Question about Mustek DV-3500 Digital Camera
Unable to charge battery
Unable to figure out if the battery is properly inserted. Once you match the contact symbols it won't stay in the slot keeps popping up on one corner. Not sure if it is correct no picture for guide. Confused!!
Why does it keep turning off unless attached to power, even if it is fully charged?
The fully charged battery may be in need of replacement. It is unable to stay charged.
Sep 15, 2015 | Samsung Galaxy Tab 3 Tablet 10.1" TFT 1280...
Stunt copter won't sync
I presume you have lights & sound on the controller when you turn it on - fourteen quick beeps and then a different toned fifteenth beep. The screen lights (blue). Insert the battery (lettering facing up toward the helo fuselage unitl it's seated all the way - an LED inside the fuselage, visible from behind, quick flashes and then begins a slower blinking.
Once the helo battery is inserted, turn on the controller, which starts the aforementioned beeping. On the last controller beep the helo's LED will stay lighted, indicating the helo & controller are synched.
I had a problem making sure the battery was inserted all the way into the helicopter. You'll know it's inserted properly when the LED inside the helo flashes.
Dec 26, 2012 | Brookstone Stunt Copter RC Helicopter
My camera won't charge
Your battery probably is in the wrong way.So take it out and look on the bottom of it.You will see 3 copper cubes.Next look in to the slot where the battery goes and you will see 3 metal wires.Now take your battery and carefully line up the copper slots with the metal wires.Then push the battery in and close the battery slot.And your done go plug it into your USB slot and you will see a white battery symbol and you will know that it is charging.
Simple fix for a simple problem.
Nov 02, 2012 | Fuji film FinePix Z70 JX520 JV200 Z900EXR...
3 ds will not turn on
1. Make sure the battery pack is charged: Connect the 3DS to your charge cable or place it on the cradle. Make sure that the battery is charging. (Indicated by the orange light on the front. Even if the battery is fully charged, this light will come on briefly and then turn off.)
2. Press and power button and make sure the blue power light turns on. If this light turns on but you do not get any picture or sound, you may want to consider sending your system in for repair.
3. Make sure any DS or 3DS game card inserted is properly inserted into the game card slot. The game card should be inserted with the label facing out and then pushed into the slot until it clicks into place.
4. Check that the battery has been inserted properly. Unscrew the back panel of the unit, remove the battery and reinsert it, making sure that the contacts on the battery match up with the contacts on the system. The battery should be inserted so that the "positive" (+) and "negative" (-) icons on the battery are facing up. CAUTION: There was a known glitch in the system at launch that prevented players from tagging other systems that they've already tagged if the battery is removed for a certain period of time.
If none of the above works, you may need to send the system in for repair. Check Nintendo's support site for repair information.
Read more: http://wiki.answers.com/Q/How_do_you_troubleshoot_a_3DS_that_won't_turn_on#ixzz274f71pEg
Sep 21, 2012 | Nintendo 3ds Handheld Game Console- Cosmo...
I have a Mitsubishi magna 2001 model and I'm having computer problems the battery symbol keeps flashing and it keep stalling and won't idall properly
You need to have the Alternator tested, the battery symbol indicates the system voltage is low. The other problems are due to the low voltage.
Sep 18, 2012 | 2005 Mitsubishi Magna Wagon
My vivitar x345 wont hold charge
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% and graduallythe charge reduces until the battery won't charge up at all. OR The batteryshows a 100% charge but when the adapter is disconnected the battery drops offto zero capacity in a very short time. If the battery drops to an unacceptablecharge level then the battery needs to be replaced.
Mar 23, 2012 | Vivitar ViviCam X345 Digital Camera
I have a weird symbol showing on the dash for my 1985 blazer that I don't know what it means. I am having a problem starting it without a jump and then it doesn't want to stay charged. New battery, plugs,...
ok get power to truck turn key to on position pull plug off altenater one of then should be hot its call an exciter wire to excit the altenater to starg charging but first before all that check the alt. fuse inside your truck
Dec 15, 2010 | 1985 Chevrolet S-10 Blazer
Nintendo dslite wont turn on.tried charging it wit 3 different charges and it still wont charge
Ensure that you are properly recharging the battery.
1. Insert the small end of the adapter into the external extension connector (labeled "5.2V=IN") on the back of the Nintendo DS Lite, just next to the SLOT 1 Game Card opening.
2. Swing the prongs on the AC adapter until they lock into place, then insert it into a standard (120 volt) outlet.
The plug should be mounted vertically or on a floor outlet (such as a power strip).
3. Once the adapter is properly inserted, the unit will begin to charge (the orange charging light will display).
4. Once the DS Lite is fully charged, the orange charge light will go off.
Check the AC Adapter for damage (such as bent prongs or split wires). If you see damage to the AC Adapter, purchase a replacement from Nintendos Online Store.
Try plugging the AC Adapter into another wall outlet. Its possible the outlet is not working properly and has not been charging the Nintendo DS Lite.
If you are unable to get power to your Nintendo DS Lite, despite trying to properly recharge the unit, then your system will need to be repaired.
Nintendo offers convenient repairs, fast turnaround times and, for all systems repaired, a new one-year manufacturer's warranty.
Jul 14, 2008 | Nintendo DS Lite Console
How do you charge a panasonic lumix dmc-fx55 camera please? I have a plug and battery charger thing with two pegs sticking out of it - how does that charge it?!!!!
take the battery out look at the charger fo a + symbol match the battery to the plus symbol snap the battery into the cradle and the light on the charger should come on once it is in the battery is charging.if no light apears then it is not charging.
Mar 20, 2008 | Cameras
Symbol RF MC9060S - Internal Battery is dead
You have to first charge the backup battery, for charging insert a fully charged main battery into the MC906x. Then the backup battery will starts charging leave it there for one day. if that message is still coming then the problem is with the backup battery and u have to replce it
Jul 06, 2007 | Laser Symbol Technologies MC9060S Mobile...
Mustek DV-3500 Digital Camera Logo
19 people viewed this question
Top Mustek Cameras Experts
Steven Wander
Steven Wander
Are you a Mustek Camera Expert? Answer questions, earn points and help others
