 Grayscale Copier
Do you recommend Sharp AL 800 Grayscale Copier?
Answer
Answer
I have a Lanier hand held cassette tape recorder model AL/C II.It has a built in mic or you can plug... (More)
Answer
need a repair service for lexmark copier houston texas zip code 77029 the zip in 77045
Answer
text comes out fuzzy and unreadable
Answer
The copy has several big strips of ink in the middle
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sharp AL 800 Grayscale Copier:
Top Copier Experts
Rank: Guru Guru
Solutions: 709
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more Copier Experts
Top Copier & Fax Repair
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
