Manfrotto 679B Monopod Logo
Posted on Sep 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I lost the clip that tightens fasteners on 679b monopod. Where can I get a replacement
Anonymous
Level 3:
  • Master 8,197 Answers
  • Posted on Sep 29, 2009
Anonymous
Master
Level 3:
Answers
8197
Questions
7
Helped
3073116
Points
27242
To get parts you need to contact Manfrotto here.
http://www.manfrotto.com/Jahia/site/manfrotto/pid/3429
Good luck
Where is the Mode Actuator Located in a 2008 Pontiac G6?
Preliminary Procedure
Remove the instrument panel left outer trim panel. Refer to Instrument Panel Outer Trim Cover Replacement .
Remove the left closeout/insulator panel. Refer to Instrument Panel Insulator Panel Replacement - Left Side .
Remove the data link connector.
Screws, Knee Bolster (Qty: 3)
Tighten
2 N·m (18 lb in)
Knee Bolster Assembly
Retaining Clip, Knee Bolster (Qty: 3)
Callout
Component Name
Notice: Refer to Fastener Notice in the Preface section.
Fastener Tightening Specifications: Refer to Fastener Tightening Specifications .
Screw, Instrument Panel Closeout/Insulator (Qty: 2)
Tighten
2 N·m (18 lb in)
Nut, Instrument Panel Closeout/Insulator (Qty: 1)
Tighten
2 N·m (18 lb in)
Panel Assembly, Instrument Panel Closeout/Insulator
Removal Procedure
Remove the fuse labeled HVAC CTRL (BATT).
Remove the left closeout panel. Refer to Instrument Panel Insulator Panel Replacement - Left Side .
Remove the knee bolster. Refer to Knee Bolster Replacement .
Remove the mode actuator retaining screws.
Remove the mode actuator.
Disconnect the mode actuator electrical connector.
1helpful
Center console removal
Well, this good to be interesting to say the least, and probably long as well. By my gm. service information your going to need to take out the front bucket seats so the sides of the console can come off.
Remove the left front seat . Refer to Bucket Seat Replacement .
Front Floor Console Extension Panel
Retainer Clip (Qty: 5) same for right side.
showgif.do?image=1875475
Callout
Component Name
Remove the right front seat. Refer to Bucket Seat Replacement .
Front Floor Console Accessory Trim Plate Assembly
Procedure
Use a flat bladed plastic trim tool in order to release the console accessory trim plate from the console assembly.
Retainer Clips (Qty: 5)
Remove the front floor console accessory trim plate. Refer to Front Floor Console Accessory Trim Plate Replacement.
Front Floor Console Accessory Housing Screw (Qty: 2)
Tighten
2 N?·m (18 lb in)
Front Floor Console Accessory Housing Assembly
Procedure
  1. Disconnect the electrical connectors.
  2. When replacing the front floor console accessory housing assembly, transfer all necessary components
  1. Remove the rght or left front floor console extension panel. Refer to Front Floor Console Extension Panel Replacement - Right Side or Front Floor Console Extension Panel Replacement - Left Side .
  2. Remove the front floor console cup holder housing. Refer to Front Floor Console Cup Holder Housing Replacement .
Front Floor Console Rear Trim Panel Screw (Qty: 1)
Tighten
2 N?·m (18 lb in)
Retainer Clip (Qty: 4)
Preliminary Procedures
  1. Remove the front floor console accessory trim plate. Refer to Front Floor Console Accessory Trim Plate Replacement .
  2. Remove the right and left front floor console fillers. Refer to Front Floor Console Filler Replacement .
Front Floor Console Armrest Assembly Bolt (Qty: 4)
Tighten
9 N?·m (80 lb in)
Procedure
Position the armrest assembly out of the way leaving the electrical harness attached.
Front Floor Upper Console Trim Plate
Procedure
Lift the rear of the trim plate first, releasing the retainers securing the trip plate to the console assembly.
Retainer Clips (Qty: 4)
Front Floor Console Replacement (Enclave)
showgif.do?image=1858392
Callout
Component Name
  2. Remove the right and left front floor console extension panels. Refer to Front Floor Console Extension Panel Replacement - Right Side and Front Floor Console Extension Panel Replacement - Left Side .
  3. Disconnect the automatic transmission range selector lever cable. Refer to Range Selector Lever Cable Replacement .
Front Floor Console Screw (Qty: 2)
Tighten
2 N?·m (18 lb in)
Front Floor Console Bolt (Qty: 10)
Tip
Before installing the right lower forward bolt, ensure that the console wiring harness is tucked below the fastener location to avoid driving the bolt into the harness.
Tighten
9 N?·m (80 lb in)
Front Floor Console Assembly
Procedure
  1. Note location and routing of the front floor console wiring harness prior to removal of the front floor console assembly to ensure proper reinstallation.
  2. Disconnect the electrical connectors.
  3. With the aid of an assistant remove the console assembly from the vehicle.
  4. When replacing the front floor console, transfer all necessary components.
h4hqqpweof7+aaaaaelftksuqmcc
arzs+0tf0j6faaaaaelftksuqmcc
Tevion helpline line
That is going to have to be disassembled and then re assembled. You can send it to:
Repairs at SpartanPhotoCenter
108 Garner Rd
Spartanburg, SC 29303
Bottom tube moves when tighten
It sounds like the tubes may be dented or bent. It won't take much of a bend to make it hard to work. Send it to: http://www.manfrottotripodparts.com/repairs.html
they can repair it for you.
I need the torque specs for replacing the valve cover gasket on a 2001 chevy cavallier 2.2 liter 4cly. thanks
This should do the trick, torque to specs then additional 90 degrees turn on all bolts
Notice: Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
  • Use the following sequence in order to tighten the cylinder head bolts: Tighten
    1. Tighten bolt 1 to 63 N·m (46 lb ft).
    2. Tighten bolt 2 to 58 N·m (43 lb ft).
    3. Tighten bolt 3 to 58 N·m (43 lb ft).
    4. Tighten bolt 4 to 63 N·m (46 lb ft).
    5. Tighten bolt 5 to 63 N·m (46 lb ft).
    6. Tighten bolt 6 to 58 N·m (43 lb ft).
    7. Tighten bolt 7 to 58 N·m (43 lb ft).
    8. Tighten bolt 8 to 63 N·m (46 lb ft).
    9. Tighten bolt 9 to 63 N·m (46 lb ft).
    10. Tighten bolt 10 (stud bolt) to 58 N·m (43 lb ft).
    11. Then tighten all bolts an additional 90 degrees
  • 0helpful
    The smallest clamp (bottom clamp) is broken.
    Try www.BogenTripodParts.com for that part. There is listed the widest selection of Bogen parts and support more models than any other web site I’ve seen. There are losts of pictures to help find just the right part.
    Reassembling telescopic sections for a 676B monopod
    Each leg lock has a leg locking lever and a screw that hold the clamp assembly tight to the leg. Unlock the leg lock lever, loosen the screw above it that holds the clamp tight to the leg. The legs should fit into each other sice each leg is slightly larger or smaller then then next one. Slide the clamps in the approprite places and tighten the screw enough to hold the clamp assembly tight, but do not over tighten it. Over tightening will damage the 679 tubes.
    How do you take off inner driver side door panel with out breaking the the snaps and panel itself
    Sometines the panel retainers do break, they are available at most parts stores, you should use a special tool to remove them (pic below)
    Front Door Panel: Service and Repair
    Trim Panel Replacement - Side Front Door
    REMOVAL PROCEDURE
    TOOLS REQUIRED
    J 38778 Door Trim Pad Clip Remover
    1. Remove the inside handle bezel (2).
    2. Remove the fastener (1).
    3. Lift the flap (1) in pull handle opening.
    4. Remove the two fasteners (2).
    5. Remove the two fasteners (1) from bottom of trim panel.
    6. Using the J 38778, release the eight retainers.
    7. Lift upward and outward on the door trim panel.
    8. Disconnect the door latch cable from the inside door handle.
    8.1. Pry the tab on the cable outboard while pulling back on the cable.
    8.2. Unhook the collar portion of the clip from the cable attachment.
    8.3. Push upward on the bottom of the cable attachment to disengage the cable from the handle clip.
    9. Disconnect the electrical connectors.
    10. Remove the door trim panel.
    INSTALLATION PROCEDURE
    1. Partially install the door trim panel.
    2. Connect the electrical connectors.
    3. Connect the door latch cable to the inside door handle.
    4. Raise the trim panel over the lock knob and align the fasteners (1) in the holes in the door assembly.
    5. Secure the trim panel to the door assembly by applying sufficient pressure on the trim panel.
    NOTE: Refer to Fastener Notice in Service Precautions.
    6. Install the two fasteners (2) under the inside pull handle opening.
    Tighten
    Tighten the fasteners to 2 N.m (18 lb in).
    7. Install the inside trim panel cover fastener (1).
    Tighten
    Tighten the fastener to 2 N.m (18 lb in).
    8. Install the trim bezel (2).
    9. Install the two fasteners at the lower portion of the trim panel.
    Tighten
    Tighten the two lower fasteners to 0.5 N.m (4 lb in).
    685B Monopod
    If In melbourne look up www.adeal.com.au . They are wholesalers and DO NOT sell to the public, but if you go out to them in Altona North they will help you over the counter. Or go to any TED's Camera Store. They sell the range of Manfrotto tripods and they will be able to help you.
    Top Manfrotto Photography Experts
    Tony Parsons
    Tony Parsons
    ADMIN Andrew
    ADMIN Andrew
    Are you a Manfrotto Photography Expert? Answer questions, earn points and help others
