Question about Water Heaters
I need a instrucion manual to be able to set up my power tilt on my mercucy 1979 modle 50hp i can get it to go up but it will not stay up not shore where the eires go that are coming out off the ram it self if someone could help me it would be fantasic
    President:
  • 1,462 Answers
You can get all the required manual of the mercury 1979 model with 50 HP from the below link
http://www.clymer.com/SearchResults.aspx?c=MARINE&y=1979&mid=183&mn=Mercury
You have to pay a small amount in getting this manual, SInce these manuals are very old.ITs worth getting that
Please leave me comment,if you need furthur assistance..We may hwlp you
RNJ VINODKUMAR
Posted on Sep 29, 2009
I'm temporarily staying in our RV while our house is re-furbished. The water heater is only working intermittently. Can anybody help me?
RV water heaters are mounted against an outside wall. Go outside and look for a removable cover that has a mesh vent installed.
Open this cover and the water heater should be inside.
If the water heater is propane your propane tank may be low of fuel. Also very cold weather may not let the propane produce adequate vapor to fuel the water heater. A low level of propane can make this problem worse.
If the water heater is electric, you may have too large a wattage draw from other appliances, when the water heater is trying to heat. Turn off items such as hair blowers, AC, and Microwave when the water heater is on. If a generator is providing the electricity it may not have enough output. If shore power is providing the electricity you need at least 30 AMPs.
Apr 20, 2016 | Water Water Heaters
How to clean air intake screen on kenmore power miser 6 hot water heater
Kenmore is AO Smith.
Set this brand water heater on bricks for ez access to arrestor screen located on bottom.
Air intake located on bottom of unit, and should be accessible without removing combustion parts. Use feather duster, or compressed air.
Copy following links for specific illustrations and information:
Same information also shows in product manual .... and you didn't save that, but next time for sure.
http://waterheatertimer.org/images/Flame-trap-inspection-325.jpg
http://waterheatertimer.org/How-to-replace-thermocouple.html
http://waterheatertimer.org/How-to-maintain-water-heater.html
Sep 17, 2012 | Water Heaters
The indicator light stays on our PVS50 water heater.
You have the Robershaw wiper gas control valve.
Here are error codes and troubleshoot table for that gas control.
http://waterheatertimer.org/pdf/Robert-shaw-gas-control-error-codes-1610.pdf
Here is general service manual for power vent water heaters.
http://waterheatertimer.org/pdf/Power-vent-water-heater-service-manual.pdf
Here is general parts list for that water heater, 2009:
http://waterheatertimer.org/pdf/Rheem-power-vent-RS-parts.pdf
Aug 20, 2012 | Rheem 50 Gallon FVR NATGAS Water Heater...
A.O. SMITH MODLE S 40 FVR40 PLIT LIGHT WILL NOT STAY LIT
Copy following link for long list of pilot troubleshooting resources, including cleaning the air intake and getting more fresh air to unit, and replacing thermocouple.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#pilot
http://waterheatertimer.org/images/State-select-air-intake-400.jpg
Jul 23, 2012 | Water Heaters
Why won't the hot water stay on when the cold water is turned on?
More information is needed.
Water heater type and model is not know. Add a comment with more information.
If you have tankless water heater, the temperature could be set too high.
Other causes can include dirty combustion parts, water filter needs cleaning, heat exchanger needs to be de-limed, loose wiring, bad pressure sensor, bad PC board etc.
Instruction manual says to have professional service once per year.
Resources:
http://waterheatertimer.org/pdf/Tankless-maintenance.pdf
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Other cause can be crossover.
http://waterheatertimer.org/Crossover.html
Sep 21, 2011 | Rheem Water Heaters
The Pilot light will not stay lit
You will need to replace thermocouple or you might get by for awile by cleaning old one by lightly sanding tip and making sure it is positioned in center of pilot flame. When you light pilot hold down on pilot button until you can see the tip of thermocouple glo red. If after cleaning the pilot won't stay lit after you release button then you need to replace it. Remove thermocouplefrom gas valve and pull back on it to remove it from pilot assembly. You can buy universal replacements at most hardware stores. Try to get one at least as long as the old one. Good luck.Ihope this helps you. Thanks.
Dec 04, 2010 | Rheem 75 Gallon NGAS 70K Water Heater 6YR...
No hot water in sink and shower
it sounds like 1(or more) of the motorised valves arent working.find the valve and make sure you are getting power to it via a tester,if so then it probably needs the head on the motorised valve changed
May 04, 2010 | Rinnai Digital Remote Water Heater Control...
When loading or unloading with the Toyota Forklift it tilts without me touching the controls - it is a Toyota model 027FD25 , any suggestions why this is happening?
my past experiences with hydraulic equipment leads me to believe the valve that operates the tilt feature needs to be either rebuilt or replaced. It probably has a bad seal or O-ring in it that is allowing the hydraulic oil to pass causing the tilt to tilt. Follow the bar, or cable, from the tilt lever to the valve and that is the one to work on.
Oct 31, 2009 | Water Heaters
Water Heaters Logo
32 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
