Question about Maytag Refrigerators
My maytag msd2456dew will not stay cool. the compressor is not running but the fans are. could it be the start relay?
  • 82 Answers
Do you have power at the compressor?
There is a PTC sensor connected to the pins of the compressor.
Be careful !! and check for power there.
If in doubt, call an electrician. There is a risk of an electric shock.
You should have live and neutral at the compressor pins; one will be switched through a PTC Sensor.
Hope this helps.
Posted on Sep 29, 2009
Maytag refrigerator model# MFI2569YEM0 won't cool or freeze. Woke up to the alarms going off for the temp. Replaced the relay start thinking that was it, but did not fix the problem.
Check to see if the compressor is running you can fee it vibrating and the fans next to it should be running if it not running but fan is may be overload protector
Apr 13, 2016 | Maytag Refrigerators
Refrigerator not cooling
replace the ptc overload/relay on the side of the compressor this aids in starting and running of the compressor
Jan 12, 2013 | Maytag MFI2568AES Stainless Steel Bottom...
I have a Maytag 2651HEW . Seems to be cooling and
Thant must be checked out soon as that buzzing sound is the start relay struggling to start the compressor. The longer it goes on without repair to either the sart/run capacitor, start relay and overload the higher the chance there is for complete compressor failure. The condenser and evaporator areas should be cleaned and inspect both internal freezer fan and lower condenser fan that both run without stopping. Let me look for a service manual for your model and return soon, Thanks, Sea breeze
Jan 10, 2010 | Maytag MSD2651 HE Side by Side...
My Maytag refrig MSD2454FR is not cooling. Fan runs but compressor is not starting
Part number 61004918 is the compressor start relay.
Replace the relay to solve most Maytag compressor problems.
Nov 09, 2009 | Maytag Refrigerators
Fridge acts like compressor is not coming on - Maytag wide by side - seven yrs. old
Pull the refrig out and remove the back panel . You should see the compressor and the cooling fan ( condenser fan ) . If the fan isn't working , it needs to be replaced . If the compressor isn't running or starts then cuts off , then the box plugged onto the side of the compressor , with 3 wires going to it ( overload/relay ) needs to be replaced .
Oct 31, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Side by side not cooling
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Oct 01, 2009 | Maytag MSD2756G Side by Side Refrigerator
Maytag msd2456dew not cooling / not freezing after noisy fan
my Matytag msd2456dew fridge fan is running, no ice bulid up on coils in freezer section, but no cold air to freeze anything in freezer section or cold air in fridge section. what can be the problem?
Sham
Feb 15, 2009 | Maytag Refrigerators
Maytag Skybox not cooling
sounds like compressor relay --- if the fan and compressor come on and then shut off after about 5-10 seconds -- its the relay --- sometimes you have to also replace the transformer and capacitor on the opposite side of the unit --- all items are accesible from the back of the unit
Jan 23, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Fan runs but no cool air on both freezer side and cold side
If you hear the compressor try to start then click off, you probably have a bad compressor or a bad relay. If it is less than 5 yrs old the compressor is still covered by warranty and will be replaced free of charge. The relay is only covered for a year. With it being a Maytag, I bet it is compressor. There have been a few models with control board problems that have caused this symptom, but that's not likely to be your problem.
Oct 06, 2007 | Maytag MSD2756GES Side by Side...
Refrigerators Logo
124 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
