Try to open the rear access door of the printer and see if our can pull the paper from there. Make sure that you pull it gently. It would help while you are gently pulling, the paper, turn the rollers as well to the right direction.
If you have any questions, please don't hesitate to ask. Good luck and hope this helps.
Used card stock in manual feeder. Paper jammed. Removed paper. Now no print on copies. Toner ok....
(More)
Used card stock in manual feeder. Paper jammed. Removed paper. Now no print on copies. Toner ok. Paper goes through ok, just not images on paper. Have Canon Imageclass mf 6530
When I make a copy with our machine, it goes through all the motions, but nothing comes out on the...
(More)
When I make a copy with our machine, it goes through all the motions, but nothing comes out on the paper - any thoughts? (yes, the original has been placed in the machine correctly.
Canon ImageClass MF6580 prints blank pages in copier mode and pc mode. Changed multiple 106...
(More)
Canon ImageClass MF6580 prints blank pages in copier mode and pc mode. Changed multiple 106 cartridges with same result.
