Jenn-Air JCD2295HES Side by Side Refrigerator Logo
Posted on Sep 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Jenn Air jcd2295hes refidgirator gets too cold. I
Jenn Air jcd2295hes refidgirator gets too cold. I did set the dial at one - highest temp
Borhan
Level 2:
  • Expert 109 Answers
  • Posted on Sep 29, 2009
Borhan
Expert
Level 2:
Answers
109
Questions
Helped
27725
Points
252
Set the dial to 8 / 9
Why does Our refrigerator keeps freezing everything? Even the food in the drawers are frozen. Why is that?
Check the cold control thermostat setting maybe you set it to max. put both controls on middle of whatever numbers you have on them and if its already on middle or at minimum setting still it freezing everything you need to replace to Cold Controller Thermostat
Not cold.
There is a good chance that the heater in the freezer is not working. If it is not working the coils in the freezer do not defrost and you won't be cooling either side. [cooling coils are froze up and the air fan cannot deliver cold air to either side and air fan cannot remove warm air from either side]. You might also want to check the defrost timer switch.
2answers
I have a Jenn-Air side by side refrigerator. JRSD209T. Water fills up the ice shute and runs into the floor. What stays in the freezer freezes in the chute. What do I need to change to fix this problem
From your description I'll gather you're not getting ice cubes either and need to replace the ice maker
Part # D7824706Q on the diagram labeled "Lights and Ice maker" it's item 1
This is from Sears so you can order and have it delivered to the house
http://www.searspartsdirect.com/partsdirect/part-model/Jenn-air-Parts/Refrigerator-Parts/Model-JCD2295HES/1266/0165000?pathTaken=
The freezer stopped freezing-the ice is melting and the cooling section is not getting cold.It has power lights are on but cannot adjust the temp.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
3helpful
Why are my veggies freezing even thought the temp is set to 40?
Most fridges have crisper drawers that have a selection lever on either the front or side of the drawer that allows you to select eiher veggies or meat. Veggie setting is supposed to keep the crisper drawer warmer, while Meat setting makes it the coldest possible.
If you don't have the selector slide levers, I would suggest you use the highest possible crisper drawer available, as the lower in the frdge compartment you go, the colder the air will be. That should resolve the problem you're having, other than lowering the fridge temp setting slightly.
You might notice a cold air exchange vent next to your crisper, which supplies cold air from the freezer section into the fridge section, so that could be contributing to the colder temps in the crisper where you keep your veggies.
Hope you find this Very Helpful and best regards!
2helpful
Clicking noise from JCD2295HES side-by-side refrigerator
sounds like a compressor relay check with maytag mightr be one of the recall ones
Help refridgerator has no cold air
If fan under freezer is not running and or the compressor? That will be clue to helping you resolve this. Let me know.
Icemaker is not freezing ice, freezer not freezing food,
The ice maker won't work if the freezer is warmer than 17 degrees so that's not an issue till you get the freezer cold again. I would guess that your unit is stuck in the defrost cycle. This could be the defrost timer failing. See if you can find the defrost timer in your unit and advance it by hand if possible. http://www.partselect.com/PartSearchResults.aspx?modelnum=jcd2295hes&mfgmodelnum=&fkmfgid=1&hint=defrost
Top Jenn-Air Refrigerators Experts
john h
ZJ Limited
ZJ Limited
Jose Ramirez
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
