Question about Canon MultiPASS MP730 All-In-One InkJet Printer
Canon MP730 not printing.
I ran the maintence modules. made sure here is ink. when i print, it goes thru the motions but not a dot shows up on the paper. i tried color and B&W. Print as well as copy. not a single dot.
I have a Canon MP730 and it has always worked great - until. I ran out of black ink and replaced tank. Tried to align the print head, but none of the black samples are even close to being a solid color -...
Hi There,
I believe that the printer head which feeds the ink dried out and clogged at the ink dispersal point. I'd suggest you take it to your nearest printer service capable repair center and just have them unblick the clog.
Regards,
Selk
Mar 25, 2011 | Canon MultiPASS MP730 All-In-One InkJet...
Canon MultiPass MP730 purchased 2004 NOT Printing Black INK- did: new canon ink tank inserted (never used refills) ran: printhead maintenance mannually cleaned print head w/ rubbing...
You could clean the black ink cartridge. For this you need to remove the black ink cartridge which is present in the printer. In order to clean the laser or scanner block you could use a cotton swab as it would fully clean the dirt. You need to clean the grime and the dried ink present in the printer. This would remove all the hindrances which prevent the ink from flowing. Cleaning the printer heads would also help to solve the problem.
Dec 02, 2010 | Canon Office Equipment & Supplies
Canon MP730 won't print black ink.
Hi you can try this.
To reset waste tank full error in MP730.
1. Hit the "menu": Key
2. Hit "Copy" Key
3. Hit "#" Key
4. Scroll thru the menu headings until you come to "Test Mode" - 12th heading
5. Hit the "3" button- this will bring up Eprom Clear
6. Hit "0" button
7. Hit the "Stop" button
Can only try then your printer go on longer but some time the other you will need to clean out the waste ink it inside the printer all got to be open up to do this.
Ok I have put a MP-Tools in my website for you to try out this tools are for reseting your inks plus it can do much more.
Click on the link to download it.
Click Link = http://www.4all2sell.com/reset-tools/MPTool.exe
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 15, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
Mp730 won't print color
2. Hit "Copy" Key
3. Hit "#" Key
6. Hit "0" button
Jun 23, 2009 | Canon SmartBase MP730 All-In-One InkJet...
Printer goes through print motion, but not visible print. I put a new print head in. New ink cartridges too. Printer gets message and prints, but no ink on the page. Printer window says "CHANGE H VALUE...
bi directional adjustment are not proper for that you have to go to printer setting by clicking right click printer then properties then settings the bidi adjustments.
or check for physical wear and tear of printers carriage shaft
May 01, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Canon MP730 not printing. Printhead cleaning doesn't help.
You may need new print heads. They are around $50. Or, you could do this: Take the print head out of the printer, and run warm water from the tap (not high pressure), over the ports for about 5 minutes. Ink will drop out of the jets. Dont touch the electrical contact end of this head. This may clean the head enough so it works again. If not you need a new print head.
Apr 25, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Printing problems
When I select print I can only get color it wont do black and white.I have went through all the cleanings .It sometimes says cartriges are jammed but they are not.The ink is full Im not really sure whats going on with it.
Its a Canon MP730 Thank you
Aug 21, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
My printer go thru the motions of printing a doc but comes out blank,( it will print internet stuff)
tried to check printing connecting at another computer (not networking)? icq 475653626
Sep 26, 2006 | Canon BJC S300 InkJet Printer
Canon MultiPASS MP730 All-In-One InkJet Printer Logo
82 people viewed this question
old marine
old marine
