Coleman Patio Heater
Problem for Coleman (5040B750) Patio Heater
No Gas in Heating Element
By blbateman on Dec 19, 2007
I have a Coleman patio heater 5040 series. The light works fine and the pilot for the heater comes on, but when I turn it on full the pilot goes out and no sign of propane. ?
Solution #1
posted on Dec 19, 2007
Not Rated)
Therinnaiguy
Rank: Guru  Air Conditioners  Expert
Rating: 87%, 470 votes
If you are using the heater at temperatures below 40 degrees, ther will not be enough gas vapor to run the heater. If the temperature is above 40, look for an obstruction in the gas piping or gas valve itself. There is a small screen on the inlet side of the gas valve that you can inspect if you remove the inlet hose. Make sure you reinstall the hose using a teflon base pipe sealant on the threads.
Was this helpful?
Yes
No
Popular Solutions for Coleman Patio Heater
Questions and Unsolved Problems for Coleman Patio Heater
Do you recommend Coleman (5040B750) Patio Heater?
Answer
Answer
Have a Patio heater 5040 series. THe heater lights and after about 3 to 5 minute I hear a tick or... (More)
Answer
What does OH mean on a hot tub control panel
Answer
I have a Charmglow heater, Model HBL-155DLP/M20...both heater lights don't come on...fan works and... (More)
Answer
I have a Coleman Cal Cooperage 107 hot tub. We recently had a power surge. Hot tub turns on but... (More)
Answer
haven't used for a long time Colemann 5040; light works, heater does not / Any suggestions ; valve... (More)
Describe your Heaters problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Heater Experts
Top Heater Repairmen
(888) 448-9872
Nationwide plumbers where ever you need us any...
plumbingcoop
(800) 905-9506
Traditional water heaters use a storage tank to...
Plumbing Key
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
