Question about JBL 6-1/2\ Round Coaxial Speaker By Prospec Electronics" Speaker
I have a jbl 525 powered speaker but it wont play full range it will come on and out, playing only the highs at times
    Novelist:
  • 133 Answers
Check the incorporated capacitors (if any), also inspect the braid speaker wire on the bass speakers (i understand that these are cutting out).
The braid wires are located between the speaker connection terminal and the speaker cone - if these are damaged or broken, this can cause the speaker to cut out intermittently. To see if this is the case, try to push the speaker membrane gently inward when the speaker cuts out - if it momentarily regains function, then the braid is almost certainly damaged.
Braid wires can be resoldered, but it's not a very easy task because of the structure of the braid, which makes it difficult to clean and solder.
You should have it repaired by someone with good soldering skills or at a speaker repair shop, otherwise the alternative is to replace the speaker.
regards
Triarcuate
Posted on Sep 29, 2009
My JBL soundbar starts making heavy bass sounds 10 minutes after I start playing music. how can I sort that?
Front and surround power amplifier section circuit fault. Mid and high frequencies loss. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Search the site by type in the "brand name" of your device, in the "Search box at the top right of the Homepage" to get gathered related posts
Nov 12, 2016 | JBL Audio Players & Recorders
Jbl speakers turn off on their own
Sounds like you have them plugged into the wrong jack
Jan 01, 2013 | JBL Jembe Two-piece Entertainment Speakers
Jbl jrx 100 popping
Check all electrolytic capacitors on the amp circuit board.
Jun 05, 2012 | JBL JRX-118SP Subwoofer
My JBL plays but it cuts the play back frequently like it plays and stops, plays and stops, plays and stops so on .Whats the problem. Please help
Until this is fixed, I would not use it or you may blow up a speaker... Make sure you check that you are using BALANCED audio interconnect cables, either XLR or TRS balanced cables AND that ALL interconnected equipment is poowered by the SAME receptacle... yes you have to run extension cords, but the pro's do it to avoid ground bounce damage to their equipment. Use ONLY three wire power cords.
Aug 06, 2011 | JBL New Jbl Prx512m 12 Powered Monitor...
Does onkyo HT-s3100 supports 4 Ohms speakers from JBL(control 1)
Palaboy is incorrect. JBL Control 1 speakers are 4 Ohm 150 watt speakers. He's probably thinking of the Control 1x speakers which are 8 ohm 80 watt speakers.
If you hook your Control 1s to that Onkyo, it won't sound great and could cause the receiver to overheat and trip the protection circuit if played at high volume.
Aug 11, 2009 | Onkyo HT-S3100 Receiver
I have a pair of peavey sp5 speakers that i can not get to play full range they will play high and low but not full range
what sort of amp are you driving these with?
is the amp set up with buit in x-overs?
check these settings?
Boxs should be configured already for full range from manufacture unless they have been altered since purchase,
Whats really funny is that your getting either tops or bottoms from them but not both at the same time......hmmmm
they are supposed to be full range cabinets,very good ones at that.
I suspect the amp is either faulty or x-overs are poked.
some times leads are a also the blame too.poor connections,etc.
if x-over is poked you will hear an ear peircing noise and a paper duding noise if the cones were gone,like a giant transistor radio with no bass and a very high pitched trebble burning a hole in your head,
Ok heres a cheap test,
Take the speakers to another amp and test them,
If same result then you know the answer
Let me know the results thanks
Jul 20, 2008 | Peavey CH1 Speaker
Trying to hook up jbl sr4732 speakers the highs are to loud compaird to the bass or lows. im only using a onkio with a 100 watt per speaker.
These JBL speakers are not made for a home stereo reciever. It could be part of the problem.
I do know that they have a high frequency input and a full range input on each speaker.
I am going to guess that maybe you have them connected to the high frequency input.
Are you using 1/4 inch jacks connecting to the input of the speakers?
I don't remember these speakers having a input for wires.
You may have another issue using these speakers with that reciever.
The JBL speakers are 4 ohms each, it is very likely that the onkyo requires 8 ohm speakers.
Look on the back of the Onkyo where the speaker jacks are at and see if it says anything about the minimum impeadance.
The impeadance is the ohms. Most home recievers are not designed for anything less than 8 ohms. Some are, but most are not.
Using 4 ohm speakers on a system that requires 8 ohm speakers can cause damage to the reciever. Mostly at higher volume levels, it will cause the reciever to overheat and shut off, maybe short out a channel. It pulls 2 times the amount of current thru the output transistors as 8 ohm speakers.
Let me know if this helps you or if you need more help.
Jun 18, 2008 | Audio Players & Recorders
DVD WONT PLAY
same problem-put it in for repair -advised dvd tray is a one piece assy and it was faulty-requiring full assy rplcmnt @plus£150
nuff said=bought a new dvd
Feb 07, 2007 | Pioneer DV-525
JBL 6-1/2\ Round Coaxial Speaker  By Prospec Electronics" Speaker Logo
242 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
