Question about Euro-Pro Sewing Machines
Euro-Pro Model 9110
My brand new sewing machine we bought in October 2007, cannot wind a bobbin. There is an error showing everytime I try and wind a bobbin. The last time I winded a bobbin it had messed up the thread. How do I fix it?
SOURCE: Elna Primula 410 Bobbin Winding Question
Wind the Bobbin
For the usual jobs, it is the best to use a medium sized thread.
2. Disengage the flywheel by unscrewing the coupling knob as far as it will go.
3. Place the bobbin on the bobbin winder, and push the bobbin winder to the right.
4. Pull out one of the spool pins and place the spool of thread on it.
5. Pass the thread through the bobbin winder tension discs, as indicated.
6. Wind the end of the thread around the bobbin by hand, in the direction indicated.
7. Wind the bobbin, at a medium speed by pressing lightly with a finger on the spool so as to stretch the thread better and thus fill the bobbin to a maximum. The full bobbin stops automatically.
8. Re-engage the flywheel by tightening the coupling knob.
9. Cut the thread and remove the bobbin from the bobbin winder by pushing the latter to the left.
Posted on Aug 23, 2008
  • 323 Answers
SOURCE: Sears Kenmore Sewing Machine Model 385. 1254180 Bobbin Won't Wind
On some of these machines when the bobbin winder is on it stops the rest of the machine from working. Push the bobbin winder mechanism to the left and see if your machine will work.
Posted on Jan 23, 2009
  • 182 Answers
SOURCE: problems winding bobbins on my singer 4622 sewing machine
I have two possible solutions:
1. you have the wrong bobbin and it doesn't grip the winder.
2. the small spring on the winder spindle is missing or bent, it is what applies pressure to the bobbin for winding.
good luck!
Posted on Jan 31, 2009
  • 3 Answers
SOURCE: Bobbin is not winding correctly
slide plate may be worn - i had the same problem. try holding down the center of the bobbin with a pin while slide plate is in the winding position.
Posted on Mar 03, 2009
SOURCE: Singer 6267 self winding bobbin winds around shaft under
I just figured out why my bobbine was winding on shaft instead of on the bobbin. first of all make sure the bobbin is setting up high enough, top of bobbin needs to be a fraction higher then the bobbin shuttle, next check to make sure there are no burrs on the bobbin, then make sure that the thear is catching in the groove (**** in top) of the bobbin. In order to get mine to wind i had to lett the tread go down and then slip the thread in the groove. also remember to leave the pressure foot up do not put it down. let me know if this helps.
Posted on Mar 08, 2009
  • 192 Answers
SOURCE: Singer Sewing Machine model 9224. Bobbin thread
If you turn the handwheel, can you see a metal ring rotating around the outer edge of the bobbin case? If not rotating, broken gear or timing belt off.
If that ring is turning, remove the needle plate and bobbin case. As this ring now rotates, you will a finger on the ring that will pass behind the needle from right to left and it should catch the thread from the eye of the needle. If this finger, the "hook" passes above the eye, you have a timing problem.
Let me know.
Posted on Feb 16, 2010
0 characters
1 Points
How to fix the operation buttons on a 9110 euro pro
check and make sure the bobbin winder has returned to it's normal position for when you sew
May 09, 2016 | Euro-Pro Shark 9110 Sewing Machine
My bobbin winder will not turn and wind the bobbin. I have taken it to a reputable repairman and he says the bobbin-winder motor has a loose pully but there is no way to get inside to fix this. Help!
Why not just buy a stand along bobbin winder device then. They are pretty common, you can get one from this website.
I have seen them cheaper than this too I think. Certainly solves the problem, just wind the bobbin on this.
Sep 02, 2011 | Euro-Pro Shark 9110 Sewing Machine
My sister just received the euro-pro 9110 as a gift but the manual is in spanish and she needs a manual in english - can you help?
This link no longer seems to exist:
This link sells the manual (language not specified, but the contents are given in English) for $8.00 (U.S.)
I cannot find a free english download - lots of broken links and circular links, though, since
"Euro-Pro" seems to have been bought by, and their web site offers no support (manuals or otherwise) for any sewing machine.
Jul 07, 2011 | Euro-Pro Shark 9110 Sewing Machine
I need to purchase a needle plate (?) the silver plate covering the bobbin for my Euro-Pro 9110.
try these sites for parts
Dec 27, 2010 | Euro-Pro Shark 9110 Sewing Machine
I have a shark euro-pro model 9110, i bought it from a seller on ebay, but didn't try to us it until the guant. was up. it only works when the for peddle is not pluged in? i took it to a repair center and...
Call Euro-Pro's customer service for sewing machines at 800-787-7395. They can walk you through some solutions and if nothing else charge a labor fee of $40 to service it. The Euro-Pro model 9110 is supposed to have a 25 year warranty so you should be able get it fixed without too much hassle.
Oct 30, 2009 | Euro-Pro 9105 Computerized Sewing Machine
Euro-Pro Shark Intelli-Sew 9110
you need a new bobbin case, only problem is finding the right one. I am currently wasting hours trying to find one for our 9110 intelli sew which has needle holes punched through it from where it jumps right out. I think lots of manufacturers know fine which parts fit the Euro-Pro but would like all of us to scrap them and go out and buy theirs!
Aug 28, 2008 | Sewing Machines
Shark 9110 won't thread bobbin
The same thing just happened to me, but I am miising a piece that fell off. Make sure there is a little metal wire piece on .the bobbin winder, if not that is your problem
Jul 23, 2008 | Euro-Pro 9120 Computerized Sewing Machine
Won't catch bobbin thread
In order to see whether or not my euro-pro 9110 had a timing issue, the service rep had me change out the needle (making sure I was using anything but a Singer brand needle--they do not work in these machines). I re-threaded the needle, took out the bobbin casing and the plastic ring encasing the bobbin, then lowered the needle to see if the hook on the metal ring holding the bobbin actually catches the thread on its own. If it doesn't catch, it's a timing issue and needs repair. They can walk you through this process of troubleshooting and set up repair if need. Call Eruo-Pro's customer service center for sewing machine service and repair at 800-798-7395
Apr 17, 2008 | Euro-Pro 8260 Mechanical Sewing Machine
Sewing Machines Logo
Top Euro-Pro Sewing Machines Experts
Bargain Box
Bargain Box
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
