Question about Kenmore 50522 / 50524 Side by Side Refrigerator
Water/Ice Dispensers not working.
Thanks in advance for your help!
This refrigerator came with a house I bought, sans manual. The water and ice dispensers have never worked for me. Hear a click and then a hum, get a dribble then a drip. Supply definitely gets water (but at high enough pressure I don't know...) from a reverse osmosis system under sink about 15 feet away. Refrigerator has filter system of its own as well. Refrigerator has 4(!) solenoid valves for the water and ice, all measure about 350 ohms resistance across contacts. I'm confused by how this site handles product IDs, I think it would be #50692 here, but the model # is: 596.50692000
  • Kyle Dec 19, 2007
    Thank you, a good suggestion, and something I could have added. Running the water dispenser with the filter off produces no water at the filter inlet/outlet opening in the fridge. Solenoid valves 1 & 2 are humming/buzzing while activating dispenser lever.
    I am guessing (even with the back covers off) at the routing for the water and ice dispensers, since much of the water tubing is hidden, and there are a lot of lines to trace. My guess is that the setup is as follows: inlet>>solenoid valves 1 & 2>>filter inside fridge>>solenoid valves 3 & 4>>dispenser feeds.
    My biggest questions are:
    1) Is there a minimum water pressure that must be applied at the inlet for the whole system to work?
    2) How do I test solenoid valves for proper operation?
    Sergeant:
    Champion:
  • 262 Answers
See if you have a filter in the ref it could be stopped up too
Posted on Dec 19, 2007
Icemaker will not make, cold water works fine, have changed inside filter nd outside filter I added before I knew there was one inside
Refrigerators with both ice and water dispensers have a dual port electric water inlet valve. This inlet valve is the plastic part usually on the back of the refrigerator where the house water supply connects to. This dual valve has 2 electric coils that open to let water in depending on if you want water to a glass or if the icemaker needs to fill with water. Your problem seems to be the half that fills the icemaker may be bad. The valve comes as 1 complete part for both water and ice.
May 09, 2015 | Refrigerators
Ice tray not filling
Open your freezer and remove the ice bin. You will see the mechanism and the tray that fills with water to make the cubes. On the left there should be a rocker switch that turns the ice maker on and off with a green light that tells you if its on or not, under the ice cobe tray there is a small paddle that should move, give it a wiggle. On the right you will see the wire for the ice maker, make sure that it is plugged in. Once the icemaker starts working (little green light comes on) you should have ice within 24 hours. You may need to remove the ice bin and a
small plastic louvered cover above it.
Hope this helps.
Jun 23, 2010 | GE Profile PSW26P Stainless Steel Side by...
Whirlpool Side by Side Bad Water Taste
Most "new" fridges with water dispensers and ice instruct the consumer in there manuals to "bleed" the reservoir by running a couple of large pictures of water thru it. I usually recommend dumping the first few harvest's of ice as well (I believe this is also mentioned in most manuals too). once that is done the water should be fine as any contaminants in the system/reservoir should be gone. you may try changing the filter after this, but it shouldn't be necessary. most ice makers do not have there supply water travel thru the water dispenser reservoir however. the water filling the ice tray should have no baring on the water you dispense into a glass to consume.
hope that helps.
good luck
Sep 27, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Kenmore Elite refrigerator ice and water dispensers not working
check for a child lockout button it will look like a tiny padlock ,press and hold for 3 sec.(could be the freezer door light switch)
Jul 24, 2009 | Refrigerators
Ice Maker not working
Get me the model number. Put tap water in ice maker tray and make sure arm is down. Let it freeze. Wait and see if the ice will drop, this should allow water to come into the ice maker for another run. Let me know, Thanks, Sea Breeze
Apr 27, 2009 | Whirlpool GS6NBEXR Side by Side...
KitchenAid door ice and water dispensers don't work
Hi
If  the ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Please do rate the solution as "FixYa" and revert for further assistance.
Thanks
Rylee
Mar 31, 2009 | KitchenAid KSRG22FK Side by Side...
Water & Ice dispenser quit on Kenmore 106.9535110
recheck the electical connection at upper frz door hindge sometime a wire could be pushed out but check to see that the control lock was not set by accident
Dec 11, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerator Ice maker not working
my ge refrigerator stop making ice a week ago, water dispenser still works.
May 15, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice/Water Dispenser Not Working...
suspect you didnt connect plug and socket wiring at top of door properly
Mar 19, 2007 | Whirlpool GS6SHAXMQ Side by Side...
No ice or water from dispensers
Womers, make sure there is not a lock-out on the dispensor panel. If there is, hold it in for 5 seconds and see if the dispensors come alive. Because both water and ice are not working, I would think you have a dispenser board issue. Catriver..post back.
Sep 26, 2006 | Whirlpool GS5SHAXN Side by Side...
Kenmore 50522 / 50524 Side by Side Refrigerator Logo
101 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
