My canon mp180 wont scan. it will go to scan mode, black, colour, but it wont do anything else not even make a noise. it does copy and print though, no scans. please help, quick!
My black and white photos will only print out in sepia. I have plenty of ink in the Cartridges of my MP610. Please help?
Two possibilities come to mind:
  1. There is a function in many printers that lets you print in the single colour of your choice. Check every tab and every "advanced..." dialog box you get when you are about to print. Then go to the printer's properties in the control panel and check whether there's anything like that
  2. Many printers let you print black with black ink, OR alternatively make black by mixing the other three colours CMY. Look for that setting in the same places and deactivate it
Feb 27, 2013 | Canon MP610 Photo All-In-One Printer
CANON PRINTER MP560 WONT PRINT IN BLACK
This is seems to be weird issue you are facing with the printer. I would like to know what is the application you are trying to print from ? Is it Microsoft word etc ? Try to type something in Notepad and print and check if the black is printed.
If you are able to print from Notepad then probably it there are chances the application you are tying to use is corrupted and might need to uninstall and reinstall
Regards,
Suhail
May 14, 2012 | Canon Office Equipment & Supplies
Canon MP180
That error code is described below:
Error Code Error indication Error condition.
5B00 Waste ink full H/W fail Replace printer.
And i would like you to refer to www.feedroller.com/Store/Service%20Manual/S100sm.pdf
Thos document has all the error codes and what needs to be done for that.
Hope my info is useful,
Thanx for using fixya.
Sep 26, 2008 | Canon PIXMA MP180 All-In-One InkJet...
Print Cartridge Problems
i have an mp170 all in one and when you fill the cartriges they dont show up as full cannon put a chip in the cartridge to con people into buying new ones try siting the cartridges in warm water for a few hours then blot the cartridge with tisue paper if it dont blot out the ink the cartride is finnished and you need a new one .To align the cartridge you flick through the menu on the printer not pc screen look for alignment page print this off then you have to pick the dark boxes on the sheet shade the bit next to it and put on your scan bed and click ok it should scan the sheet and reset the alignment
Jul 19, 2008 | Canon PIXMA MP180 All-In-One InkJet...
How come the colours end so easily
it's using the color cart to print black.
Jan 09, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Printing problem
The black cartridge printhead needs to be cleaned or replaced. Follow your printer manual instructions.
Mar 18, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Colour problem with printer
After you scan it, do you immediately print it in an image format or do you use word? If you use word i might have a tip that might help.
Before printing, click File>print>click on "Properties" and check that the grayscale printing box isn't marked, if it is unmark it and it'll print in colour.
Also anything is that, when you're scanning. After previewing your scanned piece, double check the mode, either magazine (which is in colour), Black and white or outline (i think)
That's all i have for now.
Sep 09, 2006 | Canon PIXMA MP130 All-In-One InkJet...
319 people viewed this question
jasbo
jasbo
