hi,
More than likely you've got an iced up evaporater. If you look in the lower section of the freezer on the back wall, is the wall frosty or icy looking? The only way to defrost this is by taking the back wall out of the freezer and using a hair dryer on it (being careful not to melt the plastic liner) or to just empty the whole thing and let it sit with the doors open for a few days. Be prepared for water to leak out from under it however as the ice melts and overflows the drain tray in the bottom of the fridge.
this will help you to fix ice maker http://www.bobvila.com/HowTo_Library/Fixing_an_Ice_Maker-Refrigerator-F2155.html
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary. most probably problem is in the door seal.......
How old is your refrigerator?
Post further comments if you need more help or information....
Good Luck!!
Thanks
Was this helpful?
Yes
No
Popular Solutions for KitchenAid KSCS25FKSS Side by
My side by side freezer is now gathering a lot of frost and won't de-frost. What could be the...
(More)
My side by side freezer is now gathering a lot of frost and won't de-frost. What could be the issue?
The icemaker works but always crushes ice. I suspect the selenoid is not making contact to open up...
(More)
The icemaker works but always crushes ice. I suspect the selenoid is not making contact to open up the chute for cubed ice. Also the light doesn't work (clearly not a burnt out bulb). This hints to a problem with the control panel, but I don't know if it's due to the wire assembly or the wire harness control mounting.
my ice maker stopped making ice and there is a red light flashing near the on off switch for the ice...
(More)
my ice maker stopped making ice and there is a red light flashing near the on off switch for the ice maker
