Question about Westinghouse SK-32H540S 32 in. LCD TV
The center transformer from the power supply board was burnt
This transformer i beleived to be the power supply to the LCD.
part number 4302H 8060 _
where can i purchased this spare parts? is it available in the philippines?
  • 3 Answers
Http://www.lcdparts.net/TransformerDetail3D.aspx?ProductID=2775 Suggest you get 2 and keep spare handy. EV
Posted on Feb 03, 2010
Light goes blue to orange, no picture or sound?
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for blown fuses burnt parts, bad capacitors, etc. Look for 5vdc, 12vdc, and 24dvc. you have to this with the help of multimeter to read...
- You can look at the sample of the power supply board, the picture with the soldering side has labeling of what you should have on the output of the power supply, yours may be labeled on the top side of the board, there are high voltage on the board so you must be real careful, if you are not sure, let the professional handle it.
Good luck in solving the problem.....
May 31, 2011 | Westinghouse LTV-27w6 27 in. LCD HDTV
Westinghouse SK 32H540S when i Turn on TV, get Westinghouse logo, picuture turn on for 2 sec then black screen.
The problem is cause by the transformer on LIPS inverter (Power supply + Inverter board). You could see an obvious burn on the 1 of these transformers ( There are total 3 black transformer on this board). The part number is 4302H. It is available online at http://www.lcdparts.net/TransformerDetail3D.aspx?ProductID=2775
May 27, 2010 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Samsung LCD 40 Sensor & picture problem.
Since this is affecting several functions, the problem is likely the main power supply. It may be that the supply itself is failing (switched mode power supplies like hari-kari) or an assembly (possibly the backlight invertor) is producing a fault condition which is causing the supply to drop out to protect itself.
Try the instructions below -
The supply is normally built on a separate board since these are often out-sourced by set manufacturers.
Unplug your set overnight to allow potentially hazardous voltages to discharge, remove the back panel of the set so you can see the guts.
Look for a smaller board with larger parts on it; some cylindrical (capacitors), others block-like and relatively large (chokes and transformers).
You should also see a relationship between the board and the incoming AC.
Check the board for a label or if not present, a stamped-on number.
Call the manufacturer's service center with your TV model number and the number found on that board and inquire about repair/replacement costs; if both are offered, they won't be that much different.
If you must buy a new board, don't dispose of the failed one as there are smaller companies that can repair it for less than the mfr. and then keep it as a spare as this problem will likely arise again.
Sep 10, 2009 | LG 42LC2D 42 in. LCD HDTV
How do i install a new mother board on my hp officejet 7410?
Well you wont find this info anywhere...HP doesnt give it out to anyone but authorized repair centers...
I dont think you know what that board costs....it may be cheaper to get a new printer...you probably cant get the board with out having a repair center do it anyway
Aug 27, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Replacement transformer Darfon 4301H
If the transformer is part of the power supply board, the board is available as an assembly. Please verify that your model number is LTV-32W1. If so, the part number is: 4900214080 and is available from tritronicsinc.com for $208.33
Dan
Apr 25, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
How to solve Flickering problem of LCD
I have had the same problem,
I found it was my power supply transformer (part of power lead).
Some transformers may be faulty, or replacement transformer may not provide a voltage stable enough for the LCD.
Also check the wiring in your plug.
Safest option is, buy a genuine Acer supply transformer with plug lead from Acer.
Hope this helps (please rate my advice)
Jan 30, 2009 | Acer Aspire 5920-6727 Notebook
ZX-8100
I'm not familiar with that particular amp but generally, the only transistors that burn are the ones in the power supply. If the adjacent transistors had numbers like IRFZ44, IRF3205 or similar, the burned transistor is likely the same as the ones next to it.
Confirm that the center and right-most leg of the burned transistor and the transistor next to it are directly connected by large traces on the circuit board. Also confirm that the center leg goes to the large windings of the power transformer. If it passes these tests, the transistor is one of the power supply FETs. The numbers on the adjacent (parallel connected) parts will be the same as the burned one.
Jul 16, 2008 | Volfenhag ZX-8200 Car Audio Amplifier
Stopped working
I had a similar problem with a jvc 8040. when I replaced the fuse it became very obvious that the b1560 output on the center channel was blown (smoke and sparks, always a dead giveaway). I haven't fixed the center channel yet but simply unplugged the center channel board and removed it from the unit. Now everything works fine except of course the center channel. Pre outs still operate just fine so a slave amp could be used for center channel power, or you could just go and buy a marantz amp; I did and then I realized that I was lucky that the old jvc quit.
Jan 27, 2008 | JVC RX-1028V Receiver
Westinghouse lcd tv parts
HAVE A WESTINGHOUSE LTV32-6HD. HAS SOUND, NO PICTURE. APPROXIMATELY 8 MONTHS OLD
Jan 20, 2008 | Westinghouse LTV-27w7 7 in. LCD HDTV
Viewsonic vx924 LCD burnt transformer - T1
I did find a source for ccfl inverter transformers.The site is www.bourns.com
Oct 21, 2007 | ViewSonic VX924 19" LCD Monitor
Westinghouse SK-32H540S 32 in. LCD TV Logo
588 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
