Question about Whirlpool GBS307PR Electric Single Oven
I have a whirlpool gbs307 oven and after completing a self-clean cycle and wiping it clean after it cooled, it won't heat at all. Any ideas?
  • mwietrick Oct 19, 2009
    It was the thermal fuse located at the rear of the oven - a design flaw in the oven acording to the service technition.
I have same problem and was just told by repair tech that you have to remove racks and excess spillage before doing self cleaning cycle or oven cavity overheats and trips thermal coupler. Does Whirlpool tell us this???
Posted on Nov 14, 2009
    President:
  • 267 Answers
HI,
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
thank you,
vijay
Posted on Sep 29, 2009
Hi lost the manual..need to start self cleaning
An electric oven is a great oven choice because of the advanced self-cleaning feature often available on certain models. A self-cleaning oven uses high temperatures to clean crusty baking spills and splatters and free its owner from having to use harsh chemicals to clean his oven. The following 4 steps lay out how a self-cleaning oven works.
Step 1 - Setting the Self Cleaning Mode
Depending on the style and brand of oven you own, you start the self-cleaning cycle by setting the oven's operating dial to "Clean," a function that can be as simple as setting a timer knob or pushing one or two buttons.
Step 2 - Cleaning Cycle
Once you have set the self-cleaning cycle, the oven coils-both lower and upper--will begin to heat. These self-cleaning ovens are protected from high oven temperatures damage by heavy insulation installed in their walls and door during the manufacturing process.
Step 3 - Automatic Door Lock
When the oven reaches a pre-determined temperature, the lock on the oven door engages, preventing anyone from opening the door until the oven temperature has cooled.
Step 4 - Removing Residual Ashes
Once the cleaning process is completed, including cooling, you can then remove the residual ash by wiping the bottom oven surface with a damp cloth or sponge.
Hope this helpout
May 17, 2011 | Ovens
How do I use the self cleaning option for my oven?
First remove the rack, because the extreme heat will tarnish the racks and the shinny coating will will no longer be there, press the cleaning button, and leave it this cycle will take approx.. 3-1/2 to 4- hours to clean and cool down will take another hour, it will tell you that it is cooling and also the the cleaning is complete. so let the cycle complete and all you will need to do is wipe off some residue once it is complete.
Nov 14, 2009 | GE Ovens
I have a self cleaning whirlpool oven. It caught on fire and I turned off the cycle. Is it safe to use the oven? And can I just clean it manually?
I highly recommend that you wipe it out as often as possible to prevent using the self clean mode. It heats to over 800 degrees and this usually takes out electronic parts. It should be fine to use your oven now. I would heat it and watch it to be sure there are no more flames. Hope this helps!
Aug 24, 2009 | Ovens
Self cleaning oven won't start self clean mode
NO IN ORDER TO ENGAGE IN SELF CLEANING THE LOCK MUST FIRST ENGAGE. DOOR LOCK ASSEMBLY FAILURE
Apr 27, 2009 | Whirlpool RBD305PD Electric Double Oven
I have a GBS307 built-in oven stopped heating
It has been a while since he was there. Did you have to replace a board? Hopefully, it is fixed.
Dec 17, 2008 | Whirlpool RBS245PDS Electric Single Oven
Oven wont work after self clean
I have a Whirlpool MOD. RBS275PDB17 single electric self-cleaning oven; although the manual is generic, it specifies, "When the cycle is completed and the oven cools, "End" will appear on the lower oven display and "LOCKED' will disappear" and "To Stop Self-Clean any time: Press UPPER/OFF, LOWER/OFF or OFF/CANCEL. If the oven temperature is too high, the door will remain locked. It will not unlock until the oven cools." Has your oven had time to cool?
Jun 13, 2008 | Whirlpool RBS275PD Electric Single Oven
Whirlpool RF367LXS Ceramic Glass Range not working
Almost every time I run the SELF CLEAN cycle on my Whirlpool Self Cleaning range, it fails to function after completing the self clean cycle, even though it completes the cycle of cleaning and unlocks the door. What I do to solve the problem, I power off the BREAKER for the range at the main electrical panel in the house and wait 30 seconds, then power on....and the whole system works just fine until the next time I clean it. This has been a problem from the beginning. My theory is that the electronics get heated up and, like a computer, the system stalls out and needs a complete hard reboot. Good luck!
Feb 02, 2008 | Ovens
Whirlpool GBS307PR Electric Single Oven Logo
490 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
