Question about Fagor 24 in. FI-48W Dishwasher
HELLO WE ARE HAVING fAGOR DISH WASHER MODEL FI-48 AR FRONT LOADED TYPE. I AM SEARCHING FOR THE VALVE,SWITCH & TIMER FOR THIS MACHINE. PLEASE PROVIDE THE PART LIAST OR DETAILS TO GET IT. THANKS AND REGARDS
  • 63 Answers
Go to www.repairclinic.com. You will need the model number. You will see all the parts available for this unit. Good luck.
Posted on Sep 29, 2009
Describe your 44832 \ 44834 \ 44836 Front Load Washer Problem The HF light is on and will not turn off even after the water pressure problem has been fixed and the unit was unplugged and plugged back in
Hello & Welcome to FixYa
FH error is displayed when the control detects no water entering the machine. To clear this error press and hold the PAUSE/CANCEL button twice. You can then check if the water inlet valve is fine and not clogged with foreign particles, try to clean it. If the water inlet valve appears to be fine then check if the pressure switch hose is properly connected to the pressure switch & tub. Please get back to me if you have any questions.
Kevin
Sep 07, 2011 | Kenmore 44832 Front Load Washer
Tip
F02 and F09 - valid for Whirlpool Duet front load washer, HE3, HE3T Kenmore,...
Hi.
This tip is valid for valid for Whirlpool Duet front load washer, HE3, HE3T Kenmore,Fagor, amd more washers built by Whirlpool group.
F02 means that there is a drain problem, and F09 is overflow condition. When you get both error , it is usually because of a faulty pressure switch. Better testing the drain system as described below , before replacing the pressure switch..
To start try clearing the error by disconnecting the power cord or tripping the circuit breaker for five minutes. If you can clear the error, then the problem was just temporary.
The drain pump must be accessed as the drain hose is probably clogged. Also drain pump must be tested and eventually replaced.
If you get the error , but there is no water inside, and drain system is working correctly, then test and eventually replace the water level pressure switch, that determines when to start/stop fillng and drain.
If the drain lines are not clogged, the drain pump can be tested by reading ohms at solenoid (contacts on valve), and by energizing the pump directly.
If the pump is fine, then test the pressure switch by jumping its contacts, and advancing cycle to drain to avoid overfilling.
If you get both the codes, the cause is usually the pressure switch
Since one of the codes is overfilling, check if the inlet valve is opening and closing during the cycle, by observing if water starts and stops flowing into the machine, or by reading volts at inlet valve or at electronic control contacts. If the valve stays open or leaks with no volts from timer, then the valve is faulty. If timer is opening the valve while draining, then the timer board is probably faulty.
If water and sensor are OK, then it can be a problem with wiring or control board. Electronic control board causing this error is not common.
Test all other parts first.
You can find parts and diagrams by entering model number here.
Test and repair must be done by a trained person. Call the phone number listed on the user manual if you need to contact a qualified technician.
Regards.
on Mar 25, 2010 | Washing Machines
The washer was giving F and H warnings I may have had too many clothes for one load. Thank you Kenmore Elite front load washer
Kevin
Jun 01, 2011 | Kenmore Elite 45986 Front Load Washer
Washer stops and post H F flashing alternately on display, what is the problem?
Kevin
Mar 09, 2011 | Kenmore Front Load Washer
Kenmore front load washer model# c45072 can't find mixing valve replacement , any sources
Here is a site that might help, Can you recheck your model # when I did a search It didn't come up.
Retype the model # where I typed it and do a new search..... Good Luck
http://www.searspartsdirect.com/partsdirect/part-model/%20c45072?pathTaken=modelSearch&prst=0&shdMod=+c45072
Feb 13, 2011 | Kenmore Front Load Washer
It wont fill up with water. an H & F keeps showing up on the front screen
Kevin
Feb 03, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washer overflowed after moving Load Capacity Switch from Super to reset and then to Large load?
On this model of washer you have 4 separate components that could cause overflowing. The water valve, pressure switch, pressure switch hose & the air dome. If you have to turn the water off to prevent overflowing, I would recommend replacing the water valve. If you can turn the timer off & the water stops overflowing, I would recommend checking the pressure switch, hose & air dome.
Jan 16, 2011 | GE Washing Machines
No instruction manual
The instructions are available in
http://www.fagor.com.au/manuals/dishwashing/versionw/FI-48W,%20FI-64W.pdf
Hope this helps. Please post a comment to say if you found this useful or not.
Apr 20, 2010 | Fagor 24 in. FI-48W Dishwasher
On my Maytag Neptune MAH-3, the water is running non-stop
check plastic hose out side of tub to pressure switch
if ok replace pressure switch
Oct 12, 2009 | Maytag Neptune Washer
No water during cycle
Check water valve if you know electricity you can test with 110 directly on water valve & see if water comes out or check valve with ohm meter.
Check water level switch this switch must work to feed power to water valve. Voltage also must go through timer. Timer last thing to check (rare).
Jun 10, 2009 | Kenmore HE2 Plus Front Load Washer
Dishwashers Logo
401 people viewed this question
Top Fagor Dishwashers Experts
dannydoesita
ray gallant
Are you a Fagor Dishwasher Expert? Answer questions, earn points and help others
