Question about Kenmore Refrigerators
New Kennmore side by side freezer works but refrig is warm
    Problem Solver:
  • 18 Answers
Do you hear the fan running in the back of the compartments when either door is open? The freezer side runs the fridge side and a fan transfers the cold air from the freezer to the fridge side. If the fan does not run or there is a blockage then the fridge side will not get cold of course.
Posted on Sep 29, 2009
Ge profile side by side 2005 psh25pswass small amnt of water on inside of refrig on the bottom of refrig floor on side next to freezer. vents in refrig appear to be bringing in very humid air that is
It can have an air leak, but also a clogged drain pan under the freezer evaporator coil. If the refrigerator is getting warm, then it may be another issue
Dec 17, 2014 | GE Refrigerators
Freezer cold fridge warm
sounds like the evaporator in the freezer section is iced up and you need to see if the defrost section is working correctly,then as for the warm refrige side,it sound as if the vent damper door is frozen shut or the cold control in the refrige isn't opening it to let cold air into the refrige from the freezer,if its frozen take a hand held hair dryer and remove the vent grille over it and defrost it and then check to make sure the control opens and closes it as you adjust its control in the refrige
Apr 26, 2010 | Hoover HCA391FFK Bottom Freezer...
The freezer is freezing but the refrigerator is not getting cold why?
check the damper door vent located between the refrige and freezer for being iced up and stuck shut,if cold air from freezer can't get past thid door the refrige will warm up,if this isnt the problem,adjust the refrige temp control and watch and see if this makes this door open and close as you adjust the temp of the refrige compartment
Apr 03, 2010 | Maytag MSD2756G Side by Side Refrigerator
Kenmore refrig/freezer. freezer side is cold,
Check your condenser coil (should be below the refrig.). If dirty, you can clean it with a condenser brush from Home Depot or Lowe's. Turn the appliance off while cleaning. Be careful not to damage the refrigerant tubing (copper). If this doesn't solve the problem, then there may be an issue with the defrost thermostat, defrost heater(s) or the main temperature control assembly.
Contact an appliance service company.
Feb 17, 2010 | Kenmore Refrigerators
G E side by side refrig . freezer cold but
you have a defrost system problem timer or heater or bimetal tst could have a electronic defrost timer
Aug 09, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer cold /refrigator warm . we have a side by side unit a couple of years old the freezer seems to work fine but the refrigator is warm .It don,t seem to make any funny noises and the back is clean
When the compressor is running, if the fan by the compressor and the fan inside the freezer are both running, and there is no frost on the back wall of the freezer (if there was frost would indicate a defrost issue) then check the air dampener. It is located at the very top left back side of the fresh food section. If it is not opening up, no air will flow from the freezer compartment (where all the cooling takes place) into the refrigerator section.
Jul 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer fan running non-stop+freezer icing up
very likely that either the defrost timer is not working or the defrost heater is not working.
May 04, 2009 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
My GSS22SGRE Side by Side freezer & Refrig temp is too warm
Possible the defrost thermostat is bad and need to be replaced. Not allowing the evaporator coil ice buildup to melt , which acts like an insulation and restricts the air flow in the freezer compartment.
Jul 31, 2017 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer cold refrig warm
4 yr old sears side by side...not cold in freeze or frig side
May 21, 2008 | Frigidaire FRS26ZSG
Refrigerators Logo
93 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
