Question about Juki Sewing Machines
Juki DDW-126, we would like to know the needle size and how to thread the machine it is very old
yalmer
  • 552 Answers
SOURCE: threading a juki ddl 5530
Go to this link and you will find how to thread your machine.
Posted on Apr 02, 2008
SOURCE: juki stuck needle
check settings
Posted on Apr 28, 2008
  • 3 Answers
SOURCE: needle thread breaks while quilting on machine frame
I think you might have better luck if you use 40 or 50 weight thread.
Posted on Dec 20, 2008
  • 4 Answers
SOURCE: Needle Thread breaking after about 30 seconds of quilting
Are you threading it correctly? I've had this problem twice, the first few times the thread was wrapped around different items (below the spool holder and then around the needle) the other times I threaded it wrong. Double check that the machine is threaded correctly with the manual. I've missed a step here or there and it does make a difference.
Posted on Jul 29, 2009
SOURCE: thread keeps breaking on sewing machine
Probably just the needle. Try turning it 180 degrees
Posted on Sep 23, 2009
Why is the thread shredding above the needlehole on my juki lu563
are you threading the needle from the correct side
upper tension too tight
thread too old
needle alignment and timing needs adjustment
Mar 18, 2015 | Juki Sewing Machines
Thread keeps breaking
Hai, I think your thread very old or thick. Please putting some drop oil in thread. If your cloth lighter, you use small size needle and new cotton or silk thread.
Mar 13, 2014 | Juki Sewing Machines
Juki DDL 227 top needle keeps breaking
Needle breaks
1.the needle is damaged
2.the needle is not correctly inserted
3.wrong size needle for the fabric
4.the wrong foot is attached
5.the needle clamp screw is loose
6. Top tension is too tight
7. Machine could be out of time
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Oct 08, 2012 | Juki Sewing Machines
My Juki MO-655 serger will sew a few inches then the needle thread becomes disengaged in the stitch process. The machine will sew a few inches more then stops making stitches. I have cleaned the thre
Make sure you are threading the machine correctly. Make sure you are using serger thread that isn't old. Make sure you are undoing all the threads when it breaks and thread it from the beginning.
Make sure you have the right needles in their respective places. My Juki MO has two different size needles.
Sep 02, 2012 | Juki MO-655 Mechanical Sewing Machine
Having problem sewing on leather. I have a juki 555-5 and it is skipping 1 stitch every 3 inches . I bought a roller foot kit and it did not work. I am so frustrated. If any one could help it would be...
make sure to use a leather needle
needle must be inserted correctly,,the falt side of the needle must face the shaft
the groove in the needle faces away from the shaft
raise the needle bar to the highest point,,then loosen the clamp screw to remove the old needle
push the needle all the way up to the stop, or as far as it will go,then tighten the needle clamp screw
also make sure the needle & thread will work togeather
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
also clean under the needle plate where the feed dogs are
also bobbin area
Nov 20, 2010 | Juki MO-644D Mechanical Sewing Machine
The thread on my Juki machine keeps breaking when I sew. How do i fix it. Also, How can i change the thread tension
there's a tension dial with numbers-0-9 --above the needle area- the smaller the number the looser the tension--the higher the number the tighter the tension
thread breaking-try this
try rethreading the machine
thread tension to tight
needle is inserted incorrectly
the thread is either too heavy or too fine for the needle
try this & see if it helps you
Oct 26, 2010 | Juki DDL-8300
Tension settings juki mo-644d
-If the machine is threaded correctly and the thread is flossed into the tension discs,
-if the thread is high quality and not cheap thred
the top tensions should be at 5-6 and the looper tensions should be at 4-5
Be sure it is threaded correctly (follow the threading map on the inside of the front cover of machine
Also be sure you are using a size 14 or size 90 standard Schmetz needle do not use Klasse needles
as these are to short and affecdt the timing.
drtension
Apr 24, 2010 | Juki MO-644D Mechanical Sewing Machine
How do i stop juki ddl from top skipping stitches?
Hi. Skipped stitches are usually caused by a mismatch in your thread and needle. Wrong thread type, wrong needle size, or even old thread can cause skipped stitches. If all else fails, change the needle. If that doesn't work, clean the machine. Sometimes just getting rid of all the lint and giving her a good oiling does a world of good.
Let me know if this works.
Robbie
Jan 10, 2010 | Juki HZL-E80 Computerized Sewing Machine
Needle not catching thread
im no expert, just been sewing for many years, i use 2 different juki machines, i suggest looking at the needle, are we sure you have the rite size? 135/ 140? did the needle just get changed? it could be the correct one, but if its in backwards, there isn't a dimple to let the hook behind the thread, to catch it, feel free to call me, 239-895-4845, my name is devin, shop is Quality Auto Trim Inc., ill try to help you over the phone if necessary, good luck
Mar 12, 2009 | Juki Sewing Machines
Sewing Machines Logo
348 people viewed this question
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
