Question about Radio Shack Pro-95 Handheld Scanner
Volume drops every few seconds - Radio Shack Pro-95 Handheld Scanner
    Problem Solver:
  • 10 Answers
Some circuits ust be bad it may have gotton wet try putting it in a bag of rice for awile and see if it helps
Posted on Sep 29, 2009
Screen has lines through it
Try this, but this wll also wipe all data from your phone. so back up your stuff first
Step 1 Power down the Kyocera Hydro smartphone. If the phone is frozen, pull out the battery, wait a few seconds and reinstall it to ensure the phone is off.
Step 2
Press and hold the "Volume Down" button and then hold down the "Power" button.
Step 3
Release the buttons after a few seconds when you see the Android System Recovery screen.
Step 4
Press the "Volume Down" button to highlight "Wipe Data/Factory Reset" and then press the "Power" button to select it.
Step 5
Select "Yes -- Delete All User Data."
Step 6
Select "Reboot System Now" to complete the reset.
Feb 09, 2014 | Boost Mobile Kyocera Hydro Smartphone
My pc left speaker does not work. but in other devices speaker works
click start control panel sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place icon in taskbar for any
further volume control settings you will need to right click on the speaker volume icon system select adjust volume
click start control panel sounds and audio volume advanced speakers select the appropriate speakers
from the drop down list or navigate to the device manager scroll to system devices + to expand system
speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if its a laptop on the side
you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity
clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line or use a can of compressed air specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer
or if its a desktop swap the speakers around if one still does not work its either a faulty speaker or the speaker connection
hope this helps
Aug 21, 2012 | Intel Desktop Board DG41WV Motherboard
A few drops of fruit juice got under the volume wheel and dried. Now the volume wheel won't turn easily. How do I get the volume wheel off to clean underneath?
Electrical contactsupply cleaner is best. You canto try drops of rubbing alcohol, which will clean the wheel and evaporate quickly. While you add the drop/s, turn the wheel.
Jun 04, 2012 | iHome Clock Clock Radio for iPhone iPod...
Thorn amplifier model 4044 volume control VR201 faulty.
put a few drops of "switch cleaning oil" inside the volume control by opening the cover & rotate the control a few times. you can use it on switches as well. you will see the control is working again. if that does not work, u need to replace the control pot.
Sep 26, 2011 | Audio Players & Recorders
Our beocenter 9300 will only play at a low volume (of about 4 bars). You can increase the volume a bit, to about 8 bars, but not for long. The volume drops to about 4 bars in just a few seconds. What is...
TRY REMOVING THE SPEAKER CABLES AND LISTEN ON HEADPHONES,IF THIS WORKS THEN SUSPECT SP WIRING BUT MAY STILL BE AN INTERNAL FAULT IN UNIT EITHER OUTPUT OR P SUPPLY.
Sep 09, 2010 | Bang and Olufsen Beocenter 9300 Shelf...
The volume drops every few seconds
This could be due to the connection used. Try using new higher quality cabling to connect your tv.
Jan 03, 2010 | Samsung HP-S4253 Television
Don't know how to change the clock
Hold the volume button in for a few seconds, this will activate the set up screen where the clock, scrolling info, auto-dim controls, etc are controlled from. When done, hold the volume in a few seconds again to return to normal.
Mar 11, 2009 | Sony CDX-GT320 FM / AM / XM Radio / Sirius...
TV picture blanks out, the restores
your tv has a loose board problem, its either in main board or CRT socket.
Apr 10, 2008 | Quasar SP-2719 27" TV
PHONE IS POSESSED
Let me ask. Did you drop the phone by chance? If you did, you might have broken the sim card holder. Take out your sim and start up the phone. If the phone loads up fine, it is just as I said, the sim holder. If not, I have no idea.
Dec 12, 2007 | Motorola Mobility RAZR V3
Tv turns off, volume adjusts incrementally then shuts off, screen is tinted blue
there is a defecton the small signal panel. most of the time caused by power surge..john
Aug 30, 2007 | Insignia IS-LCDTV32 32 in. Television
Radio Shack Pro-95 Handheld Scanner Logo
Top Radio Shack Radio Communications Experts
Jason
john milligan
Steve
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
