Question about HP Computers & Internet
I want to reset my computer to a previous date because i hit a download that reconfigured my homepage settings?
  • HP Master
  • 3,051 Answers
Hello there:
go to start than go to all programs
now look towards the top left side and you will see accessories now look for system tools , once you open system tools you will see restore towards the bottom of the list simply click on it and you can start the process from there ok?
hope that is verry helpfull and easy to understand
best regards michael
Posted on Sep 29, 2009
How to disable HDD Bios password in dell Optiplex 990?
The easy way to clear the bios password and reset bios is to take out the bios battery and start computer for about 10 seconds and then turn it back off and replace the battery. When you turn it back on you may need to go into the bios and reset everything the way you want it, and don't forget to rest the time and date.
You are welcome
Aug 30, 2015 | Dell Computers & Internet
Tip
How to Configure your Linksys router with wireless security
Launch your Internet Explorer, Netscape or your Mozilla.
On the Address, Search or URL, type: http://192.168.1.1, then hit Enter/Return. A login screen will appear. Type admin for the password and leave the username blank or empty then hit “OK”.
Note: If it doesn’t take admin as the password you might have changed it when you have ran the RUN ME FIRST CD that came with the router so try other passwords.
If you cannot remember the password, I regret to tell you but, you have to reset the router and, reconfigure it again. Next time, remember the password to avoid unnecessary reset and reconfiguration.
To reset the router to factory default
1] Press and hold the reset button for 30 sec., after that
2] Unplug the power keep holding down the reset button for another 30 sec.
3] Then, plug back the power keep holding down the reset button for 30sec., after that
4] Release the reset button.
Note: Configuring WEP in the router varies depending on the model number and firmware version of your Linksys Router.
Cisco Interface (If your Setup page has a Cisco Logo)
Go to Wireless Tab > Wireless Security > Click the drop down arrow then select WEP:
Regular Linksys Router Interface (If your Setup page has a no Cisco Logo)
Under Setup > Click WEP Key Settings or Edit WEP Key Settings
Using passphrase 64bit
Encryption LEVEL 64bit > type a passphrase > click Generate > copy key1 on a piece of paper (10hex character). Then hit Apply or Save Settings.
For manual key entry of 64bit encryption:
Encryption LEVEL: 64bit > Under Key 1 type a 10 digit character from A-F and 0-9.
(e.g.: A0B3F58C9E, 0123456789, ABCDEFABCD). Then hit Apply or Save Settings.
Using passphrase 128bit
Encryption LEVEL128bit > type a passphrase > click Generate > copy key1 on a piece of paper (26hex character). Then hit Apply or Save Settings.
For manual key entry of 128bit encryption:
Encryption LEVEL: 128bit > Under Key 1 type a 26 digit character from A-F and 0-9.
(e.g.:0123456789ABCDEF9874561230, 012345678901234567890123456, ABCDEFABCDABCDEFABCDABCDEF).
If you want better security for Vista computers, you may want to select WPA personal (WPA-PSK) under security > set the Algorithm to TKIP and type your personal security code (any code you want, any characters)
on Jan 06, 2010 | Computers & Internet
I am unable to locate the key code for the WRT160N. when I try to go through the ipaddress admin as user and password will not work.
If you have not changed the password previously, leave the user name blank and use the password "admin".
If you have changed the password, you will have to reset the router and reconfigure it.
To reset the router using the reset button, use these steps:
  1. Look for the red reset button at the back of the router.
  2. Press and hold the reset button for approximately 5 seconds.
Thi will set it back to the factory defaults. It will need to be reconfigured.
Mar 23, 2011 | Linksys WRT160N Wireless Router
Forgot mynetwork security key and I am trying to connect my daughters computer to the internet.
You'll need to reset the router then, unless someone else knows it, or it's printed on the router somewhere. There's a small reset button on the back, hold it in for 30 secs, you may need a pencil or something. Then you have to set up the router again. At least it's good practice and you won't forget it again in a hurry ;-) hopefully anyway.
Nov 27, 2010 | NetGear WGR614 Wireless Router
I downloaded another program & it took over my homepage. This new homepage does not have any tools or other options at the top of the page. I would like to reset my homepage to google the way it was...
Try F11 first. See if the top section comes back.Then look under tools, Internet options, and set your home page. Spyware causes this, so check out your system. http://spywaretruth.net
Oct 31, 2010 | Computers & Internet
Trying to copy a document. I'ts 8.5 x 11. It's only copying the upper right corner of the document. Can't figure out why. Help.
Reset the printer to default settings.
  1. Press Setup.
  2. Go to Defaults.
  3. Go to Set Defaults.
  4. Select Use Factory.
  5. Hit Ok to reset the printer to factory default settings.
  6. Reconfigure the printer with the printer settings (Country, Time, Date, etc.)
  7. Try copying.
NOTE: Wireless connection won't be affected when resetting printer to default settings.
Oct 12, 2010 | Lexmark X6650 4-In-One Wireless InkJet...
I have a hp notebook laptop. i accidently made google my homepage. how do i make the original "hp homepage" my homepage again?
go into your browser's setting to change or set homepage for that browser. there may even be a "reset to default (or previous)" setting, otherwise you will need to manually enter the web page you want. Note: many software installations change your homepage against your wishes and without asking your permission. Use good antivirus, firewall, and spyware prevention programs to avoid this.
Sep 13, 2010 | Computers & Internet
All lights are on they are not blinking
Has this device previously worked correctly?
If it has you should try a reset. Log on to the user interface from a pc that is connected to the router and select the reboot option. Alternatively, just turn the power supply to the router off, leave for ten seconds and then turn power back on.
If that does not work post another comment here.
Mar 28, 2010 | Linksys Wireless-G Broadband Router
Reset laptop system settings
Do a search of your files and type in System Restore. Then chose factory settings, or you can do this by shutting down the computer and turning it back on and continue to hit F8 until the screen pops up
Feb 04, 2009 | Toshiba Satellite A215-S7422 Notebook
Very slow, or no connection to internet, on wired computer, not wireless one
Yes, it would be best to reconfigure it. Try the following but note.. resetting the router will erase all previously given settings.
First, reset the router - when the unit is on, press the reset button (using a paper clip) for 20 seconds then let go of the button. Once the WLAN light is solid, it means that router has rebooted.
Go to a computer wired to the router and open Internet Explorer, enter http://192.168.0.1 on the address bar. Enter admin for the username and leave the password blank.
Once you're in the Dlink page, this is where you can configure your Internet and Wireless settings again. Just run through the setup process (as if you just got the device out it's box).
Nov 06, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
Computers & Internet Logo
62 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
