Question about LG enV VX9900 Cellular Phone
When I turn on my phone it says "battery is required", even though it is being powered by the battery.
Try taking the battery out and putting it back in. If it doesn't work after you've done it a few times you may to need replace either your battery or your phone depending on witch is causing the problem.
Posted on Sep 30, 2009
Braun series 5 shaver won't turn on despite charging up and the lights work
The battery may not be any good, even though the lights go on they only require a tiny amount of power, the motor on the other hand requires a lot of power, and so it will not run. Pull the razor apart and test the motor with an external battery.
Nov 07, 2016 | Braun Health & Beauty
On power up, why does it indicate 'use genuine battery', then shuts off?
If your phone does not indicate it is charging, the 'use genuine battery' message may its way of telling you the battery is defective.
Nov 23, 2015 | LG VX8350 Cellular Phone
The problem is that it intermittently won't start. Put the key in, turn the ignition "ON", and everything lights up as normal. Turn it to "START" - and nothing happens. Not even a hint at cranking. My
It sounds like you have a bad battery. Even though everything lights up, your battery doesn't have enough power to crank the engine (which requires a lot more power than the lights)
Feb 14, 2014 | Cars & Trucks
Engine wont turn over even though all dash lights work when key on.
This is the classic symptom of a bad battery. Your engine requires a lot of power to crank but the little lights in your dash require very little. if the battery is even a little drained it won't crank the engine, but everything else will seem to work fine. Either jumpstart the car (if it starts, then you likely need a new battery) or test the voltage at the battery terminal when trying to start the car. If the voltage drops below 12 volts you need a new battery (or at least a freshly charged one)
Dec 18, 2013 | 1999 BMW 5 Series
Cant turn on my nokia lumia 610 even though the battery is fully charged
If the battery is fully charged and still it does not turn on then either the power button is faulty or the phone. Did the phone get a jerk, because sometimes even a small thud can snap some connection inside as everything is so very delicate inside. Is it under warranty? if yes then Nokia Care is the answer.
Oct 24, 2013 | Nokia Lumia 610 Unlocked Black
My Samsung WB100 turns off after switch on. Got new batteries and same problem plus 'old' batteries are still good even though camera said they needed replacing after a few days minimal use.
Make sure you are using name brand high quality batteries and not some generic from China. Camera require a great deal of power to boot up.
Jan 25, 2013 | Samsung Wb1000 Digital Camera
What are other causes of a phone not turning on besides a dead battery, overheating, and freezing?
replace the battery for starters
check that the charger is putting out the correct voltage
Jun 05, 2017 | HTC HD Windows Phone 7
The phone turns itself off and wont turn on again, even after the battery has been taken out for awhile
try to clean the battery terminal/conector on your cellephone.use cotton buds with small amount of alchohol.If it still does'nt work,try to replace your battery with new one,because batteries are sometime make fool on us.Even though it still have a power within the battery,cp still doesnt open when the battery is already weak its current, or what we call the AMPERE.
Oct 21, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
I cant turn my phone on even though it is fully charged. I think the power button may be broke
You are answering your own prob. Good. Have it checked. If the battery is charged, the phone has had no falls or dips and was woking fine before, it should start even now. The power on switch is generally the culprit.
Aug 06, 2009 | Samsung J700 Cellular Phone
Trouble turning on my cell phone
I would take out the battery and keep the power button pressed for 15 seconds. After this power cycle, put the battery back in and try to turn it on.
Aug 29, 2007 | T-Mobile Dash Smartphone
LG enV VX9900 Cellular Phone Logo
141 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
