Question about Westinghouse LTV-32w3 HD Television
Good power supply and main board, broken LCD panel
Sounds like one or more of you have a bad power supply for this TV and cannot find a replacement. I would be interested in buying your tv for the LCD screen if you are interested in selling. Please send inquiry to ltebbe@pcibroadband.net
  • Westinghouse Master
  • 5,138 Answers
GO to Ebay thats where you can find what you are looking for.Look under Electronics
Posted on Mar 18, 2010
I have an Element tv that has no picture, good sound but basicaly a black screen. Do i need a didgital board or a main board?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Apr 26, 2017 | Element Televison & Video
Repair Sony nsx-40gt1 tv, no picture, 2 red blinking lights where normally green. Is the power supply board bad, t-con bad or main board bad. Who sells repair manual?
Hello Eric,
shopjimmy has the circuit boards and gives live support..
Check out the URL below.
Also consider getting an anti-static wrist band... so you don't destroy good semi-conductors with tiny static sparks.
Further information on that is under "ESD"
(Electro-static Discharge)
TV Parts Universal TV Stands DLP Chips ShopJimmy
Sep 14, 2016 | Sony NSX40GT1 40 Inch Internet TV powered...
Model KDL32BX300. Why won't it turn on?
PLEASE CHANGE THE INVERTER BOARD BECAUSE YOUR 24 VOLTS ARE SHOTED
Dec 20, 2015 | Sony Televison & Video
I have a LG 50LN5600 LED Smart TV w/sound no/pic Have replaced the power supply board and t-con board. Main board only one left and research says that this would not be a main board prob. Any help?
If the LCD panel back light is not lit you have a bad LCD panel. If the back light stays lit when the set is turned on then you almost certainly have a bad main board since you have already replaced the power supply and T-con.
Aug 17, 2015 | LG Televison & Video
Horizontal lines
It sounds that the main power supply regulator board has the fault. Replace all the large electrolytic capacitors on that circuit board, or replace it with a new board as card basis.
Apr 25, 2013 | RCA L32HD41 LCD TV
I hae a vizio E320VL, i have replace main board and the power suplly, and it still won't stay on.
hi. you sure your replacement -- power supply & main board in good condition???? lcd present 5v , 12v, &24 v ??? if no you need going back power supply. if yes. you need to replace inverter board as possible. good luck!
Sep 01, 2012 | Vizio L32 32 in. LCD HDTV
Spot of bad weather here, just had a power surge in the house and now our tv (sharp lc-42SB48UT) won't power on. There is no blue or red light on the front and changing outlets/surge protectors doesn't...
90% to 95% ur tv have a dead power supply board only.5% ur tv could have both dead boards the tv power supply board and the main tv Tuner signal board too.The tv power supply board.That the board,where the power a/c cord plug into it.The tv main Tuner signal board,that the board where all the exstented devices and the tv incomming broadcasting signal cable wire plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement first.The tv problems should be fixed.If not than the main tv Tuner signal board is dead too.Must be replaced also.
Apr 24, 2011 | Sharp LC42SB48UT 42 in. LCD TV
The tv powers up for about 30 seconds and then the power light starts blinking fast and the tv shuts off i think it is the main board but any suggestions would help
Good day.
This the procedure that you have to do.
  1. Remove the cover of your TV.
  2. Power on the TV to apply voltage data.
  3. Check the power supply output.5vdc for main board supply,12v for the sounds and 24vdc for back-light inverter.
  4. If any of the 3 supplies are missing or got a voltage drop,there's a problem with your power supply.Check some leak/bulging top capacitor.
  5. If the 3 supplies are OK,the problem is on the main board of your TV.Replace it.
I hope this solution will be helpful.Thank you for using FixYa.Good luck.
Apr 17, 2011 | Sylvania LC420SS8 LCD TV
Samsung 40" lcd tv with a broken internal lcd panel
If the screen is cracked, it will cost more that what the TV is worth. Are you just getting black screen but still have sound? Otherwise it can be the backlight inverter board is bad or it is not getting power from the main power supply section.
Nov 03, 2009 | Samsung LN40B530 40 in. LCD HDTV
My Akai LCT3201AD won't turn on
Normally the end model numbers signify a revision. Your LCD screen should work fine in the other one. Manufacture's tend to keep LCD screens within the same vendors for specific models for cheap replacements =)
Jan 22, 2009 | Akai LCT3201TD 32 in. LCD Television
Televison & Video Logo
265 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
