Question about Cameras
I cannot operate my camera, when i open the focus lens the notice of error appear
    Scholar:
  • 96 Answers
Over 95 percent of lens problems are from Knock/drop damaged or sand/grit in mechanism. It will need to be serviced by an experienced technician.
Posted on Sep 29, 2009
Why when you turn the camera appears focus error
Although the manual does not have indicate a focus error, I assume you notice the camera can't focus correct.
I hope you know the camera has a focus selector, see the picture. (in the manual, page 10. For auto focus you should select C-AF (continues) or S-AF (single). If it is in manual, toy should focus yourself using the focus ring on the lens (closest to the camera)
Then to help the focus system, there is a external AF sensor. If it is dirty, then it is difficult for the camera to focus correct in a short time.
Also be aware the camera likes to have extra contrast on the focus distance and no objects in front of the subject you want to pictures, with lots of contrast.
Sometimes point to a object with a sharp contrast, on the same distance, press the shutter release button half, then reframe your picture and only then press the button complete.
when you want to shoot fast moving objects choose C-AF.
I hope this helps.
Jul 13, 2014 | Fuji Finepix S9600 Digital Camera
No picture when i use camera then will appear the e32 error then shotdown
lens may be slightly experiencing a focus error . try cleaning the lens and contacts .
or set the switch to manual focus
Jan 27, 2014 | Cannon Cameras
E:61:00 error
E 61 00 Difficult to adjust focus Inspect the lens block focus reset sensor
E 61 10 Zoom operations fault Inspect the lens block zoom reset sensor
E 62 00 Steadyshot function does not work well. Inspect pitch angular velocity sensor
E 62 01 Steadyshot function does not work well. Inspect yaw angular velocity sensor
The simple solution to fix that error message was to the let the lens fully extend and give the lens a good whack. Possibly this error message for this means, that the auto focus motor was past the maximum set point.
This may sound crazy and this has not happened since I did this but here is what I did to get rid of that error message. I have not had that problem since but here was my steps:
· Turn the camera off
· Hold the camera face down over a hard surface (Like you are going to take of your desk) with only about half an inch above the surface.
OR reference the video files below for an alternate method.
· Turn the camera on
· Let the lens extend into the hard surface, don't let it extend all the way. Mine retracted slightly and then tried to extend again (let it extend the second time).
· Lift the camera away from the hard surface and notice that the error message is gone.
· Take pictures of your favorite things.
Here is the first alternate method (AVI format)
Here is the second alternate method (AVI format)
Good luck.
May 03, 2011 | Cameras
I turn on the camera and it starts to focus in and focus out making a noise and then appears ''lens error''..
The gears in the lens housing is grinding because of grit build up, it must be taken apart and cleaned in order to get it back to proper operational standards.
Feb 06, 2011 | Cameras
System Error (Focus)
The systems control board has detected a problem with the auto focus lens, the focus is controlled by a tiny motor that has jammed or there is a mechanical issue with the camera lens. It will require a technician that is highly skilled to deal with the situation, but the repair cost would probably not be justified.
Jan 12, 2011 | Panasonic DMC-FX37 Digital Camera
When I press the on/off button to open my camera a message appears stating 'Lens error' and the lens automatically opens and closes a couple of times before closing so I cannot take any photographs. How...
Hi!
Most likely the focus is stuck. Could be sand or some dirt inside focus gears. They're very small for these lens which are used in many Nikon, Olympus, Casio and other cameras so even one small piece of sand can block the focus system. The only way to fix it to take the camera and lens apart and clean it.
Sorry for the bad news. I repair cameras every day and you can trust me - I know what I'm talking about.
Tom
Sep 23, 2009 | Nikon Coolpix S210 Digital Camera
Lens error please help!!!
If the sand is in the zoom gears or auto focus gears then the camera would need to be disassembled to remove. Nice thing about this camera is that no soldering is required to take apart. A few small screwdrivers, and some tweezers would be all that is required. Canned air and a needle might also be helpful for removing the sand. If the camera just buzzes then I would say that the sand is in the auto focus gears (the stepper motor will buzz). If the auto focus lens is not fully retracted then the camera lens will not go back in (to prevent the auto focus lens from bumping against the shutter assembly)
May 11, 2009 | Canon PowerShot SD1000 Digital Camera
Coolpix lens opens retracts opens then closes again and lens error appears
Hello
When you turn the camera on the lens comes out and has parameters when extending to focus, if the lens does not open fully it sees a problem and then closes.
there are tiny plastic gears inside and may have chipped or a piece of sand got in causing the lens to jamb. "very fragile"
one solution is to ask a camera repair shop how much a lens mechanism would be to replace. (if cost is more than 1/2 of what you paid dont bother)
another solution is to have someone sell your camera on an auction site for parts, to make some money towards another camera purchase
Aug 26, 2008 | Nikon Coolpix L11 Digital Camera
FUJIFILM A 310
Hi
I had same thing. I took camera to bits and still didn't work. Then one day just before throwing it in the bin with batteries in and lens extended, I grabbed the outer ring (bigger part of lens near the body) and pulled it out a little further. I think there was a slight click then the red light turned green and everything was back to normal. Maybe I was lucky,but its worth a try because it definitely worked for me. Cheers John
Oct 21, 2007 | Fuji FinePix A310 Digital Camera
Strange mechanical sound from lens area
Cele, The noise you're hearing is perfectly normal. This generation camera uses a piezo electric focus mechanism to operate the lens. You will notice that the noise goes away if the camera is left alone for a moment while focused on a non moving object, this is because the focus adjustment is made and then the piezo circuit shuts down to conserve battery power. You should have no problems with this camera, it is very reliable. Hope this helps you. Joe Weibel customelectronics.org
Aug 31, 2006 | Sony Cyber-Shot DSC-W5 Digital Camera
Cameras Logo
54 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
