Question about LG DLG5932W Gas Dryer
My LG DLG0332W bought at Best Buy 6 yrs ago stopped drying. The gas "burner does not kick on even when the exhaust line is pulled off and clear. Cehcekd that gas line and it is in the on positions. Is there an igniter(electric starter) that might need to be replaced
  • 61 Answers
Replace ignitor
Posted on Sep 30, 2009
Testimonial: "Thanks, same call I made earlier I hope that it is the igniter. I ordered the $33.00 part this afternoon and had to pay another $30 for 2-day shipping"
LG dlg0332W gas lights up for 4 seconds and goes out for 5 minutes and repeats
It sounds like a plugged or restricted exhaust vent or blower wheel might not b spinning, check blower and belt:)
Nov 30, 2013 | Dryers
Frigidaire dishwasher model fdb1500fls2
Sounds like the capacitor on the motor is bad,
May 26, 2013 | Dishwashers
Kenmore gas 4burner cooktop model#229c44330p001-0 when its off the pilot keeps clicking(sparking) every 5-7secondstcarthen@
Hi
There are a few things to check for: First make sure the electrode (the small metal piece that the spark comes off from) is clean and the holes in the burner are clean, use a pin or paper clip to clean out the burner holes. The next thing to check for are theignition switchesunder the surface control knobs, the switches can twist and break and keep the spark module on and the spark keeps "clicking" even when the burner is light. If every thing looks good, you may have a badsparkmodule which should be replaced as sometimes cleaning can get moisture into the surface switches; try drying them with a hair dryer to see if this will help. Hope this helps...please post back for further assistance.
Daniel
Jun 21, 2011 | Kenmore Kitchen Ranges
Hi: I have a LG DLG0332W Dryer, which is running but drying. I cleared all the lint areas still nothing. Is there anything I can do, I am pretty handy. Thank You.
on the right side there is an access panel, unplug dryer, open it up and look inside you will see two wires and in the middle is a reset button, push it in and it shall dry
Feb 27, 2011 | LG DLG5932W Gas Dryer
My admiral dryer heats and tumbles but isn't drying the clothes
Hi, hope this helps; check the exhaust line (the plastic flex-line) behind the dryer for possible blockage (lint, dust, etc). I even had a bird nest, outside the house, that needed to be cleared-out (can buy cheap plastic "cages" to install on outlet to stop bird nesting in the outlet).
Jan 17, 2011 | Dryers
Hi i have a lg lrg30355st (lp gas) gas range. i
Hello I have the same stove and same problem...also boiled water and now it wont stop clicking...Did you ever get yours fixed? if so, what was the problem? I unplugged every wire one by one (except purple and white ones) from the spark module and still no luck.
Jul 03, 2010 | LG Kitchen Series 30" Self-Cleaning...
Seems to work but doesnt dry
check the entire exhaust vent wok
a moister sensor detects any built up of lint and shuts the burner off to prevent fires starting
Jun 09, 2010 | LG DLG5932W Gas Dryer
Have a Maytag Dependable Care dryer. Model MDG9606AWW. The glow bar comes on, gas lights and stays on about 30 seconds, go off for about 30-60 sec. then comes back on for about 10-18 seconds. Then goes off...
Inspect the dryer venting from the rear of the dryer to the outside vent hood of the home.
If there's a restriction in the vent--the clothing in the dryer takes longer to dry.
When an LG dryer is functioning normally---the time required to dry laundry is determined by the *Sensor* located on the drum side of the lint filter housing and by the main control board.
When laundry is near dry--any Time Remaining on the control panel that is *not* needed will be eliminated---except for the last 6 minutes.
The final 6 minutes of any LG automatic cycle is for cooling down the laundry before the dryer ends the cycle.
If a dryer *counts down* to the last 6 minutes but the laundry is still not dry--the computer will allow the dryer to run until the laundry has dried or defaults (not drying within the additional time allowed).
Dryer vents that are longer than 8 feet with more than (2) 90 degree turns--can affect drying performance.
Setting the DRY LEVEL selector to *Very Dry* will solve most dryability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
Reducing the length of the vent or starting a second cycle becomes necessary to fully dry the clothing.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry.
LG gas dryers are more sensitive to venting length and air flow resistance. The gas burner can cause a rapid increase in temperature compared to an electric burner.
Rapid temperature rise in a gas dryer leads to premature burner shutdown (longer time required to dry laundry).
The gradual temperature increase of an electric element is more "forgiving" in homes where the dryer venting is less than ideal.
Apr 01, 2010 | LG DLG5932W Gas Dryer
Dryer taking too long to dry
If you can get the dryer outside, blow it out from the bottom with compressed air (using an air compressor or even a leaf blower). make sure the vent is clear and has no lint buildup. make sure the burner unit is also lint/dust free. If it is still heating, that is good news, and it is most likely a "breathing" issue. it also could be an issue with your gas pressure, however that is very unlikely. Best wishes in this project.
Oct 22, 2009 | Kenmore 73952 Gas Dryer
Not properly drying
If you remove the front cover hitting the reset switch is rather easy. However I did that the other day and only got 1 load done before it tripped again.
I just picked this dryer up used from a buddy the other day and am already having trouble. Also... It runs very loud. How loud is yours complared to the washer?
May 30, 2008 | LG DLE0332 Gas Dryer
LG DLG5932W Gas Dryer Logo
714 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
