Question about Sony Cyber-shot DSC-W70 Digital Camera
After a few seconds at power-up the "For use with compatible battery only" message is displayed and then the camera shuts down. Have cleaned contacts, tried 2 chargers and 4 batteries.
  • 1 more comment
  • esteyc Oct 01, 2009
    Two of the batteries (NP-BG1) had worked with the camera. Two new batteries (NP-BG1) also do not work with the camera.
    Just to clarify:
    I did try all four batteries in a new Sony DSC-220 and they work fine.
    I did clean with Q-Tips and Isopropyl Alcohol all battery contacts and those in the camera
    I did examine all battery contacts for potential damage -- there is none visible.
    Three of the Four batteries worked in the camera previously. The Fourth is a third-party equivalent just purchased -- and it works correctly in the new camera.
    All batteries seem to charge correctly -- and work in the new camera.
    I have two Sony Cyber-ShotCameras -- a DSC-W70, which has the problem with all four batteries, and a DSC-200 which is new and works fine with all batteries.
    President:
  • 1,188 Answers
Please make sure that the battery packs you are using are of model number NP-BG1.
Remove the battery pack and wait for one minute. Reinsert the battery and the camera should work. The chargers do not need to be changed. If the problem persists after using the correct battery, take it to a Sony authorized service center.
Visit this link to locate the Sony dealers in your area:
Sony Parts & Accessories Sales
This problem can be caused by a damaged power controller inside the camera. If the repair cost is high, then it is better to consider buying a new camera.
Posted on Oct 01, 2009
Sorry, just a little confused. You mention all the batteries do work including the fourth third-party one. Is the problem then solved? Or does the message still come up?
If it still comes up, do you feel the third party battery might be the issue?
Sorry, just need some more clarification on this.
  • 360 Answers
Try clean contacts of camera for battery and contacts of the battery also, specially the middle one - it is for communication between camera and circuit inside the battery. If the problem persists, try use another battery in your camera, or your battery in other compatible product - you determine this way if the problem is inside the battery (I hope, it is cheaper) or inside the camera.
  • Richard Klein
    Richard Klein Oct 01, 2009
    My camera operates best with those Rechargeables 2500 mAh.
  • Richard Klein
    Yes, but have you ever notice that the positive tip on some of the batteries are flatter. Some devices the flat one's don't touch the metal connector because they hit the out side housing, and can't be used.
  • Sony Master
  • 4,924 Answers
  • Supported Battery Sony NP-BG1
  • Supported Battery 1 x Li-ion rechargeable battery - 960 mAh ( Included )
  • IN THE SPECS..THIS WAS THE ONLY 2 ALTERNATIVE THEY PROVIDE..
  • My opinion is that it has a issue that only allow it to work with this kind of power source ...so ...even if I wanted to suggest to see in the menu if it has a switch for to kinds of batteries...( some camera has... alkaline and....lithium ...choice ) I believe this isnt possible cause its need to be powered first ...
  • so ...try both kind in case it was switched before last shut down ...and also look for those recommended by the manufacturer...cause by the phrase " use compatible batteries only " they make sure and understandable that will not work but with those...
Posted on Sep 29, 2009
Our Marantz SR7400 displays check Pow5 when turned on for a few seconds and then dissapears and unit doesn't turn on. We unplugged it and wated and plugged it back in. Same message. we changed the...
pow5 - your receiver has an internal problem, most likely with power supply unit. As soon as macroprocessor detect the power problem it shuts down the receiver. Check the power supply at first.
Jan 08, 2011 | Audio Players & Recorders
Screen message
Your battery is not making contact with all three contacts, thus making the camera believe you are not using an infolithium battery, creating the error message. Clean the contacts on the camera with isopropyl alcohol and the contacts on the A/C charger.
Apr 18, 2010 | Sony Handycam CCD-TRV608 Camcorder
Kodak EasyShare Z612 Shuts down after taking a few pictures.
Question : What batteries can I use in my digital camera, and how long do they last?
Battery life depends on how you use your camera, the type of batteries you select, and how you handle the batteries.
Your camera is compatible with: KODAK Li-Ion Rechargeable Battery KLIC-8000 and KODAK CRV3 Lithium Batteries: A non-rechargeable battery. (so your battery might be in need of a change)
Using Your Camera
Some features, such as reviewing pictures and using the flash, require more power than others. Follow these guidelines to get the best use of your batteries:
  • Limit the time your camera is in Review mode.
  • Limit your use of the flash.
  • Use the LCD Dimmer or Auto Power Off features, if available on your camera.
  • Transfer your pictures to your computer using a compatible power adapter, camera dock, printer dock, or memory card reader.
  • Check that the latest firmware is installed on your camera. See Software, Driver & Firmware Downloads.
Handling Your Batteries
  • Wipe the battery contacts with a clean, dry cloth before loading it in your camera.
  • When using your camera in temperatures below 41° F (5° C), carry spare batteries and keep them warm.
  • Do not discard cold batteries that do not work; they may be usable when they return to room temperature.
  • Do not allow batteries to touch metal objects, including coins. Otherwise, the batteries may short-circuit, discharge energy, become hot, or leak.
Dec 10, 2009 | Kodak EasyShare Z612 Digital Camera
Camera has failed to operate giving a "change batteries" message
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
Nov 29, 2009 | Canon PowerShot S3 IS Digital Camera
I charged the battery and now I receive the following message on the camera display "for use with compatable battery only" then the camera shuts down.
Make, model?
Some camera's have a setting in the menu, to swich them between, Alkaline, NiMh (Nickel Metal Hydride) and NiCad (Nickel Cadmium) batteries.
Cheers.
Oct 01, 2009 | Cameras
Olympus SP-560UZ "Zoom Error" then shuts down
If you have recently dropped the camera you may have damaged the lens tube (housing). This damage will prevent the lens from moving properly and will cause the camera to shut itself off after a few seconds. If the lens is damaged the camera will require professional repair. If the lens is not damaged, the problem may be battery related. Make sure that you have the correct battery type installed, and that the batteries are fresh/fully charged. If the problem persists, you may have corrosion on the battery contacts inside that camera that is preventing full battery power from flowing to the camera. Remove the batteries and wipe the inside camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sand paper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and reinstall them in the camera. This cleaning solves the problem about 90% of the time, and I hope it works for you.
Sep 14, 2009 | Olympus SP-560 UZ Digital Camera
Compatible Battery error message
Sep 02, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
SONY DSC CYBER SHOT
Aug 17, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
Camera was dropped. Now it will turn on, but after a few seconds, lens begins to move in and out for about 3-5 seconds, then a messag is displayed: Pleaase turn camera off then on again". Doing this r
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 17, 2009 | Panasonic Lumix DMC-LZ3 Digital Camera
Canon G5 Lens error message
Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fix it.
Nov 07, 2007 | Canon PowerShot G5 Digital Camera
Sony Cyber-shot DSC-W70 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
