Question about Bon Tool Construction Book Store Co. Plasterer's Tool Kit
Method on how to attach cornice - Bon Tool Construction Book Store Co. Plasterer's Tool Kit
  • 101 Answers
What type cornice? As there are many types for many window coverings and type of walls such as drywall, brick and plaster but any Ace, Home Depot or any hardware store will carry anchors for you application
Posted on Sep 29, 2009
Gaarmin 2620
Hi hummer49....Your GPS Software needs to be updated by clicking on the following URL: http://www8.garmin.com/products/webupdater/howtoinstall.jsp If you have misplaced your Owner's Manual, you may download a copy by clicking on the following URL: http://www8.garmin.com/manuals/439_OwnersManual.pdf Please update your post if you need further assistance and also to update me on your progress....good luck my friend
Aug 06, 2007 | Garmin StreetPilot 2620 GPS Receiver
How do I cut the the corners(miter) of Polystyrene cornice.
Try making the cut with the rear of the cornice against the rear of the miter box rather than the front as you would for cutting regular (not crown) molding. I hope you are not using a circular saw to cut polystyrene.
Dec 05, 2014 | Saws
Cornice mitre angle
Try this ... http://www.constructionknowledge.net/public_domain_documents/Div_6_Woods_Plastics/Partial%20Carpentry%20pdfs/Finishing_Roofs_NAVEDTRA_14044.pdf
Nov 25, 2013 | Makita 10" Dual Bevel Sliding Compound...
Need to fit a tall cornice on a new kitchen but my sliding mitre saw splinters the cornice
You need much smaller teeth and pitch for softer materials. Hardware stores have a list of types of blades for Stone, wood, plaster, laminates, etc. Your service manual for the saw should have this info also, as it depends on the diameter of the saw as well. If all else fails, new blades are printed with their optimum use, check each one in a self serve store.
Cheers.
May 06, 2010 | Saws
Need new hard drive
If it is the CF version you can pick up a compact flash drive from EBAY by typing "Garmin 2620 CF" and the options will come up. However, if it is the cornice drive version getting a new drive is near impossible. I purchased a Phillips HDD 060 MP3 player from E-Bay for $28 as it had a 1.5GB Cornice drive in it already formatted for Windows. This worked and I just used Map Source to reinstall the maps. I've ordered 2 other MP3 players to see if they have a drive and can be used. If so I will post them. I am almost certain the RIO Nitrus has the 1.5GB drive in it; however I am not certain it is formatted for Windows. There isn't anyway to format them without a device to read the drive format as Cornice drives are a proprietary interface and the company being out of business has put a damper on replacement parts and tools to be able to try to format or fix drive problems.
To change that drive is 6 screws for the back case, pull it apart, but be careful as to not rip apart the ZIF cables that connect the back to the front. Disconnect one side of the ZIF cables (there are two) and then the ground connector and other 3 screws holding the circuit board to the back of the unit. There are 4 screws securing the Cornice drive housing, remove those and disconnect the ZIF connector on the Cornice drive. When you reinstall the drive reverse the process and you're good. After restarting there will be no maps, but the system should start up (not loop as before with the bad Cornice drive). If it doesn't then the replacement drive you purchased used is probably bad too, or wasn't installed properly. A quick check using Menu Find (holding them both down during startup) will provide a diagnostic and after about 1 minute the drive information will show up. If it does then the drive is working. Let me know if you have any additional questions and good luck.
Feb 24, 2010 | Garmin StreetPilot 2620 GPS Receiver
Need a replacement HDD for garmin 2620. It came with a Cornice 2GB drive. Anyone still make a drive that is compatabile?
There are no drives manufactured that are compatible. The interface is proprietary and the ZIF cable is unlike anything used with microdrives today. Your best bet is to try to find another device still working that used a 1.5GB Cornice hard disk drive like the Phillips HDD060 or the RIO MP3 1.5GB player. There are several others as well you might find; but the Phillips HDD060 is what I used to fix mine and it worked as a direct replacement. I picked it up on EBAY for $25 in May of 2010.
Dec 26, 2009 | Garmin StreetPilot 2620 GPS Receiver
Can I change the hard drive in my Garmin 2620 to flash memory? My 2620 does not have a flap on the side like the 2610.
No, it seems like its soldered in there. I took mine appart to check it out hoping i could take it out, connect it to a computer with a special cable, and Copy it to a bigger drive using (Ghost) or somthing, then putting it back in.
I wish Garmin would make it easier for you back up the hard drive and made it easier to swap the drive out if you wanted to.
Mar 20, 2008 | Garmin StreetPilot 2620 GPS Receiver
Won't boot up
I have a same problem, and I think I can fix it, may be not. Any how, I bought a cornice drive on eBay and as soon I will get it. I will load my maps on to it with usb connector after that I take it a part and remove it from its case. Then I will take my Garmin Streetpilot 2620 apart remove the old cornice drive and install the new drive. I suspect it will work like a charm. To check your GPS at boot push and hold "menu-find" buttons simultaneously and you will get a screen to verify your problematic cornice drive.59c5167.jpg
Jan 24, 2008 | Garmin StreetPilot 2620 GPS Receiver
Most likely your hard drive is gone bad. Push "menu+find" buttons then turn on, you will get diagnostic screen, it will show if your cornice drive is bad. It will say"Cornice Dive removed"4f3efc6.jpg
Sep 23, 2007 | Garmin StreetPilot 2620 GPS Receiver
Bon Tool Construction Book Store Co. Plasterer's Tool Kit Logo
121 people viewed this question
Top Bon Tool Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Bon Tool Measuring Tool and Sensor Expert? Answer questions, earn points and help others
