Question about Car Audio & Video
2004 mustang cd player not ejecting
My 2004 mustang is showing ''cd error'' and is not letting me eject any cd's
  • 93 Answers
SOURCE: CD player ejects CD
ok,replace the belt in spindle motor,that is only problem
Posted on Oct 26, 2007
SOURCE: 6 cd changer
I had the same problem. It was trying to eject the Cd and getting hung. A lot of times when you get the CD Error message the door will be open a little. I took a CD and pushed it in and caught the edge of the hung CD. Once I connected, I just pushed a little to free it up and then it kicked it out. It happened about 5 times to me. I actually had to go in and remove the CD player once and manually remove the CD. Kind of a pain.
Posted on May 27, 2008
RescueTechLA
  • 2653 Answers
SOURCE: cd stuck inside laptop
There is a small hole, usually near the eject button. Unbend a paper clip and carefully push the paper clip into the hole, try to keep it straight. drive should pop right out.
Posted on Feb 20, 2009
SOURCE: 2004 Jetta CD Player Won't Read CD's
I had the same problem when I first got it.  I realized that the problem was the CD I was putting in.  The CD player will NOT read burned RW CDs.  I hope that helps!  But it will read burned R CDs and ones from the store.
Posted on Mar 05, 2009
SOURCE: CD player Error 3
dear,
I have different experiance with the C.Dplayer ( error 3 ) , there is no need to remove it nor send it to the dealer ,all you have to do when you have `` Error 3 `` is to reset the C.D player , by recycling the power supply ,this can be done by disconnecting the main car battery power supply , you must also keep the battery disconnected for at least one hour . then connect the cables to the batteries ,when you start the C.D player you will hear some clicking sound ,and watch the numbers of the C.D`s in the display you will find all what is inside has been detected by the display .
and your C.D player is back to normal..
i discovered ths by chance , when I had this error in the past ,coincidently I had to replace the battery and after installing the new batteries ,i was suprised to see the player back to normal condition by its self.
Posted on Jun 19, 2009
CD player won't accept or eject CD in 2004 Colorado truck
sounds like a perished rubber off one of its wheels inside.
Jun 20, 2017 | 2004 Chevrolet Colorado
2004 lexus RX330. CD player has 6 cd's in it. Has one cd in it. Will not play or eject. Error 4
Something inside the cd player has broken and can most likely be sent off for repair but I don't know how much that would cost, but a new one can range anywhere from $500-$1,000.
Aug 10, 2012 | 2004 Lexus RX 330
Ejection error for 2004 marquis cd player
How to fix my CD player when it says CD error when I put a CD in
Apr 15, 2012 | 2003 Mercury Grand Marquis
CD will not eject in my multi CD player. Get CD error
I decided to buy a better radio/cd player and have it installed.
Jan 05, 2010 | 2004 Ford Thunderbird
The player will not eject the cd but it will not play it either.
I know it sound crazy, but turn the system on, press eject while using a PLASTIC knife to lift the CD in the player. If the system is stock also try disconnecting the radio fuse for about 10 minutes or so with the car off. Reconnect it to see if the radio resets. You'll know the power completely went out because you'll have to reset your stations. By Resetting, hopefully the issue will solve itself. In a few of the system issues I've seen, when the motor won't open the faceplate, or the CD player won't give the CD back. I usually remove the faceplate or disconnect the negative side of the battery for about ten minutes. Try this if the fuse removal doesn't work. Good look. Let me know how it goes. there are other things to try.
Jul 27, 2009 | 2004 Honda Pilot
2004 FORD F-150 CD EJECT ERR
I've had this happen once before..CDR's are a little bigger than regular cd's.Sometimes they wont let go at all..You either can undo the battery and then reconnect then it usually automatically ejects or you'll have to manually do it or you can pull the fuse and then put it back in and the same proceedure..
Mar 28, 2009 | 2004 Ford F150
C D problems
Unfortunately the cd-lens are malfuctioning, probably, blocking also the ejecting tray. If so, yes it would be better to acquire a new one. As for the cd's You could, depending on the model, open the cd player but this would require special tools. The best thing would be, if you cannot open the cd player, to bring it to an authorized service, to solve the problem.
Jan 12, 2009 | 2004 Chevrolet Malibu
6 disk cd player error
This is a part failure in the mechanism that loads and ejects the disk, there are no repair manuals avail to either the tech or the consumer, the only place that the factory gives this info and parts to are factory authorized repair stations, bottom line you must pull the deck and contact a Ford dealer in your area for location of the nearest factory repair station. I was dealer tech for 20 years and that is how it is done.
Nov 21, 2008 | 2002 Ford Mustang
2001 Mustang 6-disk CD player
does it give an error code? usually it just a gear timing problem, will it load discs that are in it?
Jan 02, 2008 | JVC KD-S680 CD Player
Car Audio & Video Logo
479 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
