Question about Kenmore 24032\24036 Top Load Washer
Need to know what a f code on a kenmore oasis hd washer means
  • 15,935 Answers
The F1 error code on this washer indicates a Primary Control Board failure.
It is likely that the machine control board will need to be replaced to correct this problem.
The part number for the machine control board is undetermineable because you have not provided me with the exact model # of your washer.
The procedure for replacing the machine control board is provided HERE
LINK: http://media.fotki.com/1_p,wfgstgtftbtkrrdxgtqsskgwtqkq,vi/gfsfgfsgqxgfqtqtgwf/1/1303472/5961857/image55806img-or.gif
NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
There is a slight possibility that a problem with the pressure switch hose could be causing this problem.
A pinched or twisted air hose can cause this fault code.
When you open the console, check the air hose connected to the pressure switch on the machine control board.
If it is pinched or crimped, I recommend rerouting the hose to resolve this problem.
This may fix your problem without replacing the control board.
NOTE: You may want to check for this condition before ordering the control board. Most electronic control boards cannot be returned for a refund or credit.
If you find no apparent problems with the air hose on the pressure switch, then replacing the machine control board on this washer should correct your problem. There is a risk involved in replacing this part yourself.
As noted above, you could have a problem with the air pressure hose that is not apparent upon your initial inspection. A service technician would normally need to properly and thoroughly diagnose this problem before replacing the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 12, 2010
What does code F1 mean for a Kenmore Elite Oasis model 27032?
Here is a link to some good information on your error code. This should explain the error code you have.
http://www.theworldofwashers.com/2009/03/reader-mail-f1-error-code-on-kenmore.html
Nov 21, 2010 | Kenmore 27032
What does F1 code mean
A Sublime Master at the Samurai School of Appliantology recently did battle with one of these newfangled Oasis washing machines. The F1 error code was intermittent, which made it impossible to troubleshoot. Turns out there’s a service bulletin out on this problem. Come, feast your bewildered eyeballs on the wisdom of the Masters.
Read more: Recurring and Intermittent F1 Error Code on a Whirlpool / Kenmore Oasis Washer | Washer Repair | Fixitnow.com Samurai Appliance Repair Man http://fixitnow.com/wp/2009/01/25/recurring-and-intermittent-f1-error-code-on-a-whirlpool-kenmore-oasis-washer/#ixzz0vdcTKwJA
Get appliance parts at http://parts.fixitnow.com
Aug 03, 2010 | Kenmore Oasis HE 27082 Top Load Washer
What is the mean of LD code for kenmore oasis he?
See the following Whirlpool Service manual for the Oasis / Cabrio washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
Jan 22, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Need to know what 50 means --washer keeps beeping after tub fills
Please see the following Whirlpool Service Manual for their Cabrio Washer (Basically the same as the Kenmore Oasis)
50 points to an obstruction keeping the basket drum from turning freely.
Nov 08, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
F1 mean on 110.2706
on oasis u have to replace the main board
Oct 04, 2009 | Kenmore Oasis HE 27062 Top Load Washer
F1 CODE
http://forum.appliancepartspros.com/washer-repair/7591-kenmore-oasis-f1-code.html try this but I'm sorry to say you will probley need a new computer I had to with my stove pay for the guy to come out then more money for a new computer for the stove, not the answer you wanted but most likely is whats going to have to be done sorry and hope this helps
Jul 06, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
F1 error code on Kenmore Oasis He
I think there might be a recall on your washer call to see. I am not for sure that there is a recall but I a m pretty sure there is. So don't quote me on that. the f1 error code usually means that you have a bad board. f1 means that your pressure switch line is failing and this is all in your board. check your owners manual if whirlpool is not going to pay for this repair sometimes there are extended warranties in your manual
May 29, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore elite washer problem
you can use a shop wet vac on the drain hose to **** the rest of the water out then you can remove the hoses to check to see if anything is suct in hoses or pump-,mike
Apr 24, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore washer has a error code of hc
You need to switch over your hot and cold water lines. 'HC' means that your hot and cold are hooked up to the wrong inlets.
Mar 30, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Elite Oasis Washer Error Code F1
per sears unplug the washer for at least 10 min then plug back in and push pause or stop 2 time.
Mar 25, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
fordexpert
Mike Squire
Robert Rankin
