Question about LaCie Design by F. A. Porsche 160 GB Hard Drive
My external hard disk produces a hissing sound after connection then stop and the light does not show anything.It is not recognized in the computer, how can i recover data
  • 3,153 Answers
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
Posted on Sep 29, 2009
  • 329 Answers
It seems that disk has physically damaged. try some data recovery software.. http://www.dataclinic.co.uk/data-recovery-external-disk.htm
try this link may help you...good luck and do reply
My hard-disk is on-Warrenty basis.On hardisk light is blinking but unable to detect on pc ,So Please tell me the procedure how to recover my data. P/N-WDBAAA5000ABK-00 S/N-WXM1A80N4025N
Can you hear the drive spinning when you connect it to your computer? A spinning sound means your external drive is being powered by the USB from your computer - there are several reasons the drive is not being recognized.
If you are not hearing any spinning sound the drive could be damaged.
Does the drive get recognized by any another computer? If yes - check disk management and see if security is enabled on the drive. Also - check to see if there is a drive letter assigned to your external hard drive.
Link
Feb 28, 2011 | Western Digital WD Passport 250GB Portable...
My computer wont recognize my external hard drve and the io magic light is blinking
Try connecting the external hard-drive to a different computer. If it still fails, and it is still under warranty, then exercise the warranty to get it replaced.
If the warranty has expired, open the case, and remove the disk-drive, disconnecting it from the USB-to-disk-drive adapter.
Connect the disk-drive as a "slave" disk-drive in some desktop computer, to see if the disk is recognized.
If it is, then the USB-to-disk-drive adapter has failed, and you could go to any computer-store to buy a new external case and adapter, and mount your disk-drive inside the new case, and work with your files.
If the disk-drive is not recognized, check the warranty on the disk-drive itself.
Jun 24, 2010 | IO Magic Corporation GigaBank (I250HD35)...
External hard drive is not detected
Check Following Instructions:
1. Check your USB cable properly connected to the computer.
2. Go to My computer - right click on property - Hardware - Devices Manager - in below - USB Mass storage device - right click on this - and Uninstall - then again right click - click on Scan - it should be reload your USB drivers
your External Hard Drive will be detected
Apr 25, 2010 | Seagate USB 2.0 External Enclosure + 400GB...
External hardrive not recognized
Try a different cable between the computer and the drive.
Disassemble the casing, and remove the "internal" disk-drive.
If the USB-to-disk-drive adapter has "died", it's possible that the
disk-drive itself is intact, and your data will be intact.
Connect the "internal" disk-drive as a "slave" drive in a desktop computer, and see if it can be detected.
If it's dead, and it's still under warranty, then exercise the warranty.
Jan 04, 2010 | Acomdata 1TB Puredrive USB Esata 1 TB Hard...
Can't install external hard drive. Do not have disc or manual. When I connect drive to USB port, drive lights up and makes sounds, but does not show new hardware.
Most likely the drive hasn't been initialized. Go to start, right click my computer, then manage. Select disk management on the right column. A window should immediately pop up saying disk initialize wizard. Press next, and it will guide you through on how to initialize the disk. Make sure you format it as well, so that the computer will recognize it as a drive.
Dec 29, 2009 | Maxtor OneTouch III Mini Edition 120GB...
Vista stops recognizing external hard drive
This doesn't sound like an OS issue. This appears to be more an issue of the connection to the hard drive. The USB cable likely isn't the culprit, nor the laptop USB inputs. If the drive was ever dropped or the cable gets removed and reattached often to the actual enclosure, you might be looking at a bad port on the enclosure. This isnt a lost cause. You can always buy a hard drive enclosure from newegg and move the drive from the IOMEGA to the new enclosure. You can get a new enclosure for $15. Just because the USB port is bad, it doesnt mean the data is gone and the hard drive cant be used.
Aug 26, 2009 | Iomega 33089 250 GB Hard Drive
I used my usb hard disk but I cannot access it
Try it on another USB and if no luck on another computer. If another computer recognizes it try reinstalling your chipset drivers.
Apr 19, 2009 | Western Digital 250GB MyBook External USB...
Beyond micro mobile disk BMMDU2 is not recognized
The drive USB interface may be damaged; an external case is available form various vendors for about $20. The drive should pop out and into the new case. If still not recognized, then the ID track on the drive may be compromized - that can happen if the USB is unplugged while it is still writing to the drive. There is drive recovery software out there, like EASEUS that works quite well (they have a demo that you can try free) to see if that would work.
Apr 18, 2009 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
My external hard drive is unreadable
Does you drive make any sounds like these? If yes you have a mechanical problem and you should get a specialist to work on it. If not - try to remove the drive from USB casing and connect it directly to your PC or put into another USB enclosure. This should help if the problem is with the enclosure itself and not with the drive.
Dec 30, 2008 | Seagate FreeAgent Pro 1TB External USB...
Computer does not recognize new 1TB ext HD
First I had to reseat one of the drives which had worked loose and become unseated during shipping. Then I had to format the hard drive and finally I had a 1TB external hard drive I could use. The light is still red.
Jul 31, 2008 | Cavalry Storage Cavalry CADB001U32 1TB...
LaCie Design by F. A. Porsche 160 GB Hard Drive Logo
819 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
