Question about Verizon Communications BlackBerry Pearl 8130 Cell Phone - Silver
No caller id on Blackberry 8800 when using bluetooth headset
When using my Blackberry 8800, the caller id works great. Even when I'm on a call, I can see who's calling via call waiting caller id, but as soon as i have my bluetooth headset active, the headset ringer indicates the call, but the handset shows no indication that a call is coming in. It isn't until the call goes into voicemail that the call log shows who called. I use Vlingo as well as BuzzMe. I removed BuzzMe, thinking that it caused the problem, but it wasn't the case. Has anyone experienced this problem?
    Master:
  • Verizon Comm... Master
  • 515 Answers
Yes it will happen when u connect with your Bluetooth you have to use your Bluetooth only no u can see anything on your phone
Posted on May 20, 2017
5 Suggested Answers
mattballew
  • 89 Answers
SOURCE: Caller ID not working - HTC (Verizon) XV6800
Unusual problem. Check the settings to make sure theirs not a way to disable Caller ID. Give Verizon a call and see if they can find out whats going on.
Posted on Nov 25, 2008
SOURCE: Ringer delay
try copying your ringtones onto your phone instead of having them linked as ringtones from your memory card.
Posted on Feb 21, 2009
SOURCE: Blackberry Pearl 8130 not showing missed calls
I had the same problem. Most likely your phone is low on memory.
1. To check how much memory you have, go to options-->status..
2. If your phone is low on memory, delete any old messages, if you use your internet browser on your phone, clear the browser history and cookies. Also, delete any programs/apps you are not using. This will free up a lot of memory.
3. You can also run memory cleaner- Go to: options-->security options-->enable cleaning and check show on home screen.. Then click the icon to run it from the home screen.
4. Try removing the phone's battery for 10 minutes, putting it back in, and restarting the phone.
Posted on Apr 15, 2009
SOURCE: Caller ID does not show up
go to the settings>phone settings>calleridentity>on
Posted on Apr 25, 2009
Does the Motorola H730 bluetooth do caller id with 4s
Hi Anonymous
The H730 does have the profile required to perform the caller Id function. You can check more specifications of the device, here:
https://www.motorola.com/moto_care/manuals/BT/H730_QSG.pdf
Regards,
Gaby
Motorola Mobility
Oct 06, 2014 | Motorola Mobility H730 Bluetooth Headset
Cannot 'pair' the HPBLU H1 to my Blackberry..? Not 'finding' it... need a users Guide... where can I get one...?
Instructions
Pair Your Blackberry with a Bluetooth Headset
Turn on Bluetooth headset and Blackberry hand-held.
Enable the Bluetooth radio by going to the options window and clicking on Bluetooth. Click on Enable Bluetooth in that window.
Add your Bluetooth headset to your Blackberry by clicking on Add Device in the Bluetooth window.
Find and select the name of your Bluetooth headset from the list that appears. The Blackberry will search for all Bluetooth devices within range, so other devices might show up on the list.
Click Activate Bluetooth device if you receive a call and the Bluetooth headset does not pick up automatically.
Use your Bluetooth Headset with your Blackberry
Make sure the Bluetooth radio on your Blackberry is turned on before you try to use your Bluetooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the handheld.
Tips & Warnings
Pair your Blackberry with any Bluetooth-enabled device using the same steps as those for connecting a Bluetooth headset.
Remove your Bluetooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Feb 23, 2011 | Cellular Innovations HFBLUH1 Bluetooth...
I AM NOT ABLE TO PAIR JABRA BT135 WITH MY BLACKBERRY 9700. WHAT SHALL I DO?
Hi,Instructions on how to pair blue tooth device with black berry.
Tips & Warnings
Have a nice day .
Feb 16, 2011 | Jabra BT125 Headset
My Bluetooth headset's microphone stopped working
Same Problem Here. Restored the 8220 flipphone to factory settings. Dint work either.
Sep 24, 2009 | Jabra BT250 Consumer Headset
I have a GE 21518 Bluetooth Telephone adapter. If
Caller ID is only sent to devices plugged directly into the "PHONE" jack on the back of the 21518. I'm guessing your TV DVR or Cable Box is connected directly to the real phone line. Maybe you need an RJ-11 splitter so you can plug both your phone AND the cable box in to the "PHONE" output of the 21518. I appologize if you've already tried this.
Mar 01, 2009 | GE Bluetooth In-ear Headset Wireless...
Can't hear anything in my bluetooth headset, mic is working
Go to this page, it will answer any question concerning the blueant .. including pairing to your phone .. activating your blueant etc http://www.blueant.com.au/index.php
Jan 28, 2009 | RIM BlackBerry Curve 8310 Smartphone
Blackberry Pearl Sound
Assuming you have the audio volume turned up, do you have a bluetooth headset? Check the Bluetooth options to make sure there are no associated bluetooth devices (or just turn bluetooth off).
If that still doesn't work, try clicking the trackwheel and seeing if it says "Mute" or "Unmute" respectively.
If you still can't hear the callers voice, you may have a defective earpiece in the phone and it's time for repair. If you don't have a bluetooth headset, you can try to use one of those to hold a conversation. I have my bluetooth headset around my neck at all times, I can't stand talking without it. As an added bonus, people who can't see my earpiece in my ear thinks I'm talking to myself.
Oct 17, 2008 | RIM BlackBerry Pearl 8100
Blackberry 8800 headphones aren't working
The 8800 does not support the stereo function on headphones.
Here is the ATT thread: http://forums.wireless.att.com/cng/board/message?board.id=rim&thread.id=22479
Jun 06, 2008 | RIM BlackBerry 8100 HS-655 Bluetooth...
H670 bluetooth not working
try adding headset, select blue T. device the properties, services and check headset and apply
Apr 26, 2008 | Motorola Mobility H670 Wireless Headset
My bluetooth passkey
Passkey 0000 worked for pairing my Motorola HS850 and my Blackberry 8800. Thanks!
Dec 12, 2007 | Motorola Mobility HS850 Consumer Headset
Verizon Communications BlackBerry Pearl 8130 Cell Phone - Silver Logo
Top Verizon Communications Cell Phones Experts
Computer Repairing
Computer Repairing
Laxman Bisht
Laxman Bisht
Are you a Verizon Communications Cell Phone Expert? Answer questions, earn points and help others
