Question about Dryers
I DONT KNOW HOW TO PUT THE BELT BACK ON THE MOTOR AND TENSIONER PULLEYS ON MY HOT POINT DRYER MOD. # NBXR453EVOWW
  • 304 Answers
The diagram at the link will guide you in proper belt installation:
Dryer belt Configuration
Posted on Sep 29, 2009
    Genius:
  • 1,461 Answers
First slip the belt over the drum, Then to the middle of the motor pulley lastly pull on the Two jockey pulleys, Quite sore on the thumbs, I m sure you will manage it..good luck
NEED TO PUT THE DRUM BELT BACK ON ASAP
The other pulley is spring loaded it puts tension on the belt.
Pull the pulley back and the belt will slip ight over then release the tension pulley and your done!
Apr 17, 2014 | Haier HLP140E Electric Portable Dryer
Dont know how reeve the belt around the drum the belt is two slack
From the rear of the dryer the back of the belt has to be on the right side of the idler pulley, then around the motor pulley. If the back of the belt is against the left side of the pulley looking from the rear the belt will be too long, not enough tension.
Oct 29, 2010 | Dryers
I have an older kenmore 70 series dryer. the belt broke and im trying to figure out where the pulley is supposed to go and how the belt is supposed to go
If you are referring to the tension pulley that keeps the belt tight on the drum, it is common for it to come loose when the belt breaks because there is no longer any tension holding it in place. Just follow these steps to reinstall:
1. Make sure the drive belt is looped around the dryer drum with the groove side facing the drum. (Try to line the belt up with the wear marks already on the drum).
2. With the tensioner in your left hand, insert the clip end of the idler pulley into the grooves on the dryer bottom casing with the idler wheel pointing to your left. (The grooves are directly in front of the drive motor.)
3. While holding the tensioner in place with your left hand, insert the belt UNDER the wheel with your right hand and pull it up and over the drive motor pulley.
If this does not explain it well enough, you can verify by going to repairclinic.com. Click on the Repair Help link and look for the "Dryer Belt Diagrams" link under the Special Features section on the next page. Look for Whirlpool and refer to diagram H.
If you have any questions, please post back with your MODEL NUMBER (located on a nameplate around the dryer door opening) so that I may be able to confirm your dryer configuration. I hope this helps you.
Feb 24, 2010 | Kenmore Dryers
The Belt Tensioner came off of my Whirlpool WED5300SQ0 Dryer
If the belt slipped off, this will cause the idler pulley to come loose. This is normal with no tension on the pulley to hold it in place. To re-install, follow these steps:
1. Loop the drive belt around the dryer drum with the groove side facing the drum. (Try to line the belt up with the wear marks already on the drum from the previous belt).
3. While holding the tensioner in place, insert the belt UNDER the wheel with your right hand and pull it up and over the drive motor pulley.
If this does not explain it well enough, you can also verify by going to repairclinic.com. Click on the Repair Help link and look for the "Dryer Belt Diagrams" link under the Special Features section on the next page. Look for Whirlpool and refer to diagram H. If you still have questions, please let me know. I hope this helps you.
Jul 14, 2009 | Dryers
Belt installation for a maytag dryer model# sde305day
Usally put dryer belt around the drum first
then around motor the tensioner pulley has to to be pulled up when you do this to get the belt around tensioner then you release the tensioner pulley to put tension on belt
Jun 18, 2009 | Maytag PYE2300AY Electric Dryer
Need a btlt route so i can put the new drum back in my ge profile
route the belt around the drum, pull the spring loaded idler pulley to the postion that requires you to hold it there..
put the belt : 1 through the motor pulley and around the idler pulley, or 2. around the idler pulley which ever works to keep the tensioner tight. (Idler pulley, tensioner same thing its the pulley not on the motor.
Once you put the belt on the durm, pull the idler pull so there is tension on it it should be clear how it goes.
Doc
Feb 08, 2009 | GE Profile Harmony DPGT750EC Electric...
Dryer belt routing
the best way i can tell you is open the back put the belt on the motor then visually pull the tension pulley back and put the belt on the tension back on the belt. if you are changing the belt you must touch the spring.let me know how it goes.
Nov 11, 2008 | Dryers
LER6636PW0 drum does not turn
hi fakestar,
here is an exploded view of the dyer, and you can see where the pulley came off.8dd05ba.gifpart number 24 are the pulleys.
another picture is for the belt and the tensioner
1e696ba.gifpart number 53 is the tensioner and part number 56 is the belt.
it just tricky on how to put the belt.
first put the pulley back to its location then slowly insert the drum to the dryer while putting the belt around the drum with the grouve of the belt facing the drum.
have a helper hold unto the drum , in place, then lean underneath towards the motor and put the tensioner to its slot at the flooring, just like in the drawing, then insert part of the belt under the pulley of the tensioner then with your left hand, hold the tensioner pulley and with your right hand, grab the belt which you inserted under the pulley, and bend the tensioner towards the right with your left hand while the right hand is pulling the belt towards the motor until the belt loops to the motor's pulley.
i hope i was able to explain that one.
that is really tricky to put on.
tnx 4 using fixya,
drcool
Oct 10, 2008 | Whirlpool LER5636P Electric Dryer
Replacing maytag dryer belt
looking at the back of the motor where the belt pulley is you would grasp belt coming down from the left side of drum then come across the top of belt pulley that is on motor shaft going clockwise around that pulley then continue back to your left and over the top of belt tension pulley going counterclockwise around that pulley this is when you will have to raise pulley against spring pressure to get belt on then release belt tension pulley make sure that belt is still in belt groove on the drum hope this helps ed
Feb 28, 2008 | Dryers
Maytag dryer
Make sure the belt is properly routed. Often, there is a tensioner that 'adjusts' the belt. It is a wheel that is on a pivot with a spring attached to a fixed point. It may be located anywhere around the drum but is likely near the motor frame. Now, with access to the motor shaft, start the belt over the shaft in the direction of motor spin as much as you can. Try to turn by hand or grab the belt and pull along. ...if it does not work..put the belt over the motor pulley after pulling back on the tensioner. You can use a long screwdriver as a lever. No tensioner? There will be a method of adjusting the placement of the motor. Make sure the motor shaft comes out square to the belt.
Nov 17, 2007 | Maytag Atlantis MDE7400AY Electric Dryer
Dryers Logo
155 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
