Rank: Guru
Rating: 85%, 124 votes
I use one of the graphing APPS or do through a program. I have a users manual for TI 84 silver Edition that shows you how to archive\ unarchive to run programs here at this site. Usually, I tell people to just forget about the programs and use the simple concepts so, that they could operate their calculator better. But, if you notice in those program are actually more powerful than the programs you get on the web, because I wrote them to be flawless, or I only used programs that I knew would not clash and were very well written. Won't y1=(2/5)x-(11/5) and -3x+8 work?
Comments:
Sep 29, 2009
- That might not work. I load my Ti 84 to a student so, I can't test. But, I know there is APPS, and programs that well, even though be real care what you download from the web. Ticalc has some bad programs but, won't they won't crash you as hard as some of the other site.
Sep 29, 2009
- Here better yet!
I have a program from this site 5 years ago. I can't seem to find it on a web search, maybe you'll have better luck.
Try doing a search in ticalc.com for. You may find other programs too.
henkshoeke.com/English/revolxas.htm
Sep 29, 2009
- If you can find a program name Bigslope.8xp is a real powerful program that will allow multiple graphs. HGGPFRAC.8xp is a very good pratial fraction program too. I know it is in ticalc.com
Sep 29, 2009
- I know that equation will work. you just have to set it up right. You just have to set it up using While or some other boolean function.
Sep 29, 2009
- There's a way to do exactly what you want and I gave really have given it to you and you can see it see. Did you try putting a , between them both?
Sep 30, 2009
- Try using the when( command. I'll download a simulator and solve this for you. I know there's away to do it because we were doing it in out Calc 2. So don't lock me out.
Sep 30, 2009
- That makes me think of other ways too. I only wished Ti 84's were as forgiving as the Ti 89's. That is a good idea now lets prove it with the Ti84.
Sep 30, 2009
- Even if you do get the Ti 84 calculator to do both equations on the same line it is not going to be completely simatenuosly. It will draw a little bit of one of the equations and then a little bit of the other. It is not going ot be simultaneous. Do you still want the y1=when(2/5)x-(11/5)... , -3x+8...) solution? I know it don't work in the form it is. But, it will when I finish getting the proper set up, if you don't know already. Please post a comment on exactly what you wish done. It will help in arranging the proper solution.Sep 30, 2009
- I bet these newer OS won't allow you to do this.I think that is why were being asked all the time to do it.Oct 01, 2009
- See if you use Y1=while x<1 (2/5)x-(11/5),... and while x<1... -3x+8 you just expand it!
Oct 01, 2009
- I have already answered this question. You can't graph at the same time because, it will do one a little bit and then stop. Then it will graph the other line a little bit, and stop. Just keeping going back and forth until it is done. Not the same time! Now it will preform slow, and if your memory is loaded you could crash. Why didn't you ask about the isotopes leaving their own center of mass? or partial fractions or my favorite characteristic equations g1 g2 /(1+g2 h2)..
Oct 01, 2009
- You won't graph both at the same time unless, you go to basic, assembler, or C+++, or an APP. Oct 01, 2009
- Does it go back, and forth for you guy's too?
Oct 02, 2009
- How far have you got to making it work? Errors? Do you understand or are you doing the proper procedures?
Oct 02, 2009
- I found another way to do this but, it require assembler and a special character in the command line Y(1)= $
So there is plenty of ways to do it. Hope this helps!
Oct 04, 2009
- This question is the same way. What will work on my calculator will not work on yours. But, I'm sure this will work on any calculator. You just have to have the command structure, mode settings, system variables and assembler programming .
Here's another way I've been doing two equation on one line at the same time.
y1(x)=(2/5)x-(11/5) Actually a place holder
y2(x)=-(3x+8) Actually a place hold
y3(x)=([y1(x), y2(x)])
Crunch the data in program and draw as xy points and draw line enable "at the same time" to display on the graph instead of incrementally done. It operates a lot faster, its not going back and forth wasting time. the trace works better too. You also have to make logical decisions on how your curves flow. But, it would work pretty easily. You just enter equations in the place holders.Oct 04, 2009
- How can I answer this question. The title is to Plot on graph and the question is to use the function graph. I actually turn my data into to plots. I'm not using the system plots. You want plots just plot [y1(x),y2(x)]. Oct 08, 2009
- y1(x)=If or while (x1,0,10..5) then (x2,0,10,.5)
