Question about Dell Inspiron B130 Notebook
What do i do if the computer isn't getting a direct connection from the charger?
  • 93 Answers
Hi frnd...
If ur comp is under warranty. just call up dell tech support abd get the Adapter replaced if its an isuue wit the adapter.. Any ways just call up them and let them trouble shoot k.. take care...
Posted on Sep 29, 2009
    President:
  • 1,768 Answers
This issue need some clarification.
But you will need to a charge to the battery if the power adapter isn't working
You probably need a new power adapter.
you also may have a damage connector on the mother board of the PC.
My computer shuts down when i plug in the charger
Assuming this AC laptop charger functioned correctly at one time. Several Possibilities: (1) laptop charger has failed ... connect another compatible charger to your computer to test for this; (2) or the battery has failed ... remove battery and test if the charger plugged in directly powers the laptop.
Apr 07, 2013 | Targus APA30US AC Laptop Charger AC...
Asus charger won't charge
Stop using that charger. I sounds like you have a break in the wire and when you hold it in the right position, the two pieces touch and current flows. Unfortunately the heat is probably being caused by arcing and is a potential fire hazard.
Apr 06, 2017 | ASUS Original 19v 3.42a Ac Adapter Charger...
I have an Acer 7736Z the battery isn't charging. The BIOS on the acer support website give me version 2.10 which doesn't seem to match the directions given from previous questions and solution
If your battery will not charge, you need to run a test on some components on the laptop. The battery, the charger and the laptop itself. Once you detect the faulty conponent then you replace it with a new one.
To test the battery:
1.Power off the laptop,
2.Take out the battery,
3.Insert it in another laptop,
4.Check of it will charge,
If the battery holds a charge there, then it means the problem is not from the battery, but if it does not hold a charge, then it means the battery is defective and need to be replaced with a new one.
To test the charger:
1.Unplug the charger from the present laptop,
2.Connect it to another laptop to see if it will charge.
If it charges the laptop, then it means the charger is alright, and if it does not charge the laptop, then it means the charger is bad and need to be replaced.
To test the laptop:
1.Turn off the laptop,
2.Disconnect your present charger,
3.Remove your present battery pack,
4.Insert a well tested battery into the laptop,
5.Connect a well tested charger to the laptop.
If it powers on, then it and charges, then it means the laptop is working fine, but if it does not charge, then it means the connection port of the laptop is bad.Hope this information was helpful.
http://www.chargerbuy.com/replacement-acer-aspire-7736-ac-adapter-19v-90watt.html
Nov 16, 2012 | Computers & Internet
When i connect my toshiba charger and my laptop goes off but i have tried different charger still thesame
Normally this should be a charger issue. I personally use quite a high-end charger. You should consider when you buy laptop charger that the wrong voltage/current could mean your computer can't turn on.
However, if you're 100% sure the laptop charger isn't at fault, then I recommend getting it checked out by a repair shop, because it may be a main-board issue where your laptop is actually not accepting the power from the supply, which is potentially terminal.
Oct 15, 2012 | Toshiba Satellite M35X-S163 Notebook
I am getting a flashing green light when I try to charge my batteries on the Pronto M51 what does this mean
why did you change the batteries, did you verify that it wasn't the charger in the first place, sometime the charger will appear to charge but actually isn't. put a meter on one battery then plug in charger if voltage goes up charger is good if not look for loose connections and or bad charger.
Sep 25, 2012 | Invacare Pronto M51 Power Wheelchair
How long does it take for a vivitar Vivicam 5118 to charge fully?
Since the ViviCam 5118 isn't a battery charger, it will take a very, very long time.
The 5118 uses standard AA batteries. If you want to use rechargeable batteries then you much charge them outside the camera using a separate battery charger. Connecting it to a computer through the USB port will drain the batteries even faster, since the camera has to expend power communicating with the camera (even if only to say it has nothing to say).
May 08, 2012 | Vivitar ViviCam 5118 Digital Camera Blue...
Powercord replacement
please explain further.. do you mean your laptops power adapter cord?
thanks for using fixya
Nov 10, 2011 | IBM ThinkPad 380ED
The power cord when connected to the laptop is loose and looses connectivity. how do i tighten it or secure it to keep the connectivity?
Laptop chargers usually split into two parts, there will be a "brick" which is usually connected to a thick cord which has the plug on one end, and there will be another, detachable, thinner cord connected to it as well, which has the laptop adapter. Ensure that the charger is firmly plugged into the wall, and also ensure there is a secure connection where the second cord plugs into the charger.
Has anyone recently tripped over your charger? Did it fall? Could it have broken from wear and tear over time? If the answer to any of these is yes, then you should consider getting a replacement charger, there isn't really that much you can do to fix one if it's loose like that.
Jul 06, 2011 | Computers & Internet
My Sony ereader touch isn't charging. Pluging it in to either the computer or the wall charger, and the light doesn't go on. The screen is frozen on the last page it turned to.
Hi suebagnall,
If the redlight does not come on, try the following:
1. Connect the reader to the wall charger (make sure you use the Sony Charger ACS5220)
2. Hit the Reset button at the bottom of the reader
3. Check if the redlight comes on
4. If so, leave the reader charging for 15 minutes to see if it takes the charge
5. If this does not resolve the problem, probably you will need to contact Sony to get it repaired
eBookBoy
www.digitalreader.freeforums.org
Jun 27, 2011 | Sony Reader Touch PRS-600
My blackberry isn`t charging, i`ve plugged it in and nothings happening, when i plug it into my computer it has a lightning symbol by it but im not sure what it means?
does the phone charge when connected to the computer? The lightning icon means it is connected to power and is charging. Try another charger, it seems like your charger is the problem, not the phone.
Dec 15, 2009 | RIM BlackBerry 7290
Dell Inspiron B130 Notebook Logo
52 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
