Question about Sony Cybershot DSC-T77 Digital Camera
All my photos turn out purple/blue with lines.
The screen is fine because when I'm viewing old pictures, everything is clear. I'm thinking its something with the lens, but I don't know. Can anyone help?
3 Suggested Answers
SOURCE: Distorted photo's
Sony is fixing this through Sept. 2008!
http://esupport.sony.com/perl/news-item.pl?news_id=161&mdl=DSCF717
Posted on Apr 18, 2008
SOURCE: Sony Cyber-shot DSC-S700 photos are pink/purple.
I have the same problem with my Sony cybershot DSC-T20. Ive only had it a year. Please could someone help me.
Posted on Oct 05, 2008
My screen has a blue cast over everything. On a clear screen you see blue lines running up and down the viewing picture
I have the same problem with blue vertical lines all over the picture... did you find a solution?
Nov 16, 2013 | Sony VPL VW10HT Multimedia Projector
The camera took great pictures then all of a sudden the screen appears as a purple haze -- and the pictures come out as just a purple blurry haze. Adjusting brightness doesn't work. Yet, the shutt
If the LCD displays correctly on previous photos then the problem is more than likely a CCD or associated ribbon connector failure due to moisture/condensation or age/misuse. Good luck with finding a replacement part!
May 31, 2012 | Panasonic Lumix DMC-TZ3 Digital Camera
My tv is turning everything purple like it is
Hello :
The problem is your color purity is off. The earths magnetic poles cause this to happen on all direct view televisions, when you move a television or turn it from its usual viewing spot. You may have noticed a thump sound when you first cut on the television after its been off for a while, this is the televisions degaussing circuit mixing the color phospers in the picture tube. One way to clear this is to turn off the set for at least 20 mins and turning it back on this usually clears the purity. Have you ever had a older computer monitor and it had a button on it that says degauss an press it and you see a rainbow of colors then the screen goes back to normal. Well your television also has one too but does it when you first cut on the television you can't see the rainbow effect because the screen is still dark at this point.
If this does not work have a technician come out and degauss the set for u manually, using a degaussing coil.
Hope this explains your problem,,
Please leave a comment for futher assistance.
Delhielectronics@live.com
Sep 29, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Distorted picture on a mitsubishi ws-55613 tv
Their is no more you can do.
Seen this before.
You need a professional.
Stop using the TV until it is repaired.
Continue to use the TV and your problems WILL multiply.
Call the manufacturer to find you nearest authorized service center.
MR. TV Sales & Service Inc
Milwaukee, Wisconsin 53405
(414) 762-8600
Established 1974
Mar 24, 2009 | Mitsubishi WS-55613 55" Rear Projection...
Purple Screen
If it is only 2 months old,then you still have warranty.
A purple lcd, viewfinder and photo is a 100% CCD failure.
If out of warranty, not worth the repair.
Mar 07, 2009 | Panasonic Cameras
Sep 10, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
LCD screen shows weird colours
Gimbo again. Think LCD damaged will need to repair. Pics. as normal when viewed or printed.
Why has nobody commented?
How much to replace screen? Any ideas?
Feb 16, 2008 | Cameras
PURPLE LINES SHOWING ON SCREEN WHEN ATTEMPTING TO TAKE PHOTOS
Your camera likely needs a new CCD imaging sensor. It is a cute little thing and is very expensive to replace. I've seen deals to repair any digital camera on eBay and I would check for a local repair person in your area. You can use the search on this site to see who might be close by. I have an A310 doing the same thing.
Jan 04, 2008 | Fuji FinePix S5000 Digital Camera
Coloured lines on picture screen
I have the same issue, Although My camera is a samsung N46, It was working perfectly the night before, then my friend switched it on and it came up with a black backround and pink + purple vertical lines going through it.
Nov 12, 2007 | Olympus FE-120 Digital Camera
Purple lcd display
Hello tonyj111, If your old pictures look fine on the display, then the problem is related to the ccd sensor itself. The purple color is displayed because of a problem in the signal transmision from the ccd sensor to the camera's main processor. This is done using 3 channels one for each primary color (RGB red green blue). If the connector to the sensor is broken, or got out of place (loose) because some mechanic shock or symilar, the data processing woun't come out right. It is purple because your camera's processor mess up blue and red signals therefore resulting same purple instead of blue or red colours. In order to fix this you will need to either send the camera to a service center to have those connections checked (if your camera is still in warranty you will want to do this) or ask me for further instructions if you wish to try to dissasemble the camera yourself. In either way the problem is fixable and in most probabilities a cheap fix will work. Good luck
Jun 01, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Sony Cybershot DSC-T77  Digital Camera Logo
22 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
