Question about Panasonic PT-47WX49 47" Rear Projection Television
Mt pt-47wx49e is showing a blurry picture that bounces and waves. ive tried adjusting the convergence on the set but dont have a remote and its tricky to do on the set top controls but i dont think its helping at all. what could be wrong with it
  • 101 Answers
Convergence chip could be lose as in solder joints bad sometimes a good slap on the TV side will straighten this out temporarily but not recommended. A service call is the best fix unless your handy at taking it apart and resoldering the chip you can find convergence kits online if you are the handy type :)
Posted on Sep 29, 2009
Panasonic pt 53wx53g
No--you will NOT get anywhere this way. You need a remote.
Apr 01, 2014 | Televison & Video
I have a blue double image on my panasonic pt-47wx49e projector tv. I've tried to adjust the convergence from the set up menu. But no matter how many times I try to adjust the green or the blue, only the...
If you go into the customer menu and select convergence and it is skewed you need to remove the light box and replace both of the STK-392-110 CONVERGENCE IC chips this set uses.
I HAVE START TO FINISH, STEP BY STEP INSTRUCTIONS FOR THIS REPAIR IN THIS SET--I can post them here if you think you or someone you know can do the repair.
Most shops get 300 or more for this repair--if you buy the chips on Ebay (I can tell you the seller to look for there) they and any other parts should total under 30 dollars. The fact that the set is still coming on means most likely just the two chips need to be replaced and the set adjusted with the Panasonic remote for this set.
If you have questions or want the instructions rate this solution and let me know and I will post them here---I do this here for FREE.
SD TECH
Nov 30, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-47WX49E blue convergence problem.
if convergence does not adjust in menu mode could be a defective convergenceic or fuse
Nov 11, 2009 | Panasonic PT-47WX49 47" Rear Projection...
My tv is blurry, showing green and red waves...zenith d61w25
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic2_bing.gif,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 01, 2009 | Zenith D61W25 61" Rear Projection...
Convergence problem on a panasonic 47wx49e
i would send a repairman out just to be on the safe side. if you arent sure what you are doing you can only make it worse than it already is and i dont think you want to do that. if you arent familiar with the tv then call a repaiman
Feb 16, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Convergence problem and cropped picture
your tv is under convergence problem usually we need to replace 2 big integrated circuits in the convergence section, at this point you may need a good tech to come over to your home
Nov 13, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Red horizontal convergence PT-47WX49E
converge outputs getting tired or limiting resistors opening up. adjusting this incorrectly will make the situation worse keep in mind that overdriving these chips will cause a fold over of your image when you see this carefully adjust in the opisite direction as you may be overheating the outputs
Oct 08, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Green rainbow streak on bottom of TV PT-47Wx49E
If Convergence on setup dosen't work, And you think its not STK Convergence chips!, Then "Yes" It more then likely will have a few open Resistors!... (Near STK chips)
Jun 24, 2008 | Panasonic PT-47WX49 47" Rear Projection...
PT-47WX49E Service Manuals
scott iam in need of one too would you PLEASE add me to your list Thanks so much
Apr 11, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Pt-47wxs1ce green wave at bottom of screen cannot adjust green convergence
you have bad convergence IC's and possable 1 bad resistor
let me know and i will help you find them in the set if your are a good solderer - or call a tech
thanks
scott
Aug 30, 2006 | Panasonic PT-47WX51 47" Rear Projection...
Panasonic PT-47WX49 47" Rear Projection Television Logo
79 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
