Question about Gateway FPD2275W LCD Monitor
Can anyone tell me what the C-18 capacitor is from the controller board of a gateway fpd 2275w? It fried and the numbers are gone.
    Sergeant:
  • 192 Answers
I have mine apart right now, If ya can provide me with a picture that points to which one you are referring to. I should be able to read the numbers from mine. Trippy
Posted on Dec 05, 2009
    Scholar:
  • 63 Answers
I don't have this board any longer but may be able to help you.Is it Electrolytic, SMD, or ceramic?
I have a Gateway FPD 1830 Monitor. I have to turn it on usually between 30 to 50 times to get it to turn on. What is wrong, and how can I fix it?
The power supply, the inverter, or the lighting tubes may be defective. I would bet that you need some new capacitors in the power supply or possibly some transistors. Those are the two main failure points that cause the quick power supply shutdown. It detects overload and tries to save itself from total destruction by shutting down.
I bet on capacitors, especially if you never turn the power off but let it sit in standby all the time.
Oct 27, 2014 | Gateway FPD1830 DVI/VGA 18-inch LCD Flat...
My monitor does not turn on and the power button light keeps blinking
elvisy71, If different monitor will display the Win-desktop screen with no problem, then Gateway 2275w will need you or qualified electronics technician to possibly repair a defective internal "switch-mode-power-supply" / CCFL inverter supply" !! Check the status of unit warranty first, and check to see if Gateway has a swap-out (exchange+cash) program. If that dosen't work you will be doing a lot of reading about DIY lcd monitor fixes. You will also need to view some DIY video clips at YOUTUBE on "lcd monitor disassembly" and "lcd monitor repair" that will help you decide what to do about your now BLACK or BLANK n BLACK screen unit. You can find tons of DIY stuff here on fixya in my and other CCFL back-lit lcd monitor tech's fixya profiles. Elvis, remember this! Your 2275w isn't any different than any other brand of ccfl back-lit lcd display in it's basic design and operation and some can be DIY repaired for under $6 in parts cost. Just do some reading of the higher numbered (>16) pages in my fixya profile and my old profile "louie12fix" and follow the web links you find there. If this was of some help to you please come back to fixya and rate this response and tell me and all the other black screen lcd owners what you are planning to do about your monitor. 12fixlouie 42610
Apr 26, 2010 | Gateway FPD2275W LCD Monitor
Why would the Gateway FPD 1730 17 in. Flat Panel LCD Monitor turn on,,then go right back off,,if you leave it unhooked for a few days then it will work for a short time than quit again
This sounds like a typical Capacitor in the Power Supply fault. Some people take them apart and replace the capacitors, however I recommend that you get a "Quote" for repair, as these often "Chain Fault" and I have seen a lot of disappointed would be fixers.
Feb 20, 2010 | Gateway FPD 1730 17" Flat Panel LCD...
Where can I buy on line the inverter board for FPD 1830
eBay is probably the best and easiest source for this item.
Dec 28, 2009 | Gateway FPD 1830 18.1" Flat Panel LCD...
Searching parts
try prs eletronics components uk.
Oct 12, 2009 | Gateway FPD2185W 21 in. LCD Television
My fpd1975w monitor is flickering
The Gateway FPD models develop problems after a couple or more years of use. The repairs are fairly easy for the savvy technician. The power inverter board in the back of the monitor contains some capacitors, they may be 470 and 220 mfd or 680 mfd depending on when they were made, @ 25 volts, with a 105 deg. C temp rating. They go bad due to heat issues and the currents they have to filter. Replacement of the capacitors usually restores operation.
Jan 26, 2009 | Gateway FPD1975W 19" LCD Monitor
Monitor goes blank
I was thinking about your problem, I just had a similar issue and the problem is that the inverter or the power supply with an embedded inverter had gone bad.
The reason it goes black is because the inverter fails to provide power to the LCD Display.
The only way to fix this is to open up the FPD:
*note these are instructions for the most popular FPD 1730*
1.there should be four screws on the back --> plus two large screws that hold the FPD stand and the Monitor together.
2.Open the back by pulling the cover off
Remove 7 screws holding the frame and the power button for the LCD
3.Remove two screws through holding a silver cover and remove cables.(pinkwhite) (blackwhite)
Please note where they belong before removal**
4.On the edges left and right are two screws 4 total ---> remove and remove LCD off of frame**becareful because the backlight Damaging can cause severe damage to your LCD panel.
5.Choose your model
Your FPD has 3 boards (power, inverter(backlights) Logic Video)
replace the inverter with well known good one
Your FPD has 2 boards(Power with inverter on edges, Logic Video)
replace the power board with a well known good one
6.Then do steps 1-5 in reverse order(putting your FPD back together.
I hope this is significant help
Sep 11, 2008 | Gateway FPD 1730 17" Flat Panel LCD...
Gateway monitor model Fpd 1950
It's probably cheaper to get a new monitor than it is to get a logic board. If Gateway can even get you such a thing.
Good luck on that.
Jun 15, 2008 | Gateway FPD1950
Static discharge
Hello Gil
WEll defenetely, you fried your spks. so you have some options here.
1) Go to warranty (if apply) and use it.
2) get the spks. to repair shop to change board. ($$$)
3) buy new pair of speakers. and keep away from statics places. use wood tables instead of metalics.
good luck
Jan 11, 2008 | JBL CREATUREIIWHITE Computer Speakers
Gateway FPD 1730 17 in. Flat... Problem
Try using it on a different computer, it's possible that it is your graphics card causing the problem. Check for bent pins.
Dec 20, 2007 | Gateway FPD 1730 17" Flat Panel LCD...
Gateway FPD2275W LCD Monitor Logo
198 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
