Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Whirlpool washer LA7800xpw1 - timer-shunts
In the process of cleaning and testing timer the "SHUNTS" came out - need diagram(DRAWING) for correct replacement!!    THANKS   JOHNNIE
    Problem Solver:
  • 11 Answers
Get User Manuals Find User Manuals and How-to Info For Your Dishwasher www.KitchenManuals.com
Posted on Dec 22, 2007
Exploded diagram of centrifical governor
exactly what engine are you talking about
post again stating make model ,year engine type as there are literally dozens of different centrifugal governs used in electrical and mechanical equipment
Sep 20, 2016 | Vehicle Parts & Accessories
Water in water softener, filling over potassium in tank. How do I fix this?
There is an injector (venturi) in your softener that shunts to allow brine to be sucked out of your salt tank and, near the end of regeneration, shunts again to put water back into your salt tank to make brine for the next regeneration. It isn't moving; probably needs cleaning and perhaps lubrication with silicone grease. If you don't have a manual, download one. There are hopefully illustrations to help. Otherwise you'll need to hire someone to do it for you, but watch so you can do it for yourself. If the injector has plugged in only three years it'll likely do so again.
Feb 03, 2015 | Water Dispensing & Filtration
Radio Shack Multimeter, 22-168a, shunt resistor value????
Go to the Radio Shack site and you may with the model number find a schematic or you can email/contact them for the value of the resistor.
I predict it is a precision value and type you will have to get from them if available.
PS: you posted in wrong catagory as this is TV section.
Mar 12, 2012 | Televison & Video
When I press the power button it will not power up. It is plugged in and the outlet is hot.
Hi - Its rather unfortunate its my believe the fault with your machine is most likely to be the motor controller module, without a working controller nothing will operate.
The only other component that would do this is the the drain pump, however the pumps are incorporated into the circuit as shunts - or excess power surge abbsorber, but not always efficient.
Jun 21, 2011 | Fisher and Paykel GWL11 Top Load Washer
Frigidaire fdb510lcs0 soap dispenser not opening
Hi
Many dishwashers (but not all) use a BI-metal strip that heats up once poweris applied to it. The BI-metal strip bends and allows the soap door spring toopen up the dispenser. This bi-metal strip is not given full 120 volts power,the timer "shunts" the power through either the heating element (most common ) or the motor and this gives the bi-metal strip lower than fullpower to work and open. Most often the bi-metal strip has lost its ability tobend properly and needs to be replaced. Older GE dishwashers used a mechanicalarm driven by the timer to open the dispenser = no electrical bi-metals.
Newer Frigidaire dishwashers and many newer Whirlpool dishwashers use a wax motor to open the soap dispenser. The plunger insidethe wax motor slowly moves and pushes the plunger and door open. And, if thiswax motor doesn’t receive 120 volts, then it’ll not work.
This will help you --
Please do rate this solution and revert for furtherassistance.
Thanks
Rylee
Sep 20, 2009 | Frigidaire Dishwashers
GE profile model GSD 4120y70BB the second soap dispensor does not open at the right time. When cycle is done and the door is opened the soap has just ran down. It is like it is opening to late.
Hi
Many dishwashers (but not all) use a BI-metal strip that heats up once power is applied to it. The BI-metal strip bends and allows the soap door spring to open up the dispenser. This bi-metal strip is not given full 120 volts power, the timer "shunts" the power through either the heating element ( most common ) or the motor and this gives the bi-metal strip lower than full power to work and open. Most often the bi-metal strip has lost its ability to bend properly and needs to be replaced. Older GE dishwashers used a mechanical arm driven by the timer to open the dispenser = no electrical bi-metals. Newer (plastic liner) Maytag dishwashers and many newer Whirlpool and Frigidaire dishwashers use a wax motor to open the soap dispenser; this wax motor does receive 120 volts to work. The plunger inside the wax motor slowly moves and pushes the plunger and door open. This is what a wax motor looks like.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 06, 2009 | GE Dishwashers
Soap dispensor not opeaning, and soap tabs are not dissolving
Hi
Many dishwashers (but not all) use a BI-metal strip that heats up once power is applied to it. The BI-metal strip bends and allows the soap door spring to open up the dispenser. This bi-metal strip is not given full 120 volts power, the timer "shunts" the power through either the heating element ( most common ) or the motor and this gives the bi-metal strip lower than full power to work and open. Most often the bi-metal strip has lost its ability to bend properly and needs to be replaced. Older GE dishwashers used a mechanical arm driven by the timer to open the dispenser = no electrical bi-metals. Newer (plastic liner) Maytag dishwashers and many newer Whirlpool & Frigidaire dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn’t receive 120 volts, then it’ll not work.
Please do rate this solution and revert for further assistance.
Thanks
Rylee
Aug 04, 2009 | Frigidaire Dishwashers
Soap door is locked shut and will not open, we have spun the dial around to the point that it should open and it did not work.......
Hi
Many dishwashers ( but not all ) use a BI-metal strip that heats up once power is applied to it. The BI-metal strip bends and allows the soap door spring to open up the dispenser. This bi-metal strip is not given full 120 volts power, the timer "shunts" the power through either the heating element ( most common ) or the motor and this gives the bi-metal strip lower than full power to work and open. Most often the bi-metal strip has lost it's ability to bend properly and needs to be replaced. Older GE dishwashers used an mechanical arm driven by the timer to open the dispenser = no electrical bi-metals. Newer ( plastic liner ) Maytag dishwashers and many newer Whirlpool and Frigidaire dishwashers use a wax motor to open the soap dispenser, this wax motor does receive 120 volts to work. The plunger inside the wax motor slowly moves and pushes the plunger and door open. This is a what a wax motor looks like.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Apr 26, 2009 | GE 24 in. GSD4000J Built-in Dishwasher
Pr600 shunts over on big designs
You can try to calibrate the hoops by having the machine turned off and the largest hoop and smallest hoop ready hold down the start/stop button and the needle theader button and turn the machine on while holding those in, you should get a different screen that say a/d test in the upper left corner, put the largest hoop on the machine being shure the screws are tight and hit the l button on the upper right side the numbers next to the button will change, then put the smallest hoop on and hit the ss button once the thats done turn off the machine and on again and it will start normally and try your designs again if that doesnt work take it to a brother service center/ dealer and tell them to check your x-axis position
Mar 18, 2009 | Sewing Machines
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
176 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
