Question about Hitachi DV-PF2U DVD Player/VCR
I got into the ''interleaved'' video mode inadvertantly with the remote and now I get no picture and can't access the setup menu anymore...I have 3 monster cables hooked up to the video output to my Sony KV-32FS100 TV and have tried all menu selections on the TV and the Video 1 input...any ideas..how do I setup menu defaults via the remote?
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
A possible way is to make use the 3 more montser cables and connect the  Hitachi DV-PF2U using the DVD Component Video Out (Y, Cb & Cr) to the Sony KV-32FS100's VIDEO IN 4 (Y, Pb & Pr).  This is should enable the MENU to be displayed on the Sony and restore settings to default.  In some instances, this connection may prove to be of a better quality compared to the single VIDEO IN (composite).
Good luck and thank you for asking FixYa.
Posted on Sep 29, 2009
No picture
Instructions
  1. 1 Make sure the power cord is properly plugged into a wall outlet if your TV is not powering on.
  2. 2 Make sure the video and audio cables connecting your TV to external devices are secure if you are experiencing a fuzzy picture or no picture.
  3. 3 Reset the parental password if you forgot the password and are unable to view certain programs. To do this, click "Menu" on your remote control and use the arrow keys to select "Parental Controls." Enter the master password, which is "4357" to reset the password.
  4. 4 Turn off the caption vision option if you are seeing a large black box on your screen. To do this, click the "Menu" button and select "Setup." Select "Caption vision" and press the "Plus" button on your controller to set the option to "Off."
  5. 5 Check the "TV/Video" setting if you're not getting a picture on your screen. You may have inadvertently selected a video input that isn't active. Press the "TV/Video" button on your remote to cycle through video inputs.
  6. 6 Alter the brightness settings if you are experiencing a poor picture or no picture. To do this, press "Menu" and select "Video." Increase the brightness settings to see if the picture begins to appear.
  7. 7 Make sure the volume is not muted if you are experiencing a clear picture but no sound. Press the "Mute" button on the remote control to turn mute on and off.
  8. 8 Power cycle your Sony Wega if it's frozen or not responding to your remote control. Unplug the power cord and wait a few seconds. Plug the power cord back in.
Dec 02, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Tip
ERROR CODE AND SERVICE MODE
Service tool modeHow to access
1. Select [SRV-TOOL] in Service Mode.
2. Press [OK] button on the remote control.
Display of SOS History
SOS History (Number of LED blinking) indication. From left side; Last SOS, before Last, three occurrence before, 2nd occurrence after shipment, 1st occurrence after shipment.
This indication except 2nd and 1st occurrence after shipment will be cleared by [Self-check indication and forced to factory shipment setting].POWER ON TIME/COUNT
Note : To display TIME/COUNT menu, highlight position, then press MUTE for (3sec).
Time : Cumulative power on time, indicated hour : minute by decimal
Count : Number of ON times by decimal
Note : This indication will not be cleared by either of the self-checks or any other command.Exit
1. Disconnect the AC cord from wall outlet.
Hotel mode
1. Purpose
Restrict a function for hotels.
2. Access command to the Hotel mode setup menu In order to display the Hotel mode setup menu, please enter the following command(within 2 second).
[TV] : Vol. [Down] + [REMOTE] : INPUT (3 times)
Then, the Hotel mode setup menu is displayed.
3. To exit the Hotel mode setup menu Disconnect AC power cord from wall outlet.
Troubleshooting Guide
Use the self-check function to test the unit.
1. Checking the IIC bus lines
2. Power LED Blinking timingCheck of the IIC bus linesHow to access
Self-check indication only:
Produce TV reception screen, and while pressing [VOLUME ( - )] button on the main unit, press [OK] button on the remote control for more than 3 seconds.
Self-check indication and forced to factory shipment setting:
Produce TV reception screen, and while pressing [VOLUME ( - )] button on the main unit, press [MENU] button on the remote control for more than 3 seconds.
Exit
Power LED Blinking timing chart
1. Subject
Information of LED Flashing timing chart.
2. Contents
When an abnormality has occurred the unit, the protection circuit operates and reset to the stand by mode. At this time, the defective block can be identified by the number of blinks of the Power LED on the front panel of the unit.
FOR MODE DETAILS CHECK THE FOLLOWING LINK
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
USE SEARCH TAB TO FIND MODELS OR USE DROP DOWN MENU
on Jun 30, 2015 | Panasonic Tc-50ps14 Tv Power Supply Board...
Lost picture
Sounds like you might be in "Air" mode and you want to change to "cable" mode. You are going to need to access the menu settings on the tv and change the cable input.
May 27, 2009 | Televison & Video
Sleep Timer on remote does not work
First try to access the sleep timer menu from the controls on the TV to verify the TV is working.
If that works then the remote has the problem.
Now try this;
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
If this does not work, then you may need a new remote unit.
Mar 10, 2009 | Olevia LT37HVS 37 in. LCD HDTV
Volume is too low.
smith,
good day, not so familiar with this model but try this.
1) try to check in your DVD remote controller if it does have a + and - buttons indicating volume , if does have this features press + button to increase the sound output
2) if remote commander doesn't have this features try accessing the " SETUP" menu. most probably there would be a button in your dvd remote indicating this button "SETUP"
3)once you've access the setup menu, there would be a dialogue box indicating ( Video setup, Audio Setup, display setup, parental lock) insome cases it will show you a display picture of all this menu
navigate the dialogue box and look for "audio setup" once you've access this part there would be options and controls where you can change the volume/audio settings .
cheers,
mark
Jan 29, 2009 | JVC HR-XVC25U DVD Player/VCR
NO COLOR ONLY BLACK PICTURES
carl,
i'm not familiar with this brand but try to access" setup menu" from your remote control.
1) from your remote control , locate button indicating "setup" and press it
2) viewing your screen there should be a dialogue box or this display board indicating 'Audio setup" Video setup" etc....
3)scroll arrow key (up/down key)and go to "video"
4)in "video setup there should be a dialogue box or drop box asking you to select either " Auto" " PAL" or "NTSC"
5) choose auto and see if anything change in your screen.
cheers,
mark
Jan 15, 2009 | Cyberhome DVR 1600 DVD Recorder
Adjusting color, picture & brightmess from remote contrrol
Under setup on the menu selection, The OPC must bo on the off mode, to be able to access those adjustments found under the video adjustments.
Jan 10, 2009 | Sharp 64LHP4000 64" Rear Projection...
Sony PCS-1 dont remember admin password
1. Access the Setup menu as follows:
Press and hold the MENU button on the remote commander.
2. Select Dial using the �� button on the remote commander.
3. Access the Service menu as follows:
Press 7 then 2 on the remote commander (without pressing the
PUSH ENTER button).
The Service menu appears. (See Figure 1.)
NOTE: To cancel Service mode and return to the Setup menu,
select Cancel using the arrow buttons, and press RETURN
Clear setup and FINISH
Bye Zamani Ali
azamani@iooc.co.ir
Nov 24, 2008 | Sony PCS-1 (PCS1) Video Conference
Switch to antenna mode without a remote
Can you access the menu on the front of the tv? Is so go into the menu setup and switch from cable to air then run the autoprogram to search your channels. If you cannot access the menu on the front of the tv then a remote will be required . Also if if your tv has audio/video jacks in the back of the set and you are not using them hook it up with those inputs for a better picture . Your have to push the input button to select that a/v input you used . Good luck
Feb 22, 2008 | Televison & Video
PCS-1
Reset password sony pcs-1
PUSH ENTER button).
select Cancel using the arrow buttons, and press RETURN.
Jan 18, 2008 | Sony PCS-1 (PCS1) Video Conference
Hitachi DV-PF2U DVD Player/VCR Logo
32 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
